Steve,
Do you have one or two heat muffs on your exhaust?
Bruce G
Mounting 1800 Floats
Hi Steve
Could u tell me what u are using for a prop and what u think of it so far?
Steve W Rebel 637
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/phot ... et%3den-ca
Steve W Rebel 637
_________________________________________________________________From: SWSLOANLK@aol.com
Subject: Re: Mounting 1800 Floats
Date: Wed, 7 Jan 2004 19:27:28 EST
Bruce!
These test's covered a number of small item's to update & complete the
seaplane supplement to my pilot operation's hand book along with two major
item's
the oil cooler and the propeller pitch control motor operation's at very
low
temp's
As for the cabin temp, it was just fine ( about +10 deg C ) except for the
frost forming on the inside of the cabin windows.
Steve S
Steve W
I am using a Hartzell HC-C2YF-1BF propeller with 7663-4 blades. This is a 72"
dia two blade SQ tip variable pitch unit with the low pitch stop set to
allow the engine to reach it's 2800 rpm red line at takeoff.
I am very happy with the performance this propeller provides.
Steve S
Steve S
Bruce!
I am using a 4to1 exhaust system into a central 6" by 18" long muffler. The
whole muffler is wraped with a heat shroud and is ducted direct to the cabin.
There is no carb heat!
Steve S
Steve S
hi steve is that system stainless? who built it? how much did it cost?
can it be used with out muffler or how much difference does the muffler
make in the noise level do you have the speed cowling? thanks bob
fisher
Sent: Friday, January 09, 2004 7:07 PM
fisher
TheBruce!
cabin.whole muffler is wraped with a heat shroud and is ducted direct to the
*-------------------------------------------------------------------------*There is no carb heat!
Steve S
Bob, Steve's running an IO-240 Continental just to be different ) (and
having a ball with it! from what we can tell!!)
Sent: Friday, January 09, 2004 7:13 PM
cost?hi steve is that system stainless? who built it? how much did it
*-------------------------------------------------------------------------*can it be used with out muffler or how much difference does the muffler
fisher
TheBruce!
I am using a 4to1 exhaust system into a central 6" by 18" long muffler.cabin.whole muffler is wraped with a heat shroud and is ducted direct to theThere is no carb heat!
Steve S
hi wayne question where is the best place to get 1) a light weight
starter used or new
2) an exhaust gas temperature system not fancy just basic i just want
to be able to lean the mixture properly on the 0-320
thanks fish
starter used or new
thanks fish
muffler.Bob, Steve's running an IO-240 Continental just to be different ) (and
cost?hi steve is that system stainless? who built it? how much did itcan it be used with out muffler or how much difference does the muffler
fisher
Bruce!
*-------------------------------------------------------------------------*Thecabin.whole muffler is wraped with a heat shroud and is ducted direct to theThere is no carb heat!
Steve S
