really tight or a two lip rubber style seal if you have a bit of room. The
two lip channel holds up longer and looks cleaner. Both of these that I am
talking about are available in any building center in the door sealing
department.
Sent: Sunday, November 06, 2005 10:45 AM
Subject: Re: Doors
WeDoes one put some sort of seal on the gap filler?
Mike Betti
Sent: Saturday, November 05, 2005 9:54 PM
Subject: Re: Doors
He was referring to the SR and I >THINK< it has skin doublers like I did
on
Howard's Rebel doors. Maybe I'm just referring to the doors I did!
The Rebel had you cut the door skins to fit the frames and then add .032
doublers to rivet between the skin and frame to be the door gap filler.
atook it a step further and left the door skin oversize and put the .032
behind it, bonded the two together with Proseal to reinforce. Makes for
stripsmuch cleaner looking assembly with a seam free door skin instead of
springof .032 with cut lines showing on the corners.
Sent: Saturday, November 05, 2005 10:43 PM
Subject: Re: Doors
recentlyThanks Wayne,
No, the reason I ask about the sealant is due to a comment you madethat maybe I don't understand.
You wrote:
Proseal does a good job. Rivet it together and leave clamped with
sowhereclamps around the perimeter till it cures. Clean the edge with a knife
afterwards. U are referring to the door jam overlap on the door skinsyou reinforce with .032 or similar?
What do you mean here?
Mike Betti
771E
Sent: Saturday, November 05, 2005 7:11 PM
Subject: Re: Doors
work?noare
way.doubler
hingesurface
