Spring Gear fix ???
Mike Davis
Spring Gear fix ???
Post by Mike Davis » Fri Feb 17, 2012 5:18 pm
Received: from dialup.voyager.co.nz (ts1p15.net.ashburton.voyager.co.nz
[203.21.25.179]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
MAA20393 for <murphy-rebel@dcsol.com>; Fri, 22 Jan 1999 12:23:35 +1300
(NZDT)
Message-Id: <199901212323.MAA20393@host02.net.voyager.co.nz>
Subject: Re: Spring Gear fix ???
Date: Fri, 22 Jan 1999 12:22:23 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Jim,
No, you're right, it ain't no Maule! It's Better!!!
I think we've got to keep things in perspective here, with the problems
I've had with the gear, engine mount etc. you would think I would have
every right to feel a bit brassed off with the whole thing. In fact I am
not, admittedly pulling the aircraft to bits again was a real pain, but the
end result is really worth it. I've got an aircraft here that is just the
envy of everyone. A few weeks back I teamed up with a 235hp Maule and we
headed south to fiordland and spent day doing the airstrips in that area,
some of them are really challenging. With similar payloads my Rebel
performed every bit as good as the Maule, take off distances were very
similar, landing distances a bit shorter, the Maule had to pull a bit of
power back to stay with me in the cruise but when we pulled up to the fuel
pump I know which aircraft I would rather be filling up!
The visibility is absolutely stunning in the Rebel and it is the sort of
aircraft you just 'strap on your back' and fly away. Obviously being on
experimental and with a brand new airframe, maintenance costs are way back
on that of a Maule. And for less money you own a new aircraft verses
something decades old.
The Maule pilot came back blown away by the capabilities of the Rebel, his
statement was " That has got to be the best plane in New Zealand!" I, of
course, agreed!!!
These issues in regards to the 'Floatfix' and spring gear etc. just have to
be worked through, the end result is a aircraft that you can have complete
confidence in.
All issue I've dealt with regarding the Rebel have been when the the
aircraft comes in contact with the ground (and rough ground at that!), and
as you say hanging heavier motors on the front, in the air, it's bullet
proof. Work through those problems and the road is clear ahead.
Stay positive !!
Alister
From: James A. Remington <jaremington@earthlink.net>
To: (Murphy Rebel) <murphy-rebel@dcsol.com>
Date: Friday, January 22, 1999 11:16 AM
Alister: The set I have now is a replacement for the first set. The
first set
was so bad that the left and right leg were off by 3 inches when clamped
to a
table and one had positive camber and the other had negative camber. No
amount
of shims could have corrected that. Goodness knows how the aircraft
would have
tracked on the ground and one wing tip would have been a least a foot
lower
than the other. The second set was just about as bad so I did not try
for a
third set. Again, no wedges or instructions were included with either
set.
On a different tact, I doubt if the aircraft was ever designed to take
concentrated torque load that this spring gear generates at the attach
point.
Your fix may have resolved that but Murphy's approach to all of these
structural failures is to 1) deny they exist 2) when that won't work,
slap on
a doubler of paper thin aluminum and hope it goes away.
This has been the case with cracks due to ever increasing engine weight,
seat
failures, tail cone buckling, etc. I realize it is an experimental but I
think
Murphy lets his ego and the bottom line get ahead of owning up to weak
points
and letting all kit owners know of potential problems. We kit owners are
also
at fault for taking an overgrown ultralight and trying to make it into an
C172. The original design wasn't bad. Everything was basically in
harmony
including that 80 HP rotax. When we keep hanging heavier and heavier
things on
that airframe, I think we are asking for trouble. It ain't no Maule!
jar
Alister Yeoman wrote:
Jim,
You've tried Murphy for a replacement on them? If they are not right
they
should be replaced, mine were absolutely perfect!
