probably keep them on the interior side? If someone comes up with a good
pt.no. of one please share.
Mike Betti
771E
Sent: Sunday, September 11, 2005 9:41 AM
Subject: RE: Inspection holes
Mike,
When I bought 612e, the flap handle was a rooftop installation ... and
there
was some electrical wiring routed under the floor. During the tear down,
removed all the rooftop flap handle stuff. In the rebuild, the flap
handle
is going on the floor with the hyd hand pump (and handle) for the floats
right next to it. The ONLY thing planned to go under the floor is the
flap
control cable run from the flap handle aft to a pulley, then up behind the
aft cabin area bulkhead, and then forward to a steel tube that connects
both
flaps. Plan to route all wiring and float related hyd and elect lines on
the floor surface or sides. Currently thinking about running them along
(and on top of) the floor side wraps on the passenger side with a 0.020
sqr
tunnel cover screwed to the floor to cover them. Although I haven't given
it much thought (currently finishing up the bottom side wraps at the
firewall), think inspection holes (and covers) will need to go in the
floor
for inspecting both the flap cable and for corrosion. Was thinking the
same
size holes as the ones on the bottoms of the control surfaces for
inspecting
the flap control cable areas. Your little holes sound like a good idea
a simple snap-in hole cap might answer the mail.
Bob 612e
Mike Betti
Sent: Saturday, September 10, 2005 3:04 PM
Subject: Inspection holes
Hi builders,
I plan on not hidding anything under the floor of my Elite. All
plumbing, wiring done on the surface. I need some way of inspecting the
floor area between the outer skin and inner floor. I was thinking of
drilling a say .5" hole in the outer floor skin between every bulkhead.
Then I can use my borescope for inspections as needed. I would need to
come up with some sort of way to plug the holes which I haven't come up
with yet. Any discusion on this idea is welcome?
I haven't seen any feed back on the flap handle mounting in the rooftop
I inquired on last week. Anyway, Nigel, it looks like the handle
assembly isn't going to come out too easily for service and drilling out
of a couple rivets is going to be the least of it. So I am opting for
only boring the round holes and not notching out as instructed.
Mike Betti
771E
