Bending SS Exhaust Pipe
LisaFly99
Post by LisaFly99 » Sat Feb 18, 2012 1:29 am
In a message dated 10/18/02 11:41:49 AM Central Daylight Time, dale.kilbey@sympatico.ca writes:
Does anyone have any ideas on how to bend 1 3/4" stainless steel exhaust pipe without distorting it? I tried bending it on the bending macine at a muffler shop , but it goes oval and loses size. THanks
Try filling it with sand and plugging the ends before you bend it. Or find an electrician with a hydraulic bender with a 1 3/4' shoe.
Phil&Lisa Smith
N414D
#460R
klehman
Post by klehman » Sat Feb 18, 2012 1:29 am
You could try to locate a local shop with a mandrel bender. Most people
seem to buy prebent elbows or U's then start dicing and welding. Some
guys tack it together for someone else to weld. If you need a source I
think Kinsler Auto or Burn's stainless are two companies that have web
sites.
I've heard that packing the pipe with sand or metal shot may help a bit
when used with a pipe bender but I will dice and slice when I get to my
exhaust.
Dale Kilbey wrote:
Hi All
Dale 220R
Dale Kilbey
Post by Dale Kilbey » Sat Feb 18, 2012 1:29 am
Phil and Ken
Thanks for the replies.
I'll give it some thought
Dale ____________________________________________________
http://www.incredimail.com/redir.asp?ad_id=309&lang=9 IncrediMail - Email has finally evolved - Click Here
LisaFly99
In a message dated 10/22/02 8:45:28 AM Central Daylight Time, dale.kilbey@sympatico.ca writes:
Phil and Ken
Dale
DALE
Every body I know of in the racing industry builds there headers the way Ken explained. Starting with doughnuts, U's, and straight pieces. Cut tack and weld to achieve what they want. If done properly and polished up they look good.
Phil&Lisa Smith
N414D
#460R
Dale Kilbey
Thanks again Phil
Thats how I was planning to do it, but I was going to do the bending. I was not aware that you could buy it pre-bent. Unfortunately, We don't get much exposure to the racing world up here in Northern Ontario
Dale 220R ____________________________________________________