Alister
Date: Friday, January 22, 1999 7:05 AM
Alister: I showed the gear to an EAA friend who knows a good bit
about
such
things and he said that to make them match they would have to be
softened, bent
and then tempered again to the original condition. This work must be
done by a
shop that really know heat treating of aluminum. He is also the one
that
said
the legs should have been gun drilled for the hydraulic lines before
they
were
bent the first time.
Jim
spring
gear
has
its
instructions
between
combination
caster
that
step.
consider
bookends.
Murphy
with,
it
solid
cheaper
supplied
in
them. I
fuse.
bigger
aircraft,
is
book
using
rear of
visible
but
you
would
block
make
any
was
very
they
Hanging
two
gear
wondering
aircraft
they
outer
diameter
corner
against
move a
quite
then
from
fact
inserts
AN3
really
to do
have
been
sorted
by
outer
gear
but
is
no
left
off
rolled
rows
bolts,
this
850-6
rough
more
about
any
it
stengthen
it.
Mike Davis
Spring Gear fix ???
Received: from earthlink.net (ip85.richmond8.va.pub-ip.psi.net
[38.30.130.85])
by avocet.prod.itd.earthlink.net (8.8.7/8.8.5) with ESMTP id SAA03069
for <murphy-rebel@dcsol.com>; Thu, 21 Jan 1999 18:05:07 -0800 (PST)
Message-ID: <36A7DCF3.EE9D1568@earthlink.net>
Date: Thu, 21 Jan 1999 21:05:40 -0500
From: "James A. Remington" <jaremington@earthlink.net>
X-Mailer: Mozilla 4.06 [en] (Win95; U)
MIME-Version: 1.0
References: <199901212323.MAA20393@host02.net.voyager.co.nz>
Alister: Thanks for the up lift. I have not given up but I do plan to keep
it
light. Right now I am thinking of using the Jabaru engine. I have a Subaru
Legacy and a redrive but I am not sure I have the skills or time to make it
work. If not the Jabaru then probably the Rotax. I flew the Rebel when it
first showed up at Sun 'n Fun with the Rotax. I few it the next year with
O-240 and again the next year with the 0-320. For my needs the Rotax or
similar will do just fine. Then I can sell the Maule.
By the way, if you are into the internet you can take a look at my grass
strip
at the following web site.
http://home.earthlink.net/~jaremington/ ... irport.htm
It's not much but it keeps me sharp with the Maule and someday the Rebel.
Again, thanks for the boost.
jar
Jim,
course, agreed!!!
confidence in.
Stay positive !!
Alister
first set
to a
amount
would have
lower
for a
set.
point.
slap on
seat
think
points
are
also
an
harmony
things on
jar
Jim,
they
Alister
about
such softened, bent
be
done by a
that
said
they
were
spring
gear
has
its instructions between
combination
of caster
that
step. consider bookends.
official
Murphy
with,
it solid
cheaper
supplied
in
require
them. I
fuse. bigger
aircraft,
there
is
The
book using
rear of
visible
but
you
would
block
make
any
was
very
why
they
Hanging
two
gear wondering
aircraft
this,
they
outer diameter
top
corner against
is
can
move a
slack
quite
then
from
fact inserts
AN3
really
to do
have
been
sorted
by
outer
gear
on
but
is
no
left
off rolled
rows
bolts,
this
850-6
rough
more
about
any
it
stengthen
strengthen
it.
Mike Davis
Spring Gear fix ???
Received: from [137.186.224.36] (helo=ms01-36.tor.istar.ca)
for murphy-rebel@dcsol.com
id 103gem-00048y-00; Fri, 22 Jan 1999 08:29:52 -0500
Mime-Version: 1.0
Message-Id: <E103gem-00048y-00@mail2.toronto.istar.net>
Date: Fri, 22 Jan 1999 08:29:52 -0500
Jim,
We have a former Maule owner in Northern Ontario who sold his Maule
to build the Rebel - has a Subaru Legacy on straight floats. I think he
has no regrets !!
