Fuel burn
LisaFly99
Fuel burn
Post by LisaFly99 » Sat Feb 18, 2012 12:21 am
In a message dated 10/24/01 3:35:58 PM Central Daylight Time, cowcam@pipcom.com writes:
Phil, what is your fuel burn in cruise?
PETE
At 4800 RPM engine 2300 Rpm prop I burn right at 5 gal. an hour. I can get it below 5 gal per hour at 4600 RPM engine 2200 RPM prop.
Phil&Lisa Smith
#460R
N414D
Peter Cowan/Lexi Cameron
Fuel burn
Post by Peter Cowan/Lexi Cameron » Sat Feb 18, 2012 12:21 am
PETE
Phil&Lisa Smith
#460R
N414D
You can use that fuel burn rate to estimate the actual horspower you are putting out in cruise. Apparently most internal combustion engines burn about .5 lbs of gas per horsepower per hour. Your US gal weighs 6lbs so you are burning 30lbs per hour Divide by .5 = 60 hp.
LisaFly99
Fuel burn
In a message dated 10/24/01 9:48:10 PM Central Daylight Time, cowcam@pipcom.com writes:
You can use that fuel burn rate to estimate the actual horspower you are putting out in cruise. Apparently most internal combustion engines bu rn about .5 lbs of gas per horsepower per hour. Your US gal weighs 6lbs so you are burning 30lbs per hour Divide by .5 = 60 hp.
PETE
Then they can take that mega buck dyno it was run on and burn it right?
Phil&Lisa Smith
#460R
N414D
