horn is the longer push pull. I also noted in my old manual (Rebel) that
MAM stated to cut the tubes 28" and 28 1/4"...when indeed the TUBE length
needed is 26 1/2" and 26 3/4".
Sent: Monday, January 23, 2006 10:39 PM
Subject: Re: Elite aileron settings
intoI'll check the "1/4" difference" tomorrow... if I remember... when I go
washersthe hangar to turn the compressor on.
Sent: Monday, January 23, 2006 10:33 PM
underWayne, thanks for the info.
Sent: Monday, January 23, 2006 7:10 PM
Mike...checked the "fleet". The Elite has 3 washers under left and 4right stick stop. One rebel has 4 under each side and mine has 5
aileronunder each side.
As for that push pull tube between the torque tube horn and the
6horn. The Elite is WAY longer than spec at 8 1/4". Me thinks I'll be
having
a good look at the "throws" before she flies out of here. Howards is
on5/8"
(center of rod end to center of rod end) and mine are 6 1/8"
As for the "equalizer" as you call it...tubes should not be bottoming
theto.it.
Space them out further with longer bolts and more washers if you needjustFront or rear..can't remember!
Sent: Monday, January 23, 2006 7:57 PM
fewinto
theitself.
angles
fromtotubesare
fronteach
when1/2"x
pushrodITeleflex
ailerontheaileronenoughor
seemedcoupling
positionwerethearmobtainedpushes
wingareOfmissing
couldneutraland
edge.gain
andWith don't
knowdown
me
adjusted?how
thesurgeryitto
down
full
linedseemsgoodto
out
[/quote]andofmake"rack"
[/quote]for
[/quote]to
[/quote]don't
[/quote]thathave
[/quote]thanksairplane
[/quote][/quote]On
[/quote]completed
[/quote]andto
[/quote][/quote]you
[/quote]should
[/quote]download
[/quote][/quote]horndoublerwhat
[/quote][/quote][/quote]tube
[/quote][/quote]On
[/quote][/quote][/quote]and
droop,40
[/quote][/quote]you'd
[/quote][/quote]yaw.
[/quote][/quote][/quote][/quote]Onceso
[/quote][/quote][/quote][/quote]upI
[/quote][/quote][/quote]locatedusername
[/quote][/quote][/quote][/quote]located--------------------------------------------------------------at:-----------------------------------------------------------------
[/quote][/quote][/quote]at:--------------------------------------------------------------------------------------------------------------------------------
[/quote]username-----------------------------------------------------------------
username----------------------------------------------------------------------------------------------------------------------------------
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------"rebel"
