Horizontal stab/fin post interference
moose2b
Post by moose2b » Sat Feb 18, 2012 1:08 am
Hello!
Heard third hand of another possible fix. Could a builder just shim the stab
forward .080 or so to alleviate the interference? Those of you who have the
fuse completed probably can eyeball this one for feasibility.
Terry Riedel
SR 171
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:08 am
Terry, I had warned the factory that others out there, that are not
reporting an interference problem, may have bolted the stab on in front of
the pairs of attach brackets on the fuselage (which would move the assembly
forward about the 1/4" required!!) and then just threw a shim in to take up
the space on the fus brackets. I suggested a "WARNING" bulletin, as this
would put the 4 attach bolts in singular shear (and not double shear as was
the intended set up with the stabs fitting nested in between each pair of
fus fittings), so DON'T do it.
Sent: Sunday, May 05, 2002 6:31 PM
Subject: Horizontal stab/fin post interference
Hello!
stab
Terry Riedel
SR 171
moose2b
Thanks Wayne, I kind of figured that the "fix" seemed too obvious! It did seem
like a sweet solution if it worked though!!
On 5/5/02 7:31 PM, OIFA@IRISHFIELD.ON.CA wrote to MURPHY-REBEL:
-> Terry, I had warned the factory that others out there, that are not
-> reporting an interference problem, may have bolted the stab on in front of
-> the pairs of attach brackets on the fuselage (which would move the assembly
-> forward about the 1/4" required!!) and then just threw a shim in to take up
-> the space on the fus brackets. I suggested a "WARNING" bulletin, as this
-> would put the 4 attach bolts in singular shear (and not double shear as was
-> the intended set up with the stabs fitting nested in between each pair of
-> fus fittings), so DON'T do it.
-> Regards,
-> Wayne G. O'Shea
-> www.irishfield.on.ca
-> From: <moose2b@dcsol.com>
-> Sent: Sunday, May 05, 2002 6:31 PM
-> Subject: Horizontal stab/fin post interference
-> > Hello!
-> > Heard third hand of another possible fix. Could a builder just shim the
-> stab
-> > forward .080 or so to alleviate the interference? Those of you who have
-> the
-> > fuse completed probably can eyeball this one for feasibility.
-> > Thanks,
-> > Terry Riedel
-> > SR 171
-> > To unsubscribe go to http://www.dcsol.com:81/public/listserv.htm
-> > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
