[rebel-builders] EliteProp&airfilter
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 4:01 pm
Walter:
As a matter of fact, I have both a mount and a speed cowl, but there is, of
course, a snag. The tube that goes from the lower to the upper mount on the
right side of the mount is not bent enough, and just touches the dipstick
tube, but if you're willing to do some welding, it's yours for the shipping.
And the speed cowl fiberglass is poorly laminated, so I wouldn't recommend
using at as a complete unit. But sections could be cut out and grafted in
to an existing unit.
Al
John W
Post by John W » Sun Feb 19, 2012 4:01 pm
Hey Bob and Sean
where are the pics of the Vans airbox install posted?
Tks
John W
--- Robert Andrews <robert@montanasky.us> wrote:
Thanks for uploading the pics Sean ... their worth
1000 words and more.
Looks like the air box inlet is bigger then would be
for a VANS installation
... no mods to the lower cowl .. true?
Bob 612e
Robert Andrews
Sent: Saturday, October 13, 2007 9:21 AM
Subject: RE: RE: [rebel-builders]
EliteProp&airfilter
Roger. Checked the archives for a picture of a VANS
air box install ... no
joy. Any chance you could upload a few? Sean, your
experience and lessons
learned with this is most appreciated.
Cheers, Bob 612e
kitplane_solutions@dcsol.com
Sent: Saturday, October 13, 2007 9:45 AM
EliteProp&airfilter
No that is a the original two piece Elite cowl that
had a lot of rework done
around the air box. I have since figured out how to
put the airbox in
without
an extra 50 hours of glass work but it sure looked
cool
Sean
On 10/12/2007 4:22 PM, robert@montanasky.us wrote to
rebel-builders:
-> Just curious, are this pics of a rebel cowl
modified to work with a VANS
air
-> box?
-> www.aacnet.com/elite/cowl-1.jpg
-> www.aacnet.com/elite/cowl-3.jpg
-> Bob 612e
-> -----Original Message-----
-> From: mike.davis@dcsol.com
-> WALTER KLATT
-> Sent: Friday, October 12, 2007 2:37 PM
-> Subject: Re: RE: [rebel-builders]
EliteProp&airfilter
-> Yes, they are. Email me offline if you want to
sell it.
-> Walter
-> From: Robert Johnson <bestofbo@cogeco.ca>
-> Date: Friday, October 12, 2007 2:01 pm
EliteProp&airfilter
-> > Hi Walter: I have a dynafocal mount for an O320
- are they the
-> > same?? Bob J
-> > ----- Original Message -----
-> > From: "WALTER KLATT" <Walter.Klatt@shaw.ca>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Friday, October 12, 2007 4:37 PM
-> > Subject: Re: RE: [rebel-builders]
EliteProp&airfilter
-> > > Sounds very good.
-> > > Now I also need a new speed cowl and a
dynafocal mount. Anyone
-> > have one of
-> > > these they don't need?
-> > > Walter
-> > > ----- Original Message -----
-> > > From: kitplane_solutions@dcsol.com
-> > > Date: Friday, October 12, 2007 12:57 pm
-> > > Subject: RE: [rebel-builders]
EliteProp&airfilter
-> > > To: rebel-builders@dcsol.com
-> > >> It does come with all the bits to assemble
the door but you will
-> > >> need a 2"
-> > >> flange to attach the scat hose to your heat
muff. Vans also
-> > >> includes a
-> > >> alternate air door kit to bypass the filter
as the normal setup
-> > >> filters both
-> > >> warm and cold air. The original bypass door
was held close by a
-> > >> magnet and
-> > >> was to open itself if the filter plugged but
was found to open
-> > >> when ever it
-> > >> felt like it. They now have a cable operated
door in its place.
-> > >> You do not have
-> > >> to install this door if you are not flying
in heavy snow or
-> > >> freezing rain as it is
-> > >> olny there in case you pack the air filter
full of ice and snow
-> > >> important if you
-> > >> fly a lot of IFR. If you are ever in dought
just pull the carb
-> > >> heat on as it is
-> > >> also filtered you can even use it on the
ground.
-> > >> Sean
-> > >> On 10/12/2007 10:18 AM, walter.klatt@shaw.ca
wrote to rebel-
-> > builders:>>
-> > >> -> Does it come with the carb heat gate or
is this separate?
-> > >> -> Walter
-> > >> -> -----Original Message-----
-> > >> -> From: mike.davis@dcsol.com
[mailto:mike.davis@dcsol.com] On
-> > >> Behalf
-> > >> Of
-> > >> -> kitplane_solutions@dcsol.com
-> > >> -> Sent: Thursday, October 11, 2007 7:29 PM
-> > >> -> To: rebel-builders@dcsol.com
-> > >> -> Subject: RE: [rebel-builders]
EliteProp&airfilter
-> > >> -> Vans P/N FAB-360/540 fits all 0-360 with
a carb
-> > >> -> Sean
-> > >> -> On 10/11/2007 12:42 PM,
-> > rebel-
-> > >> builders:->
-> > >> -> -> Sean,
-> > >> -> -> The VAN's website shows a few air
boxes for O-360's.
-> > >> Which one did
-> > >> you
-> > >> -> -> use? ... and was there any issues in
rigging up carb heat?
-> > >> -> -> Bob 612e
-> > >> -> -> Original Message:
-> > >> -> -> From: kitplane_solutionsol.com
-> > >> -> -> Date: Thu, 11 Oct 2007 12:32:23 -0900
-> > >> -> -> To: rebel-builders@dcsol.com
-> > >> -> -> Subject: RE: [rebel-builders]
EliteProp&airfilter
-> > >> -> -> No you must cut out the blade openings
to many differents
-> > >> blades for
-> > >> one
-> > >> -> -> cut out
-> > >> -> -> Sean
-> > >> -> -> On 10/11/2007 4:39 AM,
walter.klatt@shaw.ca wrote to
-> > rebel-
=== message truncated ===
____________________________________________________________________________________
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more!
http://tv.yahoo.com/collections/3658
Robert Andrews
Post by Robert Andrews » Sun Feb 19, 2012 4:01 pm
Go to the builders website Files area. Check for the latest uploads
(defaults to last 7 days) ... and you'll see them.
Cheers, Bob
John W
Sent: Monday, October 15, 2007 8:43 AM
Subject: RE: RE: [rebel-builders] EliteProp&airfilter
Hey Bob and Sean
Tks
John W
Bob 612e
Robert Andrews
EliteProp&airfilter
Cheers, Bob 612e
EliteProp&airfilter
put the airbox in
without
cool
Sean
rebel-builders:
air
-> box?
-> Bob 612e
-> WALTER KLATT
EliteProp&airfilter
sell it.
-> Walter
EliteProp&airfilter
- are they the
-> > same?? Bob J
EliteProp&airfilter
-> > have one of
-> > > Walter
EliteProp&airfilter
-> > >> need a 2"
muff. Vans also
-> > >> includes a
as the normal setup
was held close by a
-> > >> magnet and
was found to open
door in its place.
in heavy snow or
just pull the carb
ground.
-> > >> Sean
wrote to rebel-
-> > builders:>>
is this separate?
-> > >> -> Walter
-> > >> Behalf
-> > >> Of
EliteProp&airfilter
a carb
-> > >> -> Sean
-> > rebel-
-> > >> builders:->
-> > >> -> -> Sean,
boxes for O-360's.
-> > >> you
EliteProp&airfilter
to many differents
-> > >> blades for
-> > >> one
-> > >> -> -> Sean
-> > rebel-
______________
and more!
