lower corner wraps
Jones, Mike
lower corner wraps
Post by Jones, Mike » Fri Feb 17, 2012 8:33 pm
Hi all
Was installing .032 lower corner wraps on weekend and was going to leave
some extra width on them to add another row of rivets on side and bottom as
suggested by some builders.
Was wondering however on rivet spacing and pitch. Should the second row of
rivets be same as the first or offset ? Also how far apart from the first
row 3/4", 1" , 1 1/4" ??
Any suggestions out there??
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
BILNEWKIRK
lower corner wraps
Post by BILNEWKIRK » Fri Feb 17, 2012 8:33 pm
I AM GOING TO BE REMOVING MY ENGINE AND INSTALLING A NEW MOTOR MOUNT FOR MY
O-290. IF I ADD THE .032 CORNER WRAPS, SHOULD THEY BE ADDED OVER (IN
ADDITION TO) THE EXISTING, OR SHOULD THE EXISTING BE REMOVED?
BILL NEWKIRK
REBEL 376
lower corner wraps
Post by Bob Patterson » Fri Feb 17, 2012 8:33 pm
If you're going to change them (and I wouldn't if they're not bending)
you should remove the old ones first ...
---------------------------orig.-----------------------------------------
BILL NEWKIRK
REBEL 376
<HTML><FONT SIZE=2>I AM GOING TO BE REMOVING MY ENGINE AND INSTALLING A
NEW MOTOR MOUNT FOR MY <BR>O-290. &nbsp;IF I ADD THE .032 CORNER WRAPS,
SHOULD THEY BE ADDED OVER (IN <BR>ADDITION TO) THE EXISTING, OR SHOULD THE
<BR>
<BR>BILL NEWKIRK
<BR>REBEL 376</FONT></HTML>
lower corner wraps
Your call !! That's the joy of homebuilding !!!!
Most likely - offset, same spacing as orig. row, and as far
in as possible, giving correct edge distance.
---------------------------------orig.--------------------------------
At 07:39 AM 11/6/00 -0500, you wrote:
Hi all
Mike#007
EOM
klehman
lower corner wraps
Post by klehman » Fri Feb 17, 2012 8:33 pm
If you look at the spacing of the two rows of rivets on the outboard
side of the tank skin you will get an indication of a good way to join a
thick sheet to a thin sheet. The rivets in the inboard rivet line are
close together. The rivets in the outboard line are farther apart so
that the outboard line weakens the thinner wing skin less and more
strength is passed through to the inboard rivet line.
"Jones, Mike" wrote:
Hi all
