Thanks for the pictures they sure steered me on to right track and enabled
me to make it work
Ralph 657E
Andrews
Sent: Sunday, December 04, 2005 9:31 AM
Subject: RE: Elite cable routing
Mike, Ralph,
Uploaded a few pics into "E-Rudder" showing where the boot is w/r to the
side skin. The inside view picture shows the cut-out notch w/r/t the boot
rivets. 612e flew for 40+ hrs and I've found nothing in the logs to
indicate there is any problems associated with the rudder or rudder cables.
Hope this helps.
Mike - think I blew a pic into section 101 by mistake ... sorry.
Cheers, Bob 612e
Mike Betti
Sent: Saturday, December 03, 2005 5:51 PM
Subject: Re: Elite cable routing
Ralph,
How did you make out cutting the slot for the rudder cables with Jeffreys
advice? I'm getting ready to do the same and it looks like a crap shoot to
me. Also, to the other builders, where do I mount the rudder cable guides?
At the bulkheads? Just above the corner wraps?
Mike Betti
771E
I have come across two cable issues on my Elite; the first one involves
routing the elevator trim wiring cable from the elevator through the
stab.
My first try was to run it inside the rounded portion of the skin inside
a nylon tube and exit beside the center hinges and then just drop it into
the fuse. This didn't work well as the nylon tubing got all crushed with
the action of the hinges. My next thought is to drill and grommet a hole
out of the front of the enclosure for the servo and then cut an upright
slot
into the rounded leading edge and find an oblong grommet to protect the
cable and then drill a matching round hole with a grommet into the
trailing
edge of the stab (I am not wild about this idea because of cutting the
slot
into the rounded leading edge and what it may do to the air flow). I
have
really hit a road block on this one; maybe I am missing the obvious.
My second cable problem involves the exit point in the fuselage for the
rudder cables. Does anyone have measurements for the position and length
these openings or a good method for determining their locations? I am
afraid to start cutting this opening as I don't want to make it too long
or
have it in the wrong place and then have to do a patch job.
I would appreciate any help.
Ralph Knight E657
