Aileron Hinge Spacers ??
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 5:45 pm
I am looking for the hinge spacers identified as W-605 (1/16) and W-610
(1/8) and cannot find them anywhere in my supply of parts. Do I make them
from some sort of stock material or are they an actual part? Can AN washers
be used instead? I have kit # 56, and these are only identified as spacers
on the original plans with no dimensions or part numbers. On the newer set
of plans I have (1999) they are actual part numbers.
I need to bring the hinges out from the spar a bit to allow for clearance
between the top skin and the ailerons. Any ideas??
Roland
R56
