[rebel-builders] 0-200 MOTOR MOUNT
Post by Walter Klatt » Sun Feb 19, 2012 5:02 pm
One thing that really helps is a fuel monitor, especially with a carbed
engine. With my previous 320 engine, I had to play around at different rpms
and power setting, depending on altitude, to find the sweet spot for maximum
efficiency. That would result in at least a .5 gph saving over the lean
until rough method. It cruised easily at 7 or 7.5 gph, even 5 if I was just
tooling around the lake, and sight seeing. This is on amphibs.
Then with my new 360 I was very pleasantly surprised to find that it was
even more economical than my 320, even though much more powerful. I save at
least .5 gph at the same speed, or get an extra 5 mph at the same fuel flow.
I have EI on one side, and that seems to really help lean it more
aggressively without running rough even with the carb. Also I have the
Superior sump intake which is supposed to be better at fuel distribution to
each cylinder. Again, this one cruises comfortably at 7 or 7.5, and just
goes a little faster at that fuel flow than before.
So I for one, don't always buy the argument that a bigger engine uses more
fuel. It depends also on whether it is EI and/or FI. And these old Lycosaur
design engines are a lot more fuel efficient than some people think.
Sent: November 14, 2008 11:10 AM
Subject: Re: [rebel-builders] 0-200 MOTOR MOUNT
I've heard guys say this many times and it is no doubt true in some
circumstances. The other side seems to be that the same guys rarely
seem to cruise at such low power. I think it is a combination of
roughness from one cylinder going lean first, plug fouling from low
temperatures, or maybe they just like to go fast?? My neighbor's 0-320
just won't run smoothly below 8+ gph. Anyway I wouldn't count on being
able to do it with a carb, standard intake system, and magnetos. I
believe that matched injectors, one or two electronic ignitions with
advance, and mogas will all help at low power.
Keith Leitch wrote:
Sorry, I don't mean to get off track on your post. If you have an
O-200 I can understand your question. But as far as the others, I
personnally don't see much sense in using the O-235/IO-240 unless you
have access to one for cheap. I have an O-235 L2C I had thought about
installing in my Rebel (whenever I get to that point) but after
looking at the weight vs. the O-320 it is sensless to me. May as well
use the O-320 and if you are worried about fuel....that little thing
called the throttle can easily be pulled back. I recently was on a 5+
hour tour with a bunch of Super Cubs and I was flying my O-300
powered 172. Flying at their speeds I burn a little over 5 gph. I
guess what I am trying to say is it is nice to have the HP when you
need it....just don't have to use it all the time if you are
concerned with fuel prices. I am waiting for Ron to get his Jabiru
powered Rebel flying so I can get a report. :) The power to weight
ratio may be an option for me since I will be on floats/skis the
majority of the time. Keith R661
Post by Drew Dalgleish » Sun Feb 19, 2012 5:02 pm
At 12:51 PM 11/14/2008 -0600, you wrote:
I realize that but just wondered what others were having to pay.
EJ
55K hull on wheels costs me $1500. 65K on amphibs is about $100 a month
extra.
At 08:56 AM 11/14/2008 -0600, you wrote:
Does the 0-235 L2C have enough power to get a Rebel off the water on 1800
amphibs. or is that asking to much of it?
Yes it does but on a hot day with glassy water you better be on a very long
lake. I know one builder in Thunder Bay that pulled an 0-235 on straight
floats just after the first flight. He replaced it with an 0-320. I used to
have an 0-290 in my plane and on amphibs it performed only slightly better
than a cessna 172. I changed to an ECI Titan 0-320, 160hp and haven't
regreted it at all.
I haven't had hull on mine for many years. I just go with the standard Copa
Silver Wings 2 million incl passenger liability for around 650 dollars,
which covers me for multiple airplanes too, as long as they have the same
number of seats. Last time I looked at hull, it was over 4000 per year on
mine (amphib). I figure the money I am saving every year would cover a
pretty good prang-up. If it was more serious than that, well, I might not be
worried about the money then.
Having said that, I did have hull when I first started (learning) to fly the
Rebel as a tail dragger. And sure enough, I did prang it up within a few
months with a bad landing, and busted a landing gear. After that, I dropped
full hull coverage, except for the 3 summer months when I first went to
floats. So if I count that first pay-out, I am still away ahead of the
insurance companies.
Dalgleish
Sent: November 14, 2008 9:25 PM
Subject: RE: [rebel-builders] 0-200 MOTOR MOUNT
EJ
extra.
Angus McKenzie
Post by Angus McKenzie » Sun Feb 19, 2012 5:02 pm
Like Drew, I too began with an 0-290-D from a Super Cub but R&Rd after 169TT
in favour of an 0-320-A2B from a Champ Challenger also installed the amphibs
then, now am at 430TT.
No regrets......Angus
Sent: Saturday, November 15, 2008 12:20 AM
long
regreted it at all.