If you don't need a 320, then my first choice would be the new
912-S (100 hp). It's light, and plenty of power for wheel flying. My
912 Rebel outperforms the O-235 in every way, except climb, with a
heavy load - light, the lighter airplane always wins !
Have heard reports of problems with the Jabiru's - valve train
problems (springs,guides, valves), etc. Perhaps Alister could confirm -
he's closer to OZ ??? All feedback appreciated - even if it's only third-
hand rumour ..... :-)
FWIW - I really LIKE the bungee gear. If you make up (or buy) RINGS
of bungee, the installation and function is better, and <i> have had NO
problems with this gear. It's about 28 lb lighter than the spring gear,
AND cheaper, and (IMHO) stronger !
If you have quality problems, Murphy WILL stand behind their products.
If you tell them exactly what you are looking for in a replacement set
of gear legs (matching, AND instructions and shims,etc.), I'm sure they
will set it right. They have had staff changes in QC and shipping, so
things are getting better. You are certainly entitled to a proper,
complete kit for the gear legs, especially since it sounds like you
bought this as an UPGRADE, after the original purchase, at a hefty price !!
(they are good people - just sometimes a little laid back - it's the
West Coast environment :-) (Canada's California !!) )
....bobp
------------------------------orig.--------------------------------------
keep it
Subaru
strip
jar
Jim,
fuel
back
his
course, agreed!!!
complete
confidence in.
Stay positive !!
Alister
first set
clamped
to a
No
amount
would have
lower
for a
set.
point.
slap on
weight,
seat
think
points
are
also
an
harmony
things on
jar
they
about
be
one
that
before
they
spring
certainly
has
combination
that
official
with,
cheaper
supplied
require
absorb
aircraft,
there
is
The
up
visible
you
block
make
was
why
Hanging
by
two
aircraft
this,
top
sitting
is
can
slack
happening
then
from
for
three
AN3
to do
have
sorted
outer
on
but
bolt
is
left
rows
bolts,
up )
850-6
rough
more
about
any
[/quote]and
it
stengthen
[/quote]strengthen
it.
[/quote]
Mike Davis
Spring Gear fix ???
Received: from earthlink.net (ip126a.richmond6.va.pub-ip.psi.net
[38.30.108.126])
by avocet.prod.itd.earthlink.net (8.8.7/8.8.5) with ESMTP id GAA03069
for <murphy-rebel@dcsol.com>; Fri, 22 Jan 1999 06:49:15 -0800 (PST)
Message-ID: <36A8900B.905C3D7F@earthlink.net>
Date: Fri, 22 Jan 1999 09:49:48 -0500
MIME-Version: 1.0
References: <E103gem-00048y-00@mail2.toronto.istar.net>
Bob: Thanks for the input. I have just about decided to stick with the
bungee
gear. Weight would be the main reason. My only interest in the spring gear
was to
get the wider wheel base and lower center of gravity, thinking it would
reduce the
chance of ground looping. My only complaint with my Maule is its narrow
wheel base
which make it a bear in crosswind landing.
Yes, my spring gear was an upgread. I bought one of the early Rebel kits
with all
its shortcomings. You are probably right about the Rotax. It certainly is
building
a good track record but the the Jabiru may do so in time.
jar
Bob Patterson wrote:
Jim,
has no regrets !!
....bobp
keep it
Subaru
it
it
with the
strip
jar
Jim,
am
we
area,
fuel
back
his
course, agreed!!!
have to
complete
confidence in.
Stay positive !!
