Dale
Sent: Monday, January 17, 2005 9:18 PM
Subject: Re: wiring...
LOTHi Dale,
Moose 096 had an orange colored plastic tube in each fast build wing.
Dick Shotwell
Moose 096
N235DS
Twin Falls, ID
Sent: Monday, January 17, 2005 18:53 PM
Does anyone know is there supposed to be conduit on the fast build Moose
wings for the wiring??? I have e-mailed Murphy several times no answer.
Dale (moose 033SR)
Sent: Monday, January 17, 2005 3:20 PM
Hi Jean !
If you run the wires up the wing strut, they can then go behind
the spar from there to the wing tip - you are past the fuel tank at
that point.
It's best to run the wires down the strut (with quick-disconnects
at both ends) along with the pitot lines, because they then come into
the cockpit down at the bottom, in front of the cage tubes. It's a
aidea....wires.....easier to run them from there up behind the panel, than trying to
thread them along the wing root, around the cage, and down !!
I've used the clear plastic tubing like the fuel guages (Canadian
Tire) - it's flexible, so easy to thread in, and you can see thebehindhope it isn't PVC ! :-)
.............bobp
On Monday 17 January 2005 09:19 am, Jean Poirier wrote:
otherlater
all
flexible
mightwing -
haveforlights.
Ido
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.13 - Release Date: 1/16/05
No virus found in this outgoing message.
