Rebel on floats
Brian Lawson
Rebel on Floats
Post by Brian Lawson » Fri Feb 17, 2012 10:52 pm
Hey Blondie, err Bob,
I can get you are REAL deal on a chain-saw! Or maybe with your
ingenuity you could make it "squat to P", where P is for Park. Lift
the nose to push-pull from the hangar.
I was hoping Curt would jump in here for you, but maybe he left for
Sun N Fun already. He likes to go early if Dave Fife is going too!
<VBG>
Take care.
Brian Lawson,
Windsor, Ontario.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
On Thu, 20 Mar 2003 21:05:25 -0500, you wrote:
I was trying to search the "archives" for Info on Rebel on floats, but I
can
not seem to get it to work. Maybe I am having a "blonde" moment. What I
need
to know is height over fin when mounted on 1800 amphibs.-When sitting
on
the ground that is. Can anybody answer this as I need to check my hanger
clearance. Thanks much.-Bob Rebel "652"
Rebel on Floats
Post by Drew Dalgleish » Fri Feb 17, 2012 10:53 pm
What is the advantage of shortening your float struts? Is there any
disadvantage? I'm just getting ready to instal my floats.
can
need
on
Hello Brian:
I have uploaded a Rebel side view line drawing with mention of dimensions on
amphib floats to the group. I received this from MAM on July 28 2000. If you
wish to take a peek, look under 36-R Miscellaneous -
"dimensionswithfloats.jpeg".
With conversations with Steve Sloan concerning reducing the length of the
struts, mine may end up being about 3 inches lower.
For what it is worth.
Have fun! Good Luck!
Your Pilot Pal,
Terry Dazey
Rebel 662
Robert and Olga Johnson
Rebel on Floats
Post by Robert and Olga Johnson » Fri Feb 17, 2012 10:53 pm
That "squat to "p"(park) sounds like an interesting idea Brian. What if the
rear float legs where like screw jacks--you could even vary the angle of
attack for take-off, landing and cruise---hummm this is going to take some
thought. Its a good thing we are leaving for Cuba tomorrow-give me time to
think. (and maybe get back to reality) Bob J Rebel "652"
Rebel on Floats
Post by Bob Patterson » Fri Feb 17, 2012 10:53 pm
Geeez, Bob, you don't have to be that 'high tech' !! ;-)
Just yank down on the tail spring when pulling it into
the hangar - no problem to lift the front wheels & lower the tail !
From what I recall, my Rebel was only 9 feet to the top of the fin ...
If you don't want to pull the tail down, you could just
position a couple of ramps to lift the nosewheels at the correct
place in front of the hangar ....
Hope you have a good holiday !!
-----------------------------orig.----------------------------------
Rebel on Floats
Post by Walter Klatt » Fri Feb 17, 2012 10:53 pm
Haven't seen anyone reply to this yet, so will offer my
understanding and opinion.
Pros on shorter float struts:
- Fit into hangar better.
- May allow easier lift off on water with one wing and
float raised first, due to narrower stance.
- Less drag and weight, so speed should be better.
Cons on shorter float struts and resulting narrower
stance:
- Prop is closer to water, so may get more erosion.
- Narrower stance can cause more instability in high
winds and waves.
- You'll have to duck a little more when walking under
the wing at a dock... ;>)
Steve Sloan is the guy who has this set-up, and can
provide first hand experience.
On the lifting of one float first, one of the local
guys building floats here wanted to go fly with me to
test how easily the Rebel lifted off the water with one
float. He had also heard about this, and wanted to see
how mine worked. We loaded her up to "full load plus"
and tried it on glassy water. I had no trouble lifting
it off with one float and wing first, and even tried it
at lower power setting take-offs, and it still worked
fine. Of course, it may still work even better with
shorter struts, but that was my experience.
Sent: Friday, March 21, 2003 3:39 PM
Subject: Re: Rebel on Floats
instal my floats.
can
need
on
Hello Brian:
Your Pilot Pal,
Terry Dazey
Rebel 662
Archives located at
Archives located at
Rebel on Floats
No, I normally take off with both floats at a time. I
have never had a situation where I needed to raise one
float first. When testing that capability, I had to be
quick, or it would get off before I had a chance to
lift one. That's why I had to power it back to
experiment better with that method.
I don't think you can compare the Rebel take-off to any
Cessna. I was out a few weeks ago solo (loaded to
around 1650 pounds) and took 10 seconds to lift off in
a very light wind (light ripple on the water). Takeoff
times really increase as you load it up, but even then
25 seconds is usually the max when full loaded, unless
you screw up on your sweet spot.
I know in strong winds, I have done better than 10
seconds when solo, but it is hard to get an accurate
timing when you are by yourself. Everything happens
pretty fast then, and you can't be just looking at your
watch while taking off.
Some time in the summer, I'll get my wife or someone to
video tape me during some higher wind take-offs, and
will get some accurate timings. My bet is that it will
be no more than 8 seconds, maybe even 7 or 6. I do
remember sometimes getting airborne almost immediately
after getting on the step, so it can happen really fast
in high winds.
Sent: Sunday, March 23, 2003 11:08 AM
Subject: RE: Rebel on Floats
Thanks Walter
I think I'm going to go the lazy route and
stick with the plans. I spent
most of the day yesterday trimming the ends
of my spreader bars so I don't
want to do that again. It sure would have
been nice if murphy had of done
the mitre cut at the factory. Do you
normally take off both floats at once
or lift one out before the other. I did
almost all my float training in a
very tired 172 the only way to get it off
the water was one float at a time.
will offer my
one wing and
stance:
winds and waves.
walking under
with me to
water with one
wanted to see
load plus"
trouble lifting
even tried it
still worked
instal my floats.
At 09:26 AM 3/21/2003 -0800, you wrote: Info on Rebel on floats, but I having a "blonde" moment. What I mounted on 1800 amphibs.-When sitting this as I need to check my hanger drawing with mention of dimensions on this from MAM on July 28 2000. If you
Miscellaneous -
inches lower.
scribe.wcx
Archives located at
Archives located at
Archives located at
Archives located at
Rebel on Floats
Thanks Walter
I think I'm going to go the lazy route and stick with the plans. I spent
most of the day yesterday trimming the ends of my spreader bars so I don't
want to do that again. It sure would have been nice if murphy had of done
the mitre cut at the factory. Do you normally take off both floats at once
or lift one out before the other. I did almost all my float training in a
very tired 172 the only way to get it off the water was one float at a time.
stance:
winds and waves.
instal my floats.
Hello Brian:
Your Pilot Pal,
Terry Dazey
Rebel 662
Archives located at
Archives located at
Rebel on Floats
Wow that's impressive. Jack Weibe gave me a ride in his rebel years ago.
I'd forgotten how fast it got off the water. I just remember thinking we
didn't have a lot of room to the bend in the river but using less than half
of what was there.
in high winds.
Thanks Walter
will offer my
one wing and
stance:
winds and waves.
walking under
with me to
water with one
wanted to see
load plus"
trouble lifting
even tried it
still worked
Miscellaneous -
inches lower.
scribe.wcx
Archives located at
Archives located at
Archives located at
Archives located at
