Can someone confirm for me if there is a metal washer between the spacer
and the delrin bushing on both the inboard and outboard torque tube
brackets. I only installed the inboard one as the outboard one caused the
control arm to rub against the rib. In hindsight I am guessing there should
always be a washer between the spacer and the plastic bushing.
Roland
R56
