Float pumps
Float pumps
Post by Mike Davis » Sat Feb 18, 2012 10:06 am
I guess the flow rate is pretty low if you're trying to move a lot of
fuel... here is a page that has one rated at 40 gph.
http://www.gowerlee.dircon.co.uk/Facetpump.html
Something like this drill powered pump might be better for filling your fuel
tank... 225 gph.
http://www.sears.com/sr/javasr/product. ... 8302660000
Sent: Tuesday, February 01, 2005 12:11 PM
Subject: Re: Float pumps
No, but it's a thought. The ones I know are about 30 gph which would take
about 15 minutes per gas can, so probably not fast enough for what I would
want. I think my hand pump is faster than that. I have not looked for an
electric one yet, but maybe there are some, at a reasonable cost that
would work.
Date: Tuesday, February 1, 2005 11:16 am
Sorry, not for gasoline... big warning on the package. Have you
looked at a
12v faucett pump?
195SR
On 2/1/2005 10:00 AM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE DAVIS:
-> Can this pump be used to pump gasoline? When I am out at the
lake in the
summer, I usually have 5 or 6 cans of gas on hand for the boats,
or my plane
if I have been giving too many rides. But to get fuel into the
wing of a
docked floatplane isn't always that easy. What I use today is a
little hand
pump that goes into my gas can on the dock, and pushes the fuel up
to the
wing. It works, but is slow and cumbersome. If there is a cheap
electrical
one, I might be interested.
-> For the float compartments, I just use a small lightweight hand
pump that
works fine for me. Two quick pumps on each hole just to ensure no
leaks, is
all that I need, usually. An electrical one wouldn't help me
there. I
sometimes get a few cupfuls out of the front compartments after
being in
rough water, as I still haven't sealed off my front wheel well
hydraulic hose
grommets, but that's it.
-> Walter
-> From: mike.davis@dcsol.com
-> Date: Tuesday, February 1, 2005 10:36 am
-> Subject: Re: Float pumps
-> > I just ran into a light weight portable item that might be
-> > suitable as a
-> > float pump. I bought a battery powered kerosene pump for
$10.
-> > It's long and
-> > skinny, designed to fit through the opening of a 5 gal can of
-> > kerosene and
-> > reach the bottom. Not terribly fast, probably a couple of
gallons
-> > a minute.
-> > I can take a pic if anyones interested.
-> > Mike
-> > On 2/1/2005 5:30 PM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE
DAVIS:-> >
-> > -> the pump that works best for me was a shop vac. If you
have the
-> > power there
-> > -> for the drill anyway. my shop vac has the drain in the
bottom
-> > so I don't
-> > -> even have to dump it out,
-> > -> it will suck 10 gal. of water in 25 seconds. It's great
for
-> > getting the
-> > -> sand and dirt out of the inside too.
-> > -> Cecil
-> > -> 014R
-> > -> ----- Original Message -----
-> > -> From: "Ryan Mowat" <RMowat@forge-industrial.com>
-> > -> To: <rebel-builders@dcsol.com>
-> > -> Sent: Thursday, January 27, 2005 3:07 PM
-> > -> Subject: Float pumps
-> > -> > Does any one have a good lead on a drill attachment for
-> > float pump?
-> > -> > I'd like to find a motorized version of this plastic
work
-> > horse that is
-> > -> > wearing me out. It is only a problem if I leave the
plane in
-> > the lake
-> > -> > for a few days - but it sure would be nice to have a
faster
-> > easier-> > system
-> > -> > Ryan Mowat
-> > -> > List archives located at:
https://www.dcsol.com/login?mode=HTML-> > -> > username "rebel"
password "builder"
-> > -> > Subscription services located at:
-> > -> > https://www.dcsol.com/public/code/html-subscribe.htm
-> > -> > List administrator: mike.davis@dcsol.com
-> > -> List archives located at:
https://www.dcsol.com/login?mode=HTML-> > -> username "rebel"
password "builder"
-> > -> Subscription services located at:
-> > -> https://www.dcsol.com/public/code/html-subscribe.htm
-> > -> List administrator: mike.davis@dcsol.com
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
-> List archives located at: https://www.dcsol.com/login?mode=HTML
LisaFly99
Float pumps
Post by LisaFly99 » Sat Feb 18, 2012 10:06 am
In a message dated 2/1/2005 3:22:13 PM Central Standard Time,
mike.davis@dcsol.com writes:
tank... 225 gph.
http://www.sears.com/sr/javasr/product. ... l=LAWN&pid
=08302660000
MIKE
That's a great pump for water or diesel fuel, but there aint no way I'd
think about pumping gas with one. I have two of them one for diesel and one for
water. I've burnt up three $16 through away electric drill motors with them,
and they just keep pumping. I've never used a cordless drill on one to see what
the battery life would be. Supose I could just to see.
PDSmith
bosdes
Float pumps
Post by bosdes » Sat Feb 18, 2012 10:06 am
Northerntool.com has a number of manual and 12V gasoline transfer pumps. I use a Fillrite pump to refuel the Champ from a transfer tank on the pickup truck, bought it used and have had no trouble with it. Ted 577E
-------------- Original message from WALTER KLATT <Walter.Klatt@shaw.ca>: --------------
No, but it's a thought. The ones I know are about 30 gph which would take about
15 minutes per gas can, so probably not fast enough for what I would want. I
think my hand pump is faster than that. I have not looked for an electric one
yet, but maybe there are some, at a reasonable cost that would work.
looked at a
12v faucett pump?
195SR
lake in the
or my plane
wing of a
little hand
to the
electrical
pump that
leaks, is
there. I
being in
hydraulic hose
-> Walter
-> > suitable as a
$10.
-> > It's long and
-> > kerosene and
gallons
-> > a minute.
-> > Mike
DAVIS:-> >
have the
-> > power there
bottom
-> > so I don't
for
-> > getting the
-> > -> Cecil
-> > -> 014R
-> > -> To:
-> > float pump?
work
-> > horse that is
plane in
-> > the lake
faster
password "builder"
password "builder"
