[rebel-builders] Bungie under carriage
my mistake on previous message not aileron tip, should be
What type of undercarriage do you have, bungee, die spring, spring ?
I have almost complete parts for bungee gear, was mounted on mine then I
removed and switched to die spring, but still have a lot of the parts
Mike#007
Brian Bridgewater
Sent: September 3, 2009 10:18 AM
Subject: [rebel-builders] Bungie under carriage
Hello fellow Murphy maniac's I own Rebel No. 274R which I have recently
had a wrecked undercarriage so looking for spare parts to rebuild with,
also needed is port wing tipcowl and an aelron tip cowl can anyone help
me out please regards Brian (wocestershire England)
Mike#007
Brian Bridgewater
Hi Mike it is the Bungee but don't mind upgrading understand there is a spring adaption for the bungee's but never seen it
Will make parts list and send to you tonight
Not looking for much money for the stuff, just don't want to throw it in garbage
cheers
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Brian Bridgewater
Sent: September 3, 2009 11:21 AM
Subject: Re: [rebel-builders] Bungie under carriage
cheers
Hi Mike & Brian,
It's nice to see the parts exchange is alive, that's the same way I was able
to get parts the a/c I was working on. But just to beware, I believe the
MAM bungee gear did have a change in materials to accommodate the 1650 gross
Rebels.
I'm just noting the difference in serial numbers, 007 to 274.
Jeff
Rebels.
Jeff
Thanks very much mike here's my E-Mail ecomind@ymail.com look forward to
hearing from you by the way where are Brian.
________________________________
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Thursday, 3 September, 2009 16:24:24
Subject: RE: [rebel-builders] Bungie under carriage
garbage
cheers
Brian Bridgewater
spring adaption for the bungee's but never seen it by the way it is 1650 lb
model " Im interested" Brian
Sent: Thursday, 3 September, 2009 15:58:48
Mike#007
Brian Bridgewater
Brian, Michael,
I'd be interested too, as I'm building bungee gear with a few of the parts from
a damaged set (received when I sold/traded my cessna style gear). You got
there first tho Brian --- just between the two of you if there are parts left
you won't need.
BTW, I've taken a first look at building my replacement set out of 4130 steel
and it looks somewhat promising.
-Ben/ 496r
On 9/3/2009 7:33 AM, ecomind@ymail.com wrote to rebel-builders:
[quote]
you won't need.
-Ben/ 496r
[quote]
Yep , the 1650 bungee was heavier stuff, this will be checked
cheers
Jeff Micheal
Sent: September 3, 2009 2:42 PM
Hi Mike & Brian,
able
gross
Rebels.
Jeff
cheers
Jeff Micheal
Hi Mike & Brian,
able
gross
Rebels.
Jeff
wrote:
forward toThanks very much mike here's my E-Mail ecomind@ymail.com look
inhearing from you by the way where are Brian.
agarbage
cheers
Brian Bridgewater
1650 lbspring adaption for the bungee's but never seen it by the way it is
Imodel " Im interested" Brian
recentlyremoved and switched to die spring, but still have a lot of the parts
Mike#007
Brian Bridgewater
with,had a wrecked undercarriage so looking for spare parts to rebuild
helpalso needed is port wing tipcowl and an aelron tip cowl can anyone
I have 2 complete slider tube struts for bungie gear for 1650 lb.
gross. Including p/n LG 37, 4, 5, 6-2, 35, 36, & 40.
Each strut has a small tag on it, that I think says LG 4B, I am
guessing that is the p/n for the complete assembly. Don't know
what there worth?
Also have a set of 4130 main gear legs, and compression struts
with the machined aluminum fittings, they are set up for 3/4"
axel. However the welding would require some reworking.
Keith Pierson kp12793@aol.com
On 9/3/2009 11:25 AM, bransom wrote to rebel-builders:
-> Brian, Michael,
-> I'd be interested too, as I'm building bungee gear with a few of the parts
from
-> a damaged set (received when I sold/traded my cessna style gear). You
got
-> there first tho Brian --- just between the two of you if there are parts left
-> you won't need.
-> BTW, I've taken a first look at building my replacement set out of 4130
steel
-> and it looks somewhat promising.
-> -Ben/ 496r
-> On 9/3/2009 7:33 AM, ecomind@ymail.com wrote to rebel-builders:
what there worth?
-> Brian, Michael,
from
got
-> you won't need.
steel
-> -Ben/ 496r
My bungee gear parts are for the lighter 1350 rebel, if any one wants it let me know
cheers
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jones, Michael
Sent: September 3, 2009 11:24 AM
cheers
cheers
cheers
Hello Keith I could be interested in those struts of yours are they made up or still
In looking over the damaged bungee gear I have, it looks like the drag
strut buckled right at midway where the holes are for the fairing piece
that attaches there. Granted this particular gear set hit an abnormal load
(snow bank at the end of an ice landing), but it does make me think the
holes at the middle point of the drag strut are not the best idea. Any
other thoughts on this?
Although I can't swear to the damage sequence, it appears that the main
gear legs crumpled backward following the failed drag strut. This ended up
particularly bad in terms of repair (of the other airplane) because it tore
off the fuselage lugs of the cage carry through gusset (Fus-2).
I'm back to thinking I'll probably use aluminum and pretty standard stuff
for all of my gear rework, with the exception of using a 4130 drag strut
(.050 wall thickness) and no holes in anything mid-span. As mentioned, I'd
be interested in anyone's thoughts on bungee gear strengths and weaknesses.
At 09:37 PM 09/09/2009 -0800, you wrote:
main gear leg bent back it would push the fairing piece back causing the
drag strut to bend at the attach point. I think the weak point on the rear
strut is the unsupported bend at the top. If the gear hadn't failed when it
hit the snowbank the plane would have ended up on it's back. If you weld it
would probably be easier to make an all steel gear.
I'm not an engineer these are just ideas. It would seem to me that as theIn looking over the damaged bungee gear I have, it looks like the drag
Interesting points Drew.
When I read the post I was reminded of a previous warning not to drill any
holes in the gear struts for fairing mounting due to weakening issues.
That said, my fairings are drilled and riveted into my gear legs. I've
wondered about rebuilding them to correct this, but...... on the amphibs
since 05 so no rush.
Were you up in Muskoka over the weekend? We spent the whole weekend flying
around visiting friends, and doing Henry's, put 3 fillups through the 0-320.
Sent: Thursday, September 10, 2009 8:15 AM
At 09:37 PM 09/09/2009 -0800, you wrote:I'm not an engineer these are just ideas. It would seem to me that as theIn looking over the damaged bungee gear I have, it looks like the drag
load
up
tore
weaknesses.
it
it
