It seems there have been a lot of variations with MAM's
pitot tube. Mine came with a hole drilled in the side
for a static port, and is pretty accurate. I mounted it
on the left wing, with the static hole on the inside
pointing toward the fuselage.
However, another Rebel here locally, with the same
pitot tube has the problem with inaccurate readings. In
his case, though, the static port is on the bottom of
the tube. He tried putting the static port on the side
of the forward fuselage as suggested, but it was still
a problem there, too.
For some reason, mine seems to be OK, but have heard of
more installations that don't work than do. So, go
figure...
murphy-rebel@dcsol.com
[mailto:
murphy-rebel@dcsol.com]On Behalf Of
Sent: Wednesday, October 09, 2002 7:30 AM
To:
Subject: Re: Static Port Location
Hi Bruce !
This is a change, then. All of the tubes I've
seen here
didn't have ANY holes in the outer (static) tube -
that's why
they didn't work !!
Can you blow air freely through the static
line, out those
holes ??
In any case, that tube fastens to the leading
edge of the
wing - everything I've read says the best place for a
pitot is
about 4" below the wing, about 1/3 of the way back the
chord.
This makes the top stru fairing a pretty good
place to mount
a bracket to hold a 5/16" I.D. tube about 6" or 8"
long. The plastic
tube off the back can run under the fairing and down
the strut,
so it's easy to run up to the indicator. The large
diameter pitot tube
helps to compensate for the large range of angles that
the Rebel
flies at.
....bobp
Sorry to hear about SkyStar - they were a pretty
decent outfit.
Perhaps yet another "white knight" will appear to save
them !
-----------------------------------orig.---------------
At 08:32 PM 10/8/02 EDT, you wrote:
Bob,
What do you mean "drill a hole in the side/bottonm of
the tube"? The tube
already has four static holes drilled in it. The
installation instructions
and MAM never mentioned drilling a new hole.
Bruce 357R
<HTML><FONT FACE=arial,helvetica><FONT SIZE=2
FAMILY="SANSSERIF"
FACE="Arial" LANG="0">Bob, <BR>
<BR>
the tube"? The tube
and MAM never mentioned drilling a new hole.<BR>
<BR>
Bruce 357R </FONT></HTML>
To unsubscribe go to
http://www.dcsol.com:81/public/listserv.htm
Archives located at
To contact the list admin, e-mail
mike.davis@dcsol.com
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