Alister
---------- first set
clamped
to a
No
amount would have lower
try
for a
either
set.
take
attach
point.
work,
slap on
weight,
seat
but I
think
weak
points
are
also
into an
harmony things on
right
they about
must be
one
that
before
they spring
old
certainly
has
difference
combination
that
also
official
up
with,
cheaper supplied
require
absorb
aircraft,
there
is
The
up
visible
if
you block make
was
why
Hanging
by
two
was
aircraft
[/quote]this,
[/quote]holds
[/quote]close
[/quote]top
[/quote]sitting
[/quote]gear is
[/quote]can
[/quote]slack
[/quote]happening
[/quote]because
[/quote]and
then
[/quote]away
from
[/quote]for
[/quote]block
[/quote]three
AN3
[/quote]works
[/quote]of
to do
[/quote]say,
have
sorted
[/quote]very
[/quote]rear
outer
[/quote]riveted on
but
[/quote]bolt
is
[/quote]be
left
[/quote]lower
[/quote]two
rows
bolts,
[/quote]up )
[/quote]fitted
850-6
[/quote]very
rough
more
about
any
[/quote][/quote]and
it
stengthen
[/quote][/quote]strengthen
it.
[/quote][/quote]
Mike Davis
Spring Gear fix ???
Received: from [137.186.225.17] (helo=ms01-271.tor.istar.ca)
id 103j6F-0006U1-00; Fri, 22 Jan 1999 11:06:23 -0500
Mime-Version: 1.0
Message-Id: <E103j6F-0006U1-00@mail2.toronto.istar.net>
Date: Fri, 22 Jan 1999 11:06:23 -0500
Don't worry !! I've flown a Maule, and the Rebel with the bungee gear
is a DREAM to land by comparison. On wheels, I've landed with a 90 degree
crosswind of 25 mph on pavement with no problem !! You can almost hold a
wing down right to the tiedown !! On amphibs, I've landed with a 45 degree
crosswind that was gusting to 47 mph on the wind meter - NO problem !!
The amphibs make the Rebel as stable as a flatcar !!
The other thing that is MUCH better in the Rebel is the visibility !!
It's almost like a heckicopter if you add skylights !!
Will be interested in the feedback on the Jabiru - hope we get some !
Sorry for your problems with the spring gear - there is a chance they
might give you a refund or credit, if you wanted to return it.
....bobp
bungee
gear was to
reduce the
wheel base
with all
building
jar
Jim,
has no regrets !!
third-
....bobp
keep it
Subaru
it
it
with the
strip
Rebel.
jar
problems
am
but the
we
area,
fuel
on
back
his
have to
complete
bullet
The
clamped
No
foot
try
either
take
attach
these
work,
weight,
but I
weak
owners are
into an
heavier
Maule!
right
bit
must be
one
before
old
certainly
difference
from
also
for
official
up
require
absorb
onto the
there
negative. The
ended up
down the
[/quote]if
block
[/quote]can
[/quote]I
[/quote]know why
Hanging
[/quote]Since by
[/quote]was
aircraft
[/quote][/quote]this,
[/quote][/quote]holds
[/quote][/quote]wrong
[/quote][/quote]close
[/quote][/quote]the top
[/quote][/quote]sitting
[/quote][/quote]gear is
[/quote][/quote]big), can
[/quote][/quote]slack
[/quote][/quote]happening
[/quote][/quote]because
[/quote][/quote]and
[/quote][/quote]away
[/quote][/quote]for
[/quote][/quote]block
[/quote][/quote]three
[/quote][/quote]works
[/quote][/quote]of
[/quote][/quote]say,
[/quote][/quote]it
[/quote][/quote]very
[/quote][/quote]rear
[/quote][/quote]riveted on
[/quote][/quote]bolt
[/quote][/quote]be
[/quote][/quote]lower
[/quote][/quote]two
[/quote][/quote]up )
[/quote][/quote]fitted
[/quote][/quote]no
about
any
[/quote][/quote][/quote]and
stengthen
[/quote][/quote][/quote]strengthen
[/quote][/quote]
[/quote]
Mike Davis
Spring Gear fix ???
Received: from tim-toshiba - 206.40.8.15 by email.msn.com with Microsoft
SMTPSVC;
Fri, 22 Jan 1999 11:14:50 -0800
Reply-To: <tlcarter@email.msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Spring Gear fix ???
