[Fwd: Re: Amphib Wheel Bearings]
Post by Walter Klatt » Fri Feb 17, 2012 8:33 pm
Looks like my email had been dropped from the list server and I wasn't
getting any messages for a few days. I "joined" again, and am resending
this previous post, as I don't believe it got through.
It's a question for Wayne O., if you could just read below.
-------- Original Message --------
Subject: Re: Amphib Wheel Bearings
Date: Sun, 05 Nov 2000 10:34:46 -0800
Organization: @Home Network
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Walter.Klatt@home.com is not allowed to post to the list.
Please contact mike.davis@dcsol.com if you have any problems.
Wayne, would you attribute the bearings lasting 3 years more to the use
of the chrome
plated upgrade or to the drilled axles? Has there been any experience
with drilled axles
using regular steel bearings?
"Wayne G. O'Shea" wrote:
Bob (and All),
Lots of places (including my local guy) stock the 08125 bearings in plain
steel, but since Howard's Chrome plated ones have lasted 3 years without any
problem (since I drilled his axles to fill the wheels with grease), I don't
want to try plain steel ones like the disintigrated ones I removed from
FOKM. I would rather spend the extra $340 on bearings ($100.00/bearing vs
about $15.00 for steel) than the labour TWICE per summer to change them if
using plain steel! Stainless may even be better if available, I should look
into that and see if they are available (and at what cost)!
