First Flight
first flight
hi gang a red letter day tonight i flew the bird off the airport
for the first time with floats
did a taxi test hop to see if i have control then turned , went back
to the end of 350 and took off real carefully! did one circuit
with the gear down needed a little up elevator to compensate for the
long nose gear sticking down into the wind
landed fine no such thing as floating around up there like when it was
a taildragger
next i did 15 minutes with the gear pumped up much better! seems to
fly about 106 t o 110 a t 2400 sounds about right?
gear went back down ok landing great what a day!!! now i have to
install the water rudder cabling bob fisher rebel 342
Archives located at http://www.dcsol.com:81/default.htm
a taildragger
first flight
Congrats, Bob, and just in time for summer. What prop and hp do
you have again? I have been pumping my gear for a couple years
now, and no problems for me.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Fisher
Sent: Wednesday, May 05, 2004 5:49 PM
Subject: first flight
off the airport
turned , went back
did one circuit
compensate for the
a taildragger
better! seems to
rebel 342
first flight
Hi Bob,
Congrats on flyingthose darn amphibs <:-)) that I looked at for so long in
mygarage. I'm still not getting things done here so I haven't got my bird
painted and ready for summer yet.
Anyway, happy to here that the floats survived at least one up/down and
landing. Glad to here you're happy with the performance.
Phil.
Phil.
*-------------------------------------------------------------------------*hi gang a red letter day tonight i flew the bird off the airport
a taildragger
first flight
Congratulations, Bob, on your first flight with amphibs!
Bruce
Bruce
first flight
No problem, and great to see another Rebel amphib flying. I couldn't remember if you had the 150 or 160 engine. It will be interesting to see what you get full throttle straight and level with the 74X56 prop. My guess is that it could be just right for you, since my 150 hp and 74 X 54 prop is able to reach 2700+ pretty easily.
Bruce, now that you've been flying a while, how is your top end? I believe you have a 150 hp and 74 X 56. Can you reach 2700 RPM at straight and level, at say 1500 ASL?
Date: Thursday, May 6, 2004 3:18 pm
Subject: Re: first flight
hi walter thanks much for your answers to my questions over the
past few
months 160 hp the prop is a sensenish 74 dia by 56 inch
may be a bit
too coarse we`ll see
bob fisher
Sent: Thursday, May 06, 2004 10:14 AM
Subject: RE: first flight
*------------------------------------------------------------------Congrats, Bob, and just in time for summer. What prop and hp do
[mike.davis@dcsol.com]On Behalf Of Bob
Fisher
off the airport
turned , went back
did one circuit
compensate for the
a taildragger
better! seems to
rebel 342
-------**------------------------------------------------------------------To unsubscribe from this list go to:
first flight
I can't remember what mine does at 4000 (87.5% power), but I know
at 1500 (95 % power) I will exceed 2700 at 125 mph. I thought
your (Bruce's) prop was 56 pitch. Mine is 54. Yep, with the drag
of floats I rarely have to slip to get down. Just pull it back to
60 mph and she drops like a rock. Sounds like you will have the
usual CHT problems once the summer heat comes. Mine is running at
360 - 380 these days.
Legeorgen@aol.com
Sent: Thursday, May 06, 2004 5:52 PM
Hi Walter
My airstrip is 1950' ASL so it might get a little
messy to see what it will
do all out at 1500 ASL.
Really though, I don't believe I have ever checked my
top end, yet, but I
will do that this weekend and report back. Probably
close to yours since we fly
same engine and prop.
I have been cruising at 2400 or 2500 RPM, usually
around 4000' ASL, and run
100 to 105 MPH respectfully. Lots of drag! I can
really feel the drag on
landing as I must carry power all the way down ... to
land on terra-firma.
CHT's can be kept below 400* F at these settings only
if I don't lean to peak
EGT. At peak CHT's run at 415* and at 150 before peak
it will run at 390*
hottest CHT.
Bruce
first flight
hi phil thanks for the response how is the family?? hope to see you
this summer flying! bob
Sent: Thursday, May 06, 2004 3:28 PM
inHi Bob,
*-------------------------------------------------------------------------*mygarage. I'm still not getting things done here so I haven't got my bird
Phil.
a taildragger
first flight
hi walter thanks much for your answers to my questions over the past few
months 160 hp the prop is a sensenish 74 dia by 56 inch may be a bit
bob fisher
bob fisher
*-------------------------------------------------------------------------*Congrats, Bob, and just in time for summer. What prop and hp do
Fisher
off the airport
turned , went back
did one circuit
compensate for the
a taildragger
better! seems to
rebel 342
first flight
Hi Walter
My airstrip is 1950' ASL so it might get a little messy to see what it will
Really though, I don't believe I have ever checked my top end, yet, but I
will do that this weekend and report back. Probably close to yours since we fly
I have been cruising at 2400 or 2500 RPM, usually around 4000' ASL, and run
100 to 105 MPH respectfully. Lots of drag! I can really feel the drag on
landing as I must carry power all the way down ... to land on terra-firma.
CHT's can be kept below 400* F at these settings only if I don't lean to peak
EGT. At peak CHT's run at 415* and at 150 before peak it will run at 390*
hottest CHT.
Bruce
hottest CHT.
Bruce
First flight
Sam & Sandi,
Congratulations! You certainly have a "one of a kind"!
How did you do your cabin step? Susan is undertall and after all the
building help it seems she should at least be able to get into the
plane. Also, did you narrow your elevator or leave it full width?
Enjoy that fly off time.
Elite 624E
Elite 624E
First flight
Congratulation,
it must be a great adventure. All that hard work is finally rewarding
you....!!!!.
We should be able to fly ours witin a year
sincerely
dr gilles st pierre E717
you....!!!!.
sincerely
Subject: First flight
Date: Mon, 17 Jan 2005 21:55:53 -0500
Sam & Sandi,
Elite 624E
First flight
Good onya Jesse, was it easier than the DC3? Congrats. Mike
first flight
Congrats Jesse! We'll be following you soon!
Jason and Rebecca
817R
Jason and Rebecca
817R