Date: Fri, 22 Jan 1999 11:02:39 -0800
Message-ID: <000b01be463b$b7cc8000$14640a0a@tim-toshiba>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
In-Reply-To: <36A76C5B.D6FC7CB5@earthlink.net>
Return-Path: tlcarter@email.msn.com
Hi gang:
My experience with MAM over stuff like this is that they are good about
replacing 'bad' parts from their mfg. process. Granted, I have never asked
for an item as big as a spring gear, but, in my case if there was an
engineering-based or quality-based reason, they heard me out and sent
replacements. Every time.
Tim
From: James A. Remington [mailto:jaremington@earthlink.net]
Sent: Thursday, January 21, 1999 10:05 AM
To: (Murphy Rebel)
Alister: I showed the gear to an EAA friend who knows a good bit about such
things and he said that to make them match they would have to be softened,
bent
and then tempered again to the original condition. This work must be done
by a
shop that really know heat treating of aluminum. He is also the one that
said
the legs should have been gun drilled for the hydraulic lines before they
were
Jim
Jim,
Could the legs be pressed somehow to even them up.
It would be a shame not to use them, if the mods are done the spring gear
is really good. I have just been looking through some of the old
correspondance from this forum on the bungee gear and it certainly has its
share of problems and failures,
Stick to the spring gear!!
Alister
Date: Thursday, January 21, 1999 3:32 PM
Alister: I received no wedges with my spring gear and no instructions
for
proper rigging of the finished gear. Believe me the difference between
the left
and right leg is such that I will need quite a different combination of
wedges
on each leg to get the aircraft level and to get the camber and caster
same. No hurry in sending the drawing. I am a long way from that step.
will look at Murphy's fix if there ever is one but I will also consider
sticking with the original gear and using the spring gear for bookends.
Jim,
I can do that, I'll get on to it over the next few days.
I do have some concerns that this is of course not the official Murphy
fix,
I would suggest you wait a little to see what Murphy comes up with, it
does
sound as though they are onto it. I also found the cost of the solid
aluminum block and milling quite excessive, they may have a cheaper
option.
My gear legs were nice and straight, aluminum wedges were supplied in
kit to alter toe in/out etc. although I found I did not require them.
think you will find the the legs quite rigid, they dont absorb the
loads as
much as I would like, those loads are then transferred onto the fuse.
That
is why with all the off field work I do I have elected for the bigger
tyres. ( 850-6).
The camber of course changes dramatically as you load the aircraft, I
think
yours would tend to even out ( I think!!), Lightly loaded there is a
lot of
positive camber, at all up weight it is noticably negative. The book
says
to set the wheels at slight toe out. Seems to work.
Yes, the brake lines can be quite messy can't they? I ended up using
all
aviation spec materials with the braided flexible line down the rear
leg clipped on with the same clips as used on a C180. Very visible but
at
least it looks, and is functional!
I'll fax that through in the next few days.
Alister
would
be
inserts
you changes with
didn't
gun
hydraulic
gear
legs I
what
sit
level
told
me straddle
for
edge
settling
in, little
develops (
it quickly, braking
starts to
there
are
for
bolts in
well.
The
this,
so it working
now.
frequently in
gear
bolt
should
be
big
drama.
until
say
corner
rivets
on
this
was
my
because
tyres.
places
problems.
What changes in
didn't
seem
spring
Mike Davis
Spring Gear fix ???
SMTPSVC;
Fri, 22 Jan 1999 11:36:01 -0800
Date: Fri, 22 Jan 1999 11:18:44 -0800
Message-ID: <000c01be463e$ac933dc0$14640a0a@tim-toshiba>
MIME-Version: 1.0
Importance: Normal
In-Reply-To: <36A7A722.18C115FB@earthlink.net>
James:
What engine are you running?
