cc-38 mounting
Jones, Mike
cc-38 mounting
Post by Jones, Mike » Fri Feb 17, 2012 8:33 pm
Hi All
Have noticed a problem with mounting the main control tube that the control
sticks attach to on my rebel.
The main carry through fus-5's (x2) are cut in half on my rebel instead of
being square tube like on most rebels.
The brackets that hold the control tube are cc-38 and normally rivet to the
fus-5's.
In my case the cc-38 brackets are to wide to attach to both fus-5's , what
do i attach the cc-38 to, the floor panel or must i add channels ???
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
Drew and Jan
cc-38 mounting
Post by Drew and Jan » Fri Feb 17, 2012 8:33 pm
Mike on my rebel I cut the tubes to save weight and I used peices of .125
material about 2 1/2" wide and the same length as the cc38 I centred the
cc38 on the fus5 and used 3/16 rivets through the cc38, doubler and fus5.
[I didn't have any 1/8" rivets any where near long enough] and 1/8" rivets
every where else.
At 12:38 PM 11/13/00 -0500, you wrote:
Hi All
fus-5's.
Mike#007
EOM
Click here for Free Video!!
http://www.gohip.com/freevideo/
