[rebel-builders] Rebel firewall
[rebel-builders] Rebel Firewall
Post by Drew Dalgleish » Sun Feb 19, 2012 11:56 am
Mine shipped with an aluminum firewall and a sheet of stainless to make an
overlay with so that's what I did. Other than estetics there's no reason
not to save a few bucks and use a thin sheet of galvanized steel for your
overlay.
At 09:34 AM 3/7/2007 -0600, you wrote:
Found another problem with finishing an old kit.
Went to install the firewall this week end and discovered that it is
aluminum.
Checked with Murphy and they confirmed that the old kits were shipped this
way. A new stainless steel firewall is $ 300.00
Anyone out there have a different solution. Possibly a stainless cover? if
so any suggestions as to thickness and type.
Brad (R-195)
Brad Hewlett
Saskatoon, SK
bhewlett@sasktel.net
Richard E. Swan
Post by Richard E. Swan » Sun Feb 19, 2012 11:56 am
I too have an older project I'm trying to salvage, and it has the AL
firewall. Can one overlay either stainless steel or galvanized over the AL
within the "inside" flat dimensions of the firewall, or does it need to
conform to the old firewall dimensions around the circumference with
radiused flanges, etc?
thanks.
Richard
Sent: Wednesday, March 07, 2007 6:51 PM
Subject: Re: [rebel-builders] Rebel Firewall
overlay.
aluminum.
Brad (R-195)
Brad Hewlett
Saskatoon, SK
mines just flat. I cut to fit just inside the flanges.
thanks.
Richard
overlay.
aluminum.
Brad (R-195)
Brad Hewlett
Saskatoon, SK
Richard E. Swan
Drew:
thanks for the reply; next question: if I just overlay, what thickness is
recommended? Logic would say that it wouldn't have to be very thick because
it is being added to aluminum already in place, and the aluminum in place
is/was good enough in many versions.
thanks; again!
Richard
Sent: Thursday, March 08, 2007 9:55 AM
AL
thanks.
Richard
an
your
overlay.
At 09:34 AM 3/7/2007 -0600, you wrote: Drew
Post by Ken » Sun Feb 19, 2012 11:56 am
Thin!
I believe I've seen .018" steel as minimum mentioned in the Canadian
rules somewhere but after you caulk the edges with fire resistant sealer
no one but you will ever know even if they bothered to wonder which is
very unlikely... I believe I used one size thicker than that simply
because it was easier to obtain locally.
Richard E. Swan wrote:
Drew:
thanks; again!
Richard
I think mines about .020 but if you can find thinner go for it.
At 10:21 PM 3/8/2007 -0600, you wrote:
Drew:
thanks; again!
Richard
AL
thanks.
Richard
Post by Bob Patterson » Sun Feb 19, 2012 11:35 pm
Hi Doug !
It's either a thin sheet of stainless, or galvanized ...
If you have an early kit, it might be aluminum, so needs
a stainless overlay - or FiberFrax ! ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
On Thursday 15 December 2011 08:38:22 Doug Farrow wrote:
Is the firewall that comes with the kit stainless steel ? ThanksDoug778R
Doug Farrow
Re/Max North Country
191 Haliburton Street
Haliburton, ON K0M 1S0
705-457-1011 Office
905-925-4972 Cell
John R. Davidson
Post by John R. Davidson » Sun Feb 19, 2012 11:35 pm
In terms of serial number, how would you define "early"?
John
Date: Thu, 15 Dec 2011 11:34:34 -0500
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
Doug Farrow
705-457-1011 Office
905-925-4972 Cell
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:35 pm
Doug's should be stainless and formed at Serial 778.
I got a formed stainless in 1994 to upgrade my #243.. some in those years /
early serial #'s only got a sheet of stainless to rivet overtop of the
aluminum one that was originally supplied.
From: "John R. Davidson" <skidaddy20000@hotmail.com>
To: "Rebel List" <rebel-builders@dcsol.com>
Sent: Thursday, December 15, 2011 11:57 AM
Subject: RE: [rebel-builders] Rebel Firewall
John
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
persons.
ThanksDoug778R
Doug Farrow
705-457-1011 Office
905-925-4972 Cell
Not sure, John ! I think, below #100 ..... although
I think some later ones have been reported...
Not necessarily a bad thing - aluminum + stainless
could be a bit stronger ... Aluminum + FiberFrax could be
a bit lighter and easier to work ....
Easy to test - just try to scratch or drill it ! ;-)
bobp@prosumers.ca
bobp@pattersys.com
John
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
persons. Any action taken as a result of the contents of this email is
totally the responsibility of the reader.
ThanksDoug778R
Doug Farrow
705-457-1011 Office
905-925-4972 Cell
They were shipped with aluminum up until #243 for sure... and then the
fight began! lol
Sent: Thursday, December 15, 2011 12:34 PM
bobp@prosumers.ca
bobp@pattersys.com
persons.
John
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
sender
is
Curt Langholz
Post by Curt Langholz » Sun Feb 19, 2012 11:35 pm
Mine has aluminum 175R.
Sent from my Windows Phone
bobp@prosumers.ca
bobp@pattersys.com
andrew Byers
Post by andrew Byers » Sun Feb 19, 2012 11:35 pm
Mine is stainless
Andrew 779R
Subject: [rebel-builders] Rebel Firewall
Date: Thu, 15 Dec 2011 08:38:22 -0500
Doug Farrow
705-457-1011 Office
905-925-4972 Cell
craig
Post by craig » Sun Feb 19, 2012 11:35 pm
My kit, #207 came with a sheet of SS which had to be cut to size. Craig
G. O'Shea
Sent: Thursday, December 15, 2011 8:26 AM
John
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
persons.
ThanksDoug778R
Doug Farrow
705-457-1011 Office
905-925-4972 Cell
ray
Post by ray » Sun Feb 19, 2012 11:35 pm
My good friend has an elite and I,m sure his firewall is aluminum as is my
rebel. I should have got to 4 before now but haven,t. I've read tony
bingalis and others and 'know' that its steel or stainless on a firewall for
protection. Now it looks like a cookie cutter operation coming to the
arlington hanger this winter. I have looked at my firewall 100 times and
seen bare aluminum and just tonight the lights came on. Sure glad this plane
is so good as an airplane to make up for some of these shortcomings that pop
up.The 4 is a 2 plus 2 operation in case I wasn,t clear. How stupid does
intumesent paint sound? My firewall is loaded and it one of those hard to
get to places on the plane that is all work and small reward. I,m whining
now so I have to go. Ray
Sent: Thursday, December 15, 2011 11:21 PM
G. O'Shea
John
Hi Doug !
bobp@prosumers.ca
bobp@pattersys.com
persons.
Email scanned by PC Tools - No viruses or spyware found.
(Email Guard: 7.0.0.26, Virus/Spyware Database: 6.18900)
http://www.pctools.com/