Tim
Sent: Thursday, January 21, 1999 2:16 PM
To: (Murphy Rebel)
Alister: The set I have now is a replacement for the first set. The first
set
was so bad that the left and right leg were off by 3 inches when clamped to
amount
of shims could have corrected that. Goodness knows how the aircraft would
have
tracked on the ground and one wing tip would have been a least a foot lower
than the other. The second set was just about as bad so I did not try for a
third set. Again, no wedges or instructions were included with either set.
On a different tact, I doubt if the aircraft was ever designed to take the
point.
structural failures is to 1) deny they exist 2) when that won't work, slap
on
seat
think
points
also
C172. The original design wasn't bad. Everything was basically in harmony
including that 80 HP rotax. When we keep hanging heavier and heavier things
on
jar
Jim,
You've tried Murphy for a replacement on them? If they are not right they
Alister
such
softened, bent
done by a
that
they
were
Jim
Jim,
gear
its
Alister
instructions
for
between
the left
wedges
caster
step.
consider
bookends.
Murphy
fix,
with,
it
does
solid
cheaper
option.
in
them. I
loads as
fuse.
That
bigger
aircraft,
think
lot of
book
says
using
all
rear of
but
at
would
be inserts
any
very
they
didn't
Hanging
gear
wondering
what
sit
they
told
outer
diameter
for
edge
corner
against
the settling
move a
develops (
quite
starts to
fact
there
inserts
for bolts in
really
well.
do
this,
been
by
now. frequently in
gear
but
should
no
big
off
until
rolled
corner
rivets
this
was because tyres.
rough
places problems.
any
didn't
spring
it.
Mike Davis
Spring Gear fix ???
SMTPSVC;
Fri, 22 Jan 1999 11:36:11 -0800
Date: Fri, 22 Jan 1999 11:36:04 -0800
Message-ID: <000e01be463e$b1736900$14640a0a@tim-toshiba>
MIME-Version: 1.0
Importance: Normal
In-Reply-To: <E103gem-00048y-00@mail2.toronto.istar.net>
Bob,
There is a guy up north who makes a steel bushing set for the Rebel bungee
gear. I know I have asked you questions about the bungee gear before, but,
I cannot remember if I asked you if you have heard of that, or seen it, used
it or would recommend it.
This was advertised in the Rouser for a long time, and I believe these
bushings are used in the tops of the gear legs where the bolt goes thru.
The stated purpose was to eliminate the gear leg hole from wobbling out over
time.
Comments?
Tim
Sent: Friday, January 22, 1999 5:30 AM
To: Murphy Rebel
Jim,
has no regrets !!
....bobp
keep it
Subaru
strip
jar
Jim,
fuel
back
his
course, agreed!!!
complete
confidence in.
Stay positive !!
Alister
first set
clamped
to a
No
amount
would have
lower
for a
set.
point.
slap on
weight,
seat
think
points
are
also
an
harmony
things on
jar
they
about
be
one
that
before
they
spring
certainly
has
combination
that
official
with,
cheaper
supplied
require
absorb
aircraft,
there
is
The
up
visible
you
block
make
was
why
Hanging
by
two
aircraft
this,
top
sitting
is
can
slack
happening
then
from
for
three
AN3
to do
have
sorted
outer
on
but
bolt
is
left
rows
bolts,
up )
850-6
rough
more
about
any
[/quote]and
it
stengthen
[/quote]strengthen
it.
[/quote]
Mike Davis
Spring Gear fix ???
Received: from dialup.voyager.co.nz (ts1p02.net.ashburton.voyager.co.nz
[203.21.25.166]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
QAA22059 for <murphy-rebel@dcsol.com>; Sat, 23 Jan 1999 16:33:42 +1300
(NZDT)
Message-Id: <199901230333.QAA22059@host02.net.voyager.co.nz>
Date: Sat, 23 Jan 1999 16:28:22 +1300
X-Priority: 3
MIME-Version: 1.0
Bob, lots of Jabaru motors being fitted over here to all sorts of aircraft,
they appear very reliable, I will do some research and report back.
