Empty weight for 1800 amphibs
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 9:00 am
Well, maybe I should weigh 25 or 30 lb. more but that still puts me in at
1220 lb.(1189 + 30). I plane on weighing it again with a different scale anyway.
Bruce
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:00 am
Sounds like a plan.....with the cabin floor level this time :o)!
When you're all done... a "paper weight" under 1200lb would be wise for the
impending "ramp check"!
Sent: Tuesday, February 24, 2004 10:34 PM
Subject: Re: Empty weight for 1800 amphibs
anyway.
Bruce
Post by Drew Dalgleish » Sat Feb 18, 2012 9:00 am
At 06:01 PM 2/24/2004 -0800, you wrote:
Wow, that is very good, Drew. I thought your engine weighed about
the same as the 0320's. What were you on wheels?
Origionally on wheels was 850lbs. but I'm sure it's gained weight since
then. The 0-290 is suposed to weigh a little bit more than an 0-320
depending on the model and which book you look in. >
Legeorgen
The scales I used look like bathroom scales but are supposed to be for
aircraft with multiplying arms. I calibrated them to my usual weight but my bath
scale and my mother in laws are 8 lb. different.
With a 4 times multiplying arm on the scale, if my weight is even 4 lb. off X
4 X four wheels, that's a 64 lb. error not even counting any error the scales
themselves may have.
I will weight it again as I'm sure now the 1265 lb. I weighed the first time
has to be wrong.
Bruce
Post by Bob Patterson » Sat Feb 18, 2012 9:00 am
Hi Bob !
The factory ads say to expect a net increase of approx. 253 lb.
for the 1800 amphibs - but the max. gross does go up to 1,730 lb.
Still, a smaller useful load, but MUCH more than most aircraft
on floats (Old saying - "Nobody ever flies AT gross on floats !" ;-) )
You will have a ball, though !! :-)
On Tuesday 24 February 2004 06:26 pm, you wrote:
this is not good news! i`ve been counting on a net increase of 230 lbs
when i mount the floats that should have put rebel 342 at 1204 lbs
i guess we`ll have to do the battery and the flyweight starter trick
bob fisher nobel ontario
Sent: Tuesday, February 24, 2004 2:14 AM
Walter, Wayne, Curt. Bobp and all you other amphib drivers out there,
I wanted to know what your planes empty weights came in at with the 1800
amphibs. I weighed mine today at 1265 lb. I thought that was a bit heavy.
That's
an increase of almost 300 lb. (my wheeled empty weight was 975) and that's
after removing the heavy spring gear.
The Manual said the empty C of G would not change but mine moved back
almost
two inches from 9.95 to 11.75. I don't mined the CG change, just wanted to
know if others had similar experience.
This only leaves me with a 475 lb. useful load. I was hoping for a bit
more
so I could carry two of use and at least a 100 lb. of gear with more than
6
gallons of fuel and still have insurance!
The leaky front cylinder stopped leaking on its own...now that it has
warmed
up above 28*F (and MAM is sending me a new rebuild kit). The muscle needed
pump the gear up and down has become much better too. Amazing what a
difference a few degrees make.
Bruce G
Post by Walter Klatt » Sat Feb 18, 2012 9:00 am
When I went to amphibs with mine I weighed my two bungee gear,
wheels and all, along with the tail wheel and the whole works
came out to 50 pounds. I believe the spring gear is 25 pounds
heavier, and more if using a non-MAM tail wheel.
I recall seeing an earlier weight on the 1800's at 224 net
increase, but it didn't say what gear. In any case, I personally
wouldn't bet that Murphy really has a good handle on this either.
There does appear to be 2 different skin sizes for the 1800's, so
that would certainly account for different weights by builders.
There is also probably a lot of builder weighing errors and the
use of "accounting" scales.
As an aside, I recently helped a local Elite builder do his
weight and balance, and it came in at 1120, and that is with an
0360.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Wednesday, February 25, 2004 7:46 PM
Hi Bruce !
As far as I know, the Murphy brochure WAS based on a
standard-gear
Rebel, so you're right - a smaller weight increase !
Although, the
spring gear Rebel would be likely about 20 lb. heavier
to start with,
than a standard gear, because of all those
doubler/trippler/octupler (!)
plates ... ;-) :-)
Just curious - how much do just the gear legs alone weigh ??
Axles, wheels, & tires would be the same on both
gears, so the legs
would be the only difference. Anybody know what just
the standard
gear legs weigh ?? I bet there's not a lot of
difference, if you
count in the center tubes & the bungees (or die springs) ....
suspect most of the weight increase is in the fuse beef-ups.
