the elevator)
Max dn trim: 1 3/8"
Aileron up travel: 4"
Aileron dn travel" 5 1/2"
Ted Waltman
Waltman
Sent: Tuesday, August 25, 2009 8:56 AM
Subject: RE: [rebel-builders] Moose: Elevator trim
Servo motor determines max up/down. I don't think I have any interference
issue with the slot/servo actuator arm but I'll find out this a.m. and let
you know. Someone also wanted to know measurements for aileron up/dn
distances so I'll measure that too (If I remember...old age you know).
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Fred
Messinger (fredm)
Sent: Tuesday, August 25, 2009 8:38 AM
Subject: Re: [rebel-builders] Moose: Elevator trim
That would be most excellent if you could, Ted. Thanks. No rush on it.
Are your up and down maxes determined by the motor maxes itself or to you
have stop switches?
Thanks again,
Fred
On Tue, Aug 25, 2009 at 9:14 AM, Ted Waltman <ted@vafm.org> wrote:
upFred,
I don't recall seeing any factory recommendation on trim tab travel. In
flight, a little bit of change has a big effect. I could measure my max
theand down travel if you want me to.... As I recall, I simply positioned
tabservo in its neutral position then sized the actuator arm such that the
facewas aligned with the elevator at that position. Haven't found any
situation
yet where I think I've run out of trim.
Messinger (fredm)
Sent: Tuesday, August 25, 2009 5:42 AM
Subject: Re: [rebel-builders] Moose: Elevator trim (crush tube)...was: Ray
Allen Servo
Thanks for all there great feedback on this topic, guys. I mounted the
servo/tube last night.
I measured the maximum down (relative to the elevator) angle that the trim
woud travel without the tube installed. It was only 13 degrees. And the
reason for that is the acute angle at the piano hinge between the wide
word)of the trim and the face of the spar begin to bind on one end. I checked
whether or not the trailing edge of the trim is flush with the trailing
edge
of the elevator and they are off by about 3/32.
How do I find out what the factory recommends?
I did search the web site and archive for this and did not fine anything
related to Mooses.
Thanks again!
Fred
On Mon, Aug 24, 2009 at 8:49 AM, Ted Waltman <tedwaltman@gmail.com> wrote:
toMounting method is what the manual says <grin>. Nope, the tube is thereIstiffen the threaded rod, which bends all by itself under load. I know,neverhad one bend pretty bad before I put on the tube. Now, with the tube,Rayhave a problem. Oh, by the way, I never put proseal in there--just slid
tube on. Maybe water will corrode the rod someday, but that's another
problem...
snowyrvr@mtaonline.net
Sent: Sunday, August 23, 2009 7:34 PM
Subject: RE: [rebel-builders] Moose: Elevator trim (crush tube)...was:Allen Servo
Man, Ted, that mounting method really sounds hoaky. (yes, that's a
bendingI'm guessing the tube's purpose is to prevent exterior bumps from
willikethe little rod? Doesn't seem like it'd do much as a stiffener appliedwasthat. If I remember, this same El-0032 is in the rebel parts as well; I
just haven't seen a reference to it in the manual...yet. CW
Original Message:
Date: Sun, 23 Aug 2009 18:12:08 -0600
Subject: [rebel-builders] Moose: Elevator trim (crush tube)...was: Ray
Allen Servo
Part # is "Crush Tube" listed as EL--0032 in the manual. I thought itper a service bulletin, but none is shown on the website. The issue is
that
the trim tab actuator arm is simply a 1/4-28 threaded rod. That rod
PutHansbend under moderate force. Hence, once one has the rod cut to proper
length
and tested for successful full up/down trim travel, one is to spread
proseal
on the threaded rod then slide the crush tube over it. The crush tube,
therefore, is simply an aluminum sleeve (pipe, per se).
Hope this helps and makes sense,
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf OftheKuck
Sent: Saturday, August 22, 2009 10:58 AM
Subject: Re: [rebel-builders] Moose: Ray Allen Servo
TED, could you please mail me a copy of the service bulletin regardingwrote:Ray Allen Servo. I was not aware that there was such a S.B. to
hansk3d@gmail.com
cheers
Hans
On Fri, Aug 21, 2009 at 7:58 PM, Ted Waltman <tedwaltman@gmail.com>Fred,
AFAIK, every Moose owner uses this combination servo/actuator arm.
systemthehardwaresleeve on as per the service bulletin (get a sleeve at your localFredstore if you don't have one already).
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf OfMessinger (fredm)
Sent: Friday, August 21, 2009 3:45 PM
Subject: Re: [rebel-builders] Firewell caulk
Hi Guys,
I'm currently installing the elevator trim tab servo motor on my moose
quick
build.. The one MAM shipped is manufactured by The Ray Allen Company.
Everything (motor casing, clevis forks) is made out of a hard plastic
material. The push rod itself is a threaded metal rod, though.
My questions: Is anyone else using this set up? If not, which
forksareyou using?
I confess, I'm a little concerned about those flimsy little clevisapplication--and
the plastic drive pin....especially in cold weather.
Fred
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
myhosting.com - Premium MicrosoftR WindowsR and Linux web andhosting - http://link.myhosting.com/myhosting
