I just posted a pic of the way I fixed the wrinkle in the wheel well on my
1800 amphibs.
this puts any load on the skin directly to the bottom gear bolt.
sorry for the size I should have shrunk it.
Cecil
014R
Sent: Sunday, July 01, 2007 6:31 PM
Subject: RE: [rebel-builders] Doublers
haveAt 10:09 PM 6/30/2007 -0900, you wrote:Drew
The spring gear looks good. Did you do the same as Ken and Bob?. The
cracks are in the same place as mine. I don't have the crease that you
todayover?though. Are you going to fix them now or wait untill the flying season isMine is similar to what Ken described and the springs are the same as bothRay
Ken and Bob except I added a grease fitting. I installed the doublers
cracksabout a 3" x 4" triangle on both sides of each side skin. I'm hoping that
is enough to prevent further cracking. I think the proper fix would be to
remove the bottom rear skins and instal a patch that goes all the way to
the bulkhead. Also I think that maybe there should be some more structure
tieing the wheel well to the bulkhead right now it's just .020 angle plus
the bottom skin.
-> Just uploaded a pic of one of the cracks. The one on the other side is
-> about the same but out of 10 tries only one picture was any good. Also
put
-> up a pic of the die spring gear installed.
-> At 04:36 PM 6/26/2007 -0700, you wrote:
-> >Drew, I would be interested further to know exactly where these
toare,
-> >and what you think may have caused them. Any pics to post?
-> >Walter
-> >-----Original Message-----
-> >From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf
Of Drew
-> >Dalgleish
-> >Sent: Tuesday, June 26, 2007 3:51 PM
-> >To: rebel-builders@dcsol.com
-> >Subject: [rebel-builders] Doublers
-> >Hi guys I found a couple small wrinkles and cracks in my float
wheelwell.
-> >No leaks last year but I want to deal with this while I have the gear
apart
-> >to install die springs. My question is are rivets really neccessary
forbondget a-> >a doubler to the inside of the wheel well side skin. I would need tofairly-> >right angle drill if I wanted to get holes in there but it would be-> >easy to clamp it in place with some wedges. I think I'll use pro-seal
Drew-> >the bonding agent instead of sikaflex. Any comments?
-> >Drew
-> Drew
