before.the problem was it took so many strokes.but I'll double check.
Jason
On 5-Feb-11, at 5:44 PM, Walter Klatt wrote:
Yeah, the problem with the 201 A-6 is the flow rating is too low at
only 30
gph. The 231 is rated to 65 gph, I believe, and the .5 psi pressure
drop
isn't reached until max flow. So at normal fuel flow of 7 - 16 gph,
pressure drop would be much less than the 201.
Yes, it works with 3/8 fuel lines, that's what I have.
Rebecca Brownell
Sent: Saturday, February 05, 2011 2:31 PM
Subject: Re: [rebel-builders] fuel flow testing
Thanks again,it is a floscan 201 A-6.Should trust ones instincts ,I
knew that hole looked small.I'll check out the other senders for
later.I have to get this thing inspected before the end of Feb.Have a
pilot lined up but the insurance co. is frowning on his age a
bit.Can't really fly it till I get a hydraulic pump,the one I had made
isn't going to work.Just another few hundred down the tubes.Any word
on that pump Bob,I guess the end of January didn't work eh.
Thanks again folks.Much appreciated.
Jason
On 5-Feb-11, at 5:12 PM, Ron Shannon wrote:
FWIW, I use an EI FT-90 "gold cube" flow transducer, which they
claim has a
0.05 PSI pressure drop at 20 GPH.
http://www.buy-ei.com/Pages/Miscellaneo ... _Flow.html (It was
inline for
the gravity only results reported earlier in the thread.)
Ron
N254MR
On Sat, Feb 5, 2011 at 2:01 PM, Walter Klatt <Walter.Klatt@shaw.ca>
wrote:
Jason, if you run a fuel flow sensor, you need one would that has a
low
pressure drop. If it is a Floscan, make sure it is not the 201B.
That one
does not work well with gravity fuel systems.
I run a Floscan 231 in mine, and it has only 0.5 PSI pressure drop,
so it
works fine. I was getting around 27 gph IIRC
