Slop in flapperons
drew
Slop in flapperons
Post by drew » Fri Feb 17, 2012 11:54 pm
Hi Bruce I've the factory recommended setup on my rebel and I think I'm
getting about 10 or 12 degrees up. It's an extra 2to5 mph. when I have them
reflexed. I don't think I have much play in the mixer but there's lots of
play in the teleflex cable, the clevis pins at each end and in the flap
handle mechanism itself. I think there must be less of an air load on the
flaperons when they're reflexed than there is when they're down because even
with twice as many notches down I get the same amount of movement as up.
This is one of the areas I'd like to improve on my plane.
Sent: Sunday, October 19, 2003 12:43 PM
Subject: Re: Slop in flapperons
Thanks Wayne,
I may have to get your 5/16" bearing for the mixer. I'll examine my
control
set up again, armed with this new information and get back to the list. I
believe there is a few things I can do to take up some of the slop.
I would like to hear from other Rebels, with the factory set up, on just
how
many degrees of deflection is lost in cruise. This will give me something
compare to. Thanks
Bruce
drew
Slop in flapperons
Drew,
Does your Rebel keep the 10 to 12* deflection in flight?
Bruce
In flight I can see the trailing edge of the flaperon about 1 1/2" above the
trailing edge of the wingtip. I'll make a mental note of the position next
time I'm flying and check the deflection with my handy little angle finder.
It may take a while though I'm switching from floats back to wheels and
building skiis. I was thinking after I wrote last time and probably the
teleflex works better in tension than it does in compression.
klehman
Slop in flapperons
Post by klehman » Fri Feb 17, 2012 11:57 pm
I am under the impression that a heavier teleflex won't really help
because there isn't really any significant stretching or compressing of
the cable or sheath. There is freeplay between the inner and outer
pieces of course and I did look closely at using two teleflex cables to
eliminate that but it got a bit complicated and a bit heavy so I put it
on hold until after I get flying. IIRC, it was challenging even finding
a source for a teleflex as heavy as MAM ships. Most had lighter inner
cables.
drew wrote:
Drew,
I can tell you that 1 1/2" of space visible between trailing edges is
about 4
or 5*. That's slightly more than what I see on mine (about an 1 1/4") and
I've already measured the angle.
Bruce
OK Thanks Bruce It sounds like I might benifit from some more up reflex as
well. I'm going to check some industrial and marine suppliers to see if
theres a heavier teleflex cable available. I'd prefer to not go with an
electric actuator but that might be the simplest solution
drew
Slop in flapperons
Post by drew » Fri Feb 17, 2012 11:57 pm
Drew,
about 4
Bruce
Rick Harper
Slop in flapperons
Post by Rick Harper » Fri Feb 17, 2012 11:57 pm
G'day from Down Under Bruce ...
541R looses HEAPS of angle with the flex in the cable & rocking of the
mixer arm in flight ...
On the ground I get 6, 12 & 18 (I only use 18 in extreme short field spots,
... and I only deploy it at 40 knots or less ... really pulls her up at the
last second !) ... but the angles in flight are FAR LESS than what I get in
flight .... So I just purchased one of Vans Aircrafts' electric flap
actuators to replace the whole telecable, lever etc .... Should get rid of
heaps of the flex !
(and it has a "D-dent shaft" which you can modify to give the angles
(multiple) of deflection you require) ... so you can program into it the
reflex position as well !
I hope to have her back in the air in a month or so (still finishing off the
IO-320 installation) ... I'll let you all know how it goes then .
Rick & Wendy Harper
16 Tor Road
Dee Why
NSW 2099
Australia
Home (02) 9971 7889
Mobile 0416 041 007
Legeorgen@aol.com
Sent: Monday, 20 October 2003 2:44 AM
Thanks Wayne,
I may have to get your 5/16" bearing for the mixer. I'll examine my control
I would like to hear from other Rebels, with the factory set up, on just how
many degrees of deflection is lost in cruise. This will give me something to
compare to. Thanks
Bruce