Alister
Date: Saturday, January 23, 1999 5:06 AM
gear
degree
they
....bobp
bungee
gear was to
reduce the
wheel base
kits
with all
is
building
jar
Jim,
Maule
he
has no regrets !!
confirm -
third-
RINGS
NO
gear,
products.
they
price !!
....bobp
keep it
Subaru
make it
when it
with the
or
grass
strip
Rebel.
problems
have
I am
but the
just the
and we
area,
very
bit of
the fuel
sort of
being on
way back
verses
Rebel, his
I, of
have to
complete
that!), and
bullet
The
clamped
camber. No
aircraft
foot
not try
either
take
attach
these
work,
weight,
experimental
but I
weak
owners are
into an
in
heavier
Maule!
right
bit
be
must be
the one
before
the old
certainly
difference
camber and
from
also
for
[/quote]days.
official
[/quote]comes up
[/quote]of the
[/quote]have a
[/quote]were
require
[/quote]absorb
onto the
[/quote]for the
[/quote]the
[/quote]loaded
there
negative. The
[/quote]ended up
down the
[/quote]Very
[/quote][/quote]wonder if
[/quote][/quote]aluminum
[/quote][/quote]can
[/quote][/quote]gear. I
[/quote]know why
[/quote][/quote]bending.
[/quote][/quote]Since by
[/quote][/quote]I was
[/quote][/quote]the
[/quote][/quote][/quote]addressed
this,
[/quote][/quote][/quote]holds
[/quote][/quote][/quote]wrong
[/quote][/quote][/quote]close
[/quote][/quote][/quote]sitting
[/quote][/quote][/quote]little
slack
[/quote][/quote][/quote]happening
[/quote][/quote][/quote]because
[/quote][/quote][/quote]downwards and
[/quote][/quote][/quote]them away
[/quote][/quote][/quote]know for
[/quote][/quote][/quote]block
[/quote][/quote][/quote]the three
[/quote][/quote][/quote]works
[/quote][/quote][/quote]come of
[/quote][/quote][/quote]say,
[/quote][/quote][/quote]had it
[/quote][/quote][/quote]bolts very
[/quote][/quote][/quote]rear
[/quote][/quote][/quote]rear bolt
[/quote][/quote][/quote]should be
[/quote][/quote][/quote]lower
[/quote][/quote][/quote]put two
[/quote][/quote][/quote]gear
[/quote][/quote][/quote]doubled up )
[/quote][/quote][/quote]fitted
[/quote][/quote][/quote]some very
[/quote][/quote][/quote]anticipating no
[/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote]quiet
[quote][quote][quote][quote][quote]about
[quote][quote]any
[quote][quote][quote][quote]changes in
[quote][quote]the
[quote]area of the sping gear. I talked to Grant about
[/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote]this and
[quote][quote][quote][quote][quote]it
[quote][quote][quote][quote]didn't
[quote][quote]seem
[quote][quote]to me
[quote]that they were planning a mod or retrofit kit to
[/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote]stengthen
[quote][quote]the
[quote][quote]spring
[quote][quote][quote][quote]gear. I
[quote]would like to know what you did to the gear to
[/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote][/quote]strengthen
[quote][quote][quote][quote]it.
[quote][quote][quote][quote][quote][quote][quote][quote][quote]Thanks Jim
JimsRebel@aol.com
[/quote][/quote]
[/quote][/quote]
[/quote][/quote]
[/quote][/quote]
[/quote][/quote]
[/quote][/quote]
[/quote][/quote]
Mike Davis
Spring Gear fix ???
Received: from [137.186.227.193] (helo=ms02-193.tor.istar.ca)
id 104GpD-0000SP-00; Sat, 23 Jan 1999 23:07:03 -0500
Mime-Version: 1.0
Message-Id: <E104GpD-0000SP-00@mail2.toronto.istar.net>
Date: Sat, 23 Jan 1999 23:07:03 -0500
I haven't seen these bushings, but the photos looked like very nice parts.
