Epoxy Chromate Primers
Rebflyer
Post by Rebflyer » Fri Feb 17, 2012 5:40 pm
Hi Wayne, I've got a couple of questions on the amphib floats if you can find
the time. I guess Bobs jokes were just to good to share with us all.
Anyway, I'm using the Lake and Air pump outs and I was curious if
you had downsized the the tubing. I seems that 5/8 id all the way is pretty
large and I might not get a good pull with the syphon. Make sense? The next
question is a little more complicated in the decription. MAM has you drill
and tap 2 #10 holes in the lower front of the nose gear retract brackets.
Well, in laying out the proper angles for square to the surface in two
directions it seemed that this would put the holes really close to the inner
opening for the guides, possibly taking some strength from a critical area.
In trying to keep the two screws and moving them around, 2 just seemed 2
many., I think I"ll just use one, any comments?
I appreciate the help, N97MR, Curt
