I will bend up a single louver with a temporary mounting and see what
happens during flight test.
Al
Sent: Thursday, June 07, 2001 6:34 PM
Subject: Re: Oil cooler
-Hi Al !
It might be a good idea to put a scoop facing back over the
front of the opening in the cowl. That would break the airflow up
and create a little suction to help the cooler. Could be just bent-up
sheet, maybe 3/4" high ...
-------------------------------orig.--------------------------------------
theAt 10:03 PM 6/5/01 -0700, you wrote:problem. My SR has the IO540 and the oil cooler is too large to mount onThe oil cooler discussion has started to make me think I may have a
Iback of the baffling. Murphy used two smaller coolers, one on each side.
frommounted one large cooler on the inside of the cowling, flush against the
left side. Ram air comes from a 3" scat duct from the front of cyl #1. The
air goes to a box on the back of the cooler and exits through the side of
the cowl. My thinking was to get the coolest ram air possible and exit
that air with out adding any pressure to the lower side of the engine. My
question is, will the air flow around the outside of the cowl keep air
youexiting the cooler? Has anyone experienced this type of installation? Do
make methink I need to break up that air flow? If so how?Al Paxhia
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2919.6307" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>The oil cooler discussion has started to
coolers,largethink I may have a problem. My SR has the IO540 and the oil cooler is tooto mount on the back of the baffling. Murphy used two smaller
cowling,oneon each side. I mounted one large cooler on the inside of the
thefront offlush against the left side. Ram air comes from a 3" scat duct from thecyl #1. The air goes to a box on the back of the cooler and exits through
keepof theside of the cowl. My thinking was to get the coolest ram air
possible and exit that air with out adding any pressure to the lower sideengine. My question is, will the air flow around the outside of the cowl
installation?air from exiting the cooler? Has anyone experienced this type of
*-------------------------------------------------------------------------*Do you think I need to break up that air flow? If so how?</FONT></DIV>
<DIV><FONT face=Arial size=2>Al Paxhia</FONT></DIV></BODY></HTML>
murphy-rebel mailing list.