I <LOVE> Warren's answer !!! :-) Get a good accountant
(maybe ex-Enron ??) to find you a set of scales that give you
the answer you want !! ;-) :-) :-)
On Wednesday 25 February 2004 08:14 pm, you wrote:
Bobp
Is that a net 253 LB. Increase for a standard gear
Rebel? Because if it is,
that would mean a spring gear Rebel should have a
smaller net increase as
he is
removing gear that weighs more than the stock gear
and then adding back the
same in floats.
Bruce
Not really sure what other Elites are coming in at, but the
interior and accessories were not excessive on this one.
Legeorgen@aol.com
Sent: Wednesday, February 25, 2004 8:44 PM
I knew the Elites were heavier but 1120 LB. Wow!
That's a lot of extra weight
for only 20 more HP to pull around. Was that a heavy
Elite or is that typical?
Bruce
Legeorgen
Bobp
Is that a net 253 LB. Increase for a standard gear Rebel? Because if it is,
that would mean a spring gear Rebel should have a smaller net increase as he is
removing gear that weighs more than the stock gear and then adding back the
same in floats.
Bruce
Hi Bruce !
As far as I know, the Murphy brochure WAS based on a standard-gear
Rebel, so you're right - a smaller weight increase ! Although, the
spring gear Rebel would be likely about 20 lb. heavier to start with,
than a standard gear, because of all those doubler/trippler/octupler (!)
plates ... ;-) :-)
Axles, wheels, & tires would be the same on both gears, so the legs
would be the only difference. Anybody know what just the standard
gear legs weigh ?? I bet there's not a lot of difference, if you
Bobp
he is
same in floats.
Bruce
Legeorgen
Yea, I had a laugh when I read that too..."get a good accountant." Well, I
think I have a good one now! He told me my Rebel weighs 1189 LB. no matter what
the scale said. At least that's what I'm going to say on paper.
I'll weigh the spring gear and wheels/tires this weekend and report back to
the list.
Bruce
I do my own company books as well Bruce! :o))
Sent: Wednesday, February 25, 2004 11:39 PM
what
the list.
Bruce
Legeorgen
I knew the Elites were heavier but 1120 LB. Wow! That's a lot of extra weight
for only 20 more HP to pull around. Was that a heavy Elite or is that typical?
Bruce
Warren Montgomery
Post by Warren Montgomery » Sat Feb 18, 2012 9:00 am
Any good accountant could find scales to get you the weights you need ;-)
Warren
anyway.
Bruce
Angus McKenzie
Post by Angus McKenzie » Sat Feb 18, 2012 9:00 am
We are just ready to bring the front end loader into the hanger and push the
floats under the Rebel,just kidding but we are using the loader to lift the
plane.These are a set of MAM's earliest amphib kits and were built by Carm
Titus and used by him for about three years, they weigh 301#s.Yesterday I
completed the new 3.5"dia.x7"high cylindrical aluminum oil tank and it's
mounting pedestal which is affixed to the rear of the pump pedestal between
the seats,also determined to mount the selector switch and pressure gauge
under the dash on the extreme left side.Perhaps we will do pictures to post.
In case anyone is interested Clamar floats offer a Parker pump/selector
valve assy. which is quite small,maybe 3"square and 5high with a socket for
a detachable handle,it is really neat and would consolidate the two
functions, it is also a lot of money.
I have faired bungee gear,12-9044 loops with MAM wheels 8:50x6 McCreary's
and a Scott 3200,steel spring. When we weigh all of this stuff I will
report.
A local scale company is available with certified digital platform scales of
varying capacities which they deliver and operate and provide a federally
certified endorsed print out of the weight.
Another local aerial spray company has really cool and very expensive low
profile inter-connected digital platform scales to do their M-18 Dromaders
but they are more expensive to obtain the use of.
Regards, Angus
Hi Bruce !
plates ... ;-) :-)
Bobp
is,
as
he is
same in floats.
Bruce
N.Smith
Post by N.Smith » Sat Feb 18, 2012 9:00 am
Hi Walter
Was this Dennis's Elite we looked at back in August, and still on wheels ?.
Sounds like he's not too far off being finished now. All the photo's I took
of his and yours have proved a godsend as I work through mine.
I'm also interested where he ended up putting his battery for trim ?
I'm still working around the cabin roof fitting . Wings and outstanding bits
from MAM should be here in May sometime.
Nigel
745E
Sent: 26 February 2004 04:10
Subject: RE: Empty weight for 1800 amphibs
0360.
Patterson
Hi Bruce !
standard-gear
Although, the
to start with,
plates ... ;-) :-)
gears, so the legs
the standard
difference, if you
Bobp
he is
same in floats.
Bruce
