non-symetrical fuel tanks
Mike Davis
Post by Mike Davis » Fri Feb 17, 2012 8:18 pm
Received: from RebelAir@aol.com
by imo26.mx.aol.com (IMOv18.1) id RXBLa00811
for <murphy-rebel@dcsol.com>; Wed, 27 Jan 1999 13:06:25 -0500 (EST)
Message-ID: <a3a15524.36af55a1@aol.com>
Date: Wed, 27 Jan 1999 13:06:25 EST
Mime-Version: 1.0
Subject: Re: non-symetrical fuel tanks
X-Mailer: AOL 3.0.i for Windows 95 sub 19
Hi Alister
I for one, am always glad to hear from a flying Rebel member of the family.
Please do not stop giving your input.
Best Regards
Brian #328R
Mike Davis
Received: from dialup.voyager.co.nz (ts1p10.net.ashburton.voyager.co.nz
[203.21.25.174]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
OAA26152 for <murphy-rebel@dcsol.com>; Thu, 28 Jan 1999 14:59:38 +1300
(NZDT)
Message-Id: <199901280159.OAA26152@host02.net.voyager.co.nz>
Date: Thu, 28 Jan 1999 13:25:41 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Thanks Brian, I do hate to see people fall into the same traps I have.
Alister
Date: Thursday, January 28, 1999 7:06 AM
Hi Alister
family.
Best Regards
Brian #328R
Mike Davis
Received: from [137.186.225.15] (helo=ms01-269.tor.istar.ca)
for murphy-rebel@dcsol.com
id 10AHZS-0003dQ-00; Tue, 9 Feb 1999 13:07:38 -0500
Mime-Version: 1.0
Message-Id: <E10AHZS-0003dQ-00@mail2.toronto.istar.net>
Date: Tue, 9 Feb 1999 13:07:38 -0500
I sure wouldn't bother with the complication of aileron trim - in
any case, you'd have to do one on each aileron !! This would add weight to
the ailerons, and necessitate mass balance changes - inviting flutter !!
The Super Rebel is plenty light on the ailerons, and, like the Rebel,
you can easily pick up a wing with rudder. The chances are that your
Super Rebel will fly hands-off anyway .....
Worst case, a little adjusting of the wing-tip angles can do
dramatic things. (As might the new Hoerner tips from Dave Fife :-) !)
Rebels generally are nowhere near the speed range of RV's, and
have a fat wing, so rolling the trailing edges on the ailerons is
unlikely to have much effect, other than work-hardening the aluminum...
---------------------------------orig.--------------------------------
At 07:12 PM 1/26/99 +0400, you wrote:
Reference the the inflight aerodynamic balance, I'm considering installing
an
electric trim (MAC 4A)
for aileron trim. I will be installing electric trim for rudder when I get
around to
retrofitting.
Question; will the rudder trim by itself be able to take care of a heavy
wing
problem?
I'm thinking maybe I won't need both units. I don't have any experience in
light a/c
(engine torque) in this regard.
We trim out the big jets by using rudder only keeping the bank within 11/2
degrees
to zero the ailerons and minimize drag.
Warren T. Montgomery
SR 029
<monty@emirates.net.ae>
Dubai, United Arab Emirates