They are (IMHO) absolutely NOT necessary for the Rebel IF the gear is
set up properly. They WOULD likely be a good idea if you were going to
use die springs instead of bungees. (I DO NOT think die springs are a
good idea, but several folks are using them, with no major problem
reports so far.)
The problems happen because some people think the bungees should be
loose enough so the gear moves every time you taxi over a little bump -
this is incorrect ! The bungees are supposed to be so tight that they
only allow the gear to move if there is so much load that there might
be structural damage - they are only there to protect the airframe !
The tires are the principal shock absorbing/comfort mechanism - hence
the suggestion to use the fat 800x6 tires, fairly soft, at about 12 -
18 lbs pressure.
Rebel number 001 has over 900 hr. in 8+ years, and a LOT of
grass fields, and no significant wear in the fittings. In any case,
IF wear developped, you could THEN ream out and install the bushing
set. - the old "If it ain't broke, don't fix it !" thing.
--------------------------------orig.----------------------------------
At 11:36 AM 1/22/99 -0800, you wrote:
Bob,
used
over
time.
Comments?
Tim
To: Murphy Rebel
Jim,
has no regrets !!
....bobp
keep it
Subaru
it
it
strip
jar
Jim,
area,
fuel
back
his
course, agreed!!!
complete
confidence in.
Stay positive !!
Alister
clamped
to a
No
amount would have lower for a set. the point. slap on
weight,
seat
but
think points
are
also
an
harmony things on they about
be
one
that
before
they spring
certainly
has combination
that
official
up
with,
cheaper supplied
require
absorb
aircraft,
there
is
The
up
visible
if
you block make
was
why
Hanging
by
two aircraft
this,
[/quote]close
top
sitting
is
can
slack
happening
[/quote]because
then
[/quote]away
from
for
[/quote]block
three
AN3
[/quote]works
[/quote]of
to do
have
sorted
[/quote]very
outer
on
but
bolt
is
left
[/quote]lower
rows
bolts,
up )
850-6
[/quote]very
rough
more
about
any
[/quote]and
it
stengthen
[/quote]strengthen
it.
[/quote]
[/quote]
Mike Davis
Spring Gear fix ???
Received: from Rebflyer@aol.com
by imo28.mx.aol.com (IMOv18.1) id HKTLa23173
for <murphy-rebel@dcsol.com>; Tue, 26 Jan 1999 21:08:43 +1900 (EST)
Message-ID: <bcb6ebca.36ae752b@aol.com>
Date: Tue, 26 Jan 1999 21:08:43 EST
Mime-Version: 1.0
X-Mailer: AOL 4.0 for Windows 95 sub 214
Hi Jim,
Have you called MAM with your gear problem? Anytime I ran into
something
like that while building my Rebel they were more than helpful in fixing the
problem. Putting the thing together is difficult enough without having to
rebuild parts. Remember everyone give the factory a chance. I know that
some
of the reengineering seems to take longer than it should, but when it comes
simple part replacement due to incorrect manufacturing, they want to know.
Hmm, I do still wonder about their fiberglass parts though. Keep at it,
it's
worth it. Curt N97MR
Mike Davis
Spring Gear fix ???
Received: from earthlink.net (ip105a.richmond6.va.pub-ip.psi.net
[38.30.108.105])
by harrier.prod.itd.earthlink.net (8.8.7/8.8.5) with ESMTP id VAA14495
for <murphy-rebel@dcsol.com>; Tue, 26 Jan 1999 21:58:23 -0800 (PST)
Message-ID: <36AEAB26.8ED58A71@earthlink.net>
Date: Wed, 27 Jan 1999 00:59:02 -0500
Reply-To: jaremington@earthlink.net
MIME-Version: 1.0
References: <bcb6ebca.36ae752b@aol.com>
Thanks, I will.
jar
Rebflyer@aol.com wrote:
Hi Jim,
something
some
comes to
it's
