Date: Tuesday, October 20, 2009 10:27 am
Subject: Re: [rebel-builders] Adjusting Aileron/Flaps
(16.7Yes - 80 mph CAS is about the lower limit for reflex and I think
most
rebels experience that. Certainly mine and John Petersons were
similar.
At higher altitudes like above 4000', 80 mph CAS requires more
than 2350
rpm on an O320. At sea level, 80 mph is still a low rpm exercise.
Garry
WALTER KLATT wrote:if I am not too heavy. I often do slow cruises around the lakeI can go surprisingly slow with my reflex, down to near 80 mph
when taking people for rides, between 80 and 90 mph, and burn as
low as 5 US gph. At some point, though, as I slow down, the nose
starts to rise, and I have to put it into neutral. I immediately
lose a few mph then, and have to increase throttle to maintain
speed. It may be that the VGs help here, too. Can't remember,
though, how slow I could go in reflex before I had them.VGs. They also really help with float ops, as do the full spanAgain, I have no problems in crosswinds now that I have the
flaperons. Float angle is important too, and take off technique
may have to vary a bit depending on weight and hp.But you should come for a flight with me. My plane is quiteKen, don't know if you still lay over in Vancouver sometimes.
different than yours, and it might interesting to compare as you
continue to refine yours.for.Walter
Date: Tuesday, October 20, 2009 9:50 am
Yes Steve can drop flaps and ailerons independently.
I might be seeing a similar power thing as you in that I'm
likely
turning the Warp slower than it was really designedtoBut it is nice
and quiet.
Garry Wright wrote:
adjustments.>
lots of wind
installed7.3 gph
rpm to about
effectively
higherone and
wantrpm
allows full
maxto give up
be tricky.
ailerons
theflaperon
knots or
inch on the
rarelywing in
matter of
adjust things.
it doesn't
sideways it
possible but
3use reflex
engineblade Warp
on, the more
and roll the
suretorque,
means that I
deflection
flaps as long
That would
deflection and
andthe teleflex
hasit is a
flight that
loaded then
halfanswered
do remember
only apply if
would be offset a
bellcrank. My
it takes firm
flaperons are down.
move the
That's my
beinch is not
sureannoying when
probably
crankthe teleflex
them with the
anywhere near full
could contribute to
properly rigged. I
still a head
in the fuselage are
figure out what to
thewas a BIG surprise
installedmixer bell crank
itbackwards. I
pattern and you are
1/8" different in
is a factor in the
bellgo? Was there
missed? I guess it
time and head aches
ruddercranks effect on
incables. I would
mayslightly>>>>>> different positions or the horns on the torque
tube riveted on in
bellcrankhave to live
aileron horns will
tois backwards.
oninstall it
locationthe elevator
hesitant to make
Teleflex cable
from 2-3/8" to
