[rebel-builders] Re: Inspection
michael betti
Post by michael betti » Sun Feb 19, 2012 12:08 pm
Glade to hear of your success!
Mike Betti
----Original Message----
Date: 06/03/2007 6:45
To: "rebel-builders@dcsol.com"<rebel-builders@dcsol.com>
Subj: Re: [rebel-builders] Re: Inspection
The test flight went pretty well, not as great as I would have liked
with a
couple of problems. It was a very hot and humid day (great to test the
limits) and unfortunately I did have a water over heating problem. Oil
CHT were fine. We have a couple of easy things to do which should
solve
that issue. Also two things with the prop - I have it pitched too
course and
we didn't get full RPM - I had pitched it to get 5200 RPM on the
ground,
thinking that when in motion it would raise the RPM up to the 5800 max
but
we found that we really only got about 5350 so I need to re-pitch, but
bigger issue is that on inspection after the flight Bob found a small
"bite"
out of the trailing side of one prop blades with what looks like a
little
de-lamination. I don't want to jump to conclusions until I get it off
send it to Warp but it will be a few days to get a new one so we can
continue the test flying.
Other than that - "Rebel 333 Did Fly Yesterday!!!!"
Jim 333R
On 6/2/2007 10:10 PM, "Bob Fisher" <rgfisher@zeuter.com> wrote:
hi jim and bob how did the test flight go today bob fisher
Sent: Thursday, May 31, 2007 9:14 PM
Subject: Re: [rebel-builders] Re: Inspection
hi jim hey it was too hazy today anyway 3 miles and 1500ft
no fun
really bob fisher
Sent: Thursday, May 31, 2007 7:05 AM
Thanks Ron, I will be happy to share once I have my first few
flights
under
my belt to make sure the cooling works and everything is fine.
(there will
be
something) I'm only waiting for the flight authority from Jamie
Alexander
who said "he would try and get to it this week"????
It's my understanding that in all other jurisdictions in Canada
that the
inspector that signs off on your final will give you the flight
authority
right then and there - not so in Ontario.(please correct me if I'm
wrong)
The paperwork has to go to the BOSS to check (why should that keep
me out
the air??) before he issues the flight authority. This is very
frustrating
especially after all the work to get it this far and of course
missing a
series of perfect flying days for the test flights.
Jim 333R
On 5/31/2007 2:48 AM, "rshannon@dcsol.com" <rshannon@dcsol.com>
wrote:
very
interested
along
gear or
steam
design/material,
in with
until
912 ULS.
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 12:08 pm
WAHOO! As you know, for those still building the most encouraging thing
is news of first flights like yours. Congratulations, and do keep us
posted on... everything!
Post by Walter Klatt » Sun Feb 19, 2012 12:08 pm
Congrats Jim, and good luck on getting your little run-in problems fixed
soon. Can't remember if you were one of the planned Ramblers, but if you
are, hope you can still make it. Hope to meet up with you guys when you make
it to the west coast.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jim
Cole
Sent: Sunday, June 03, 2007 4:46 AM
The test flight went pretty well, not as great as I would have liked with a
limits) and unfortunately I did have a water over heating problem. Oil and
CHT were fine. We have a couple of easy things to do which should solve
that issue. Also two things with the prop - I have it pitched too course and
we didn't get full RPM - I had pitched it to get 5200 RPM on the ground,
thinking that when in motion it would raise the RPM up to the 5800 max but
we found that we really only got about 5350 so I need to re-pitch, but the
bigger issue is that on inspection after the flight Bob found a small "bite"
out of the trailing side of one prop blades with what looks like a little
de-lamination. I don't want to jump to conclusions until I get it off and
Jim 333R
hi jim hey it was too hazy today anyway 3 miles and 1500ft no fun
really bob fisher
Thanks Ron, I will be happy to share once I have my first few flights
under
my belt to make sure the cooling works and everything is fine.(there
will
be
Alexander
It's my understanding that in all other jurisdictions in Canada that the
authority
wrong)
The paperwork has to go to the BOSS to check (why should that keep me
out
frustrating
especially after all the work to get it this far and of course missing a
Jim 333R
On 5/31/2007 2:48 AM, "rshannon@dcsol.com" <rshannon@dcsol.com> wrote:
interested
ULS.
