[rebel-builders] For Sale: N337PB, engine, prop and parts
Khipp
Post by Khipp » Sun Feb 19, 2012 11:36 pm
I had the E22Subaru before converting to Lycoming. it too was advertised 165 HP. Turned out it was 135 HP. the 165 is apparently 2.2 litre
karl hipp
On Jan 10, 2012, at 7:30 AM, "J Portman" <baron@baron.com> wrote:
I've owned N337PB, a Rebel since 2003. I've only put about 100 hours total on
it due to time constraints.I had planned to convert from the Subaru to Lycoming.
The engine was a Crossflow package and runs strong, I just wanted the Lycoming.
It is a flying airplane. I will annual it prior to sale.
I also have a freshly overhauled Lycoming 0320 with 160HP, a Hartzell constant speed prop fresh from the overhaul shop, prop governor, pressure carburetor, one PMAG ignition and a brand new Murphy engine mount as well as the airplane.
I am asking $20K for the engine package with prop, governor, carburetor, pmag and mount.
I am asking $30K for the airplane, or $48K for the entire thing.
See some more details and pictures at http://new.baron.com/murphy
Equipment:
* 2000 Murhpy Rebel with 113 TTAE
* Subaru EJ20 2.0 liter 16 valve DOHC Fuel injected engine (165 HP)
* Warp Drive 3 bladed ground adjustable propeller.
* Ross reduction drive (2.15 ratio)
* New Battery
* Valcom 760 Com Radio.
* Magellan SkyNav GPS (needs database update)
* Narco Transponder
* Position and Strobe lights.
* Two place intercom
* Ameriking ELT
* Ameriking encoder
Specifications:
* Gross Weight 1650
* Empty Weight 1030
* Top Speed Sea Level 125 MPH
* Cruise 75% power @ 6000 ft 110MPH
* Fuel Capacity 32 gallons
* Sea Level Climb � 900 fpm
* Ceiling 15,000
* Take off
* Ground run 500 ft
* Over 50 ft obstacle 900 ft
* Landing
* Landing roll 350 ft
* Over 50 ft obstacle 700
* Baggage 100 lbs
* Oil Capacity 6 quarts
jack korycki
Post by jack korycki » Sun Feb 19, 2012 11:36 pm
Where is your plane located? Please call me at 867-445-3641.
________________________________
To: "<rebel-builders@dcsol.com>" <rebel-builders@dcsol.com>
Sent: Tuesday, January 10, 2012 8:37:38 AM
Subject: Re: [rebel-builders] For Sale: N337PB, engine, prop and parts
karl hipp
Equipment:
* New Battery
* Narco Transponder
* Ameriking ELT
* Ameriking encoder
Specifications:
* Gross Weight 1650
* Empty Weight 1030
* Ceiling 15,000
* Take off
* Ground run                      500 ft
* Landing
* Baggage                                  100 lbs
Ian W Berry
Post by Ian W Berry » Sun Feb 19, 2012 11:36 pm
Hi,I am Perth Western Australia What area in the US are you ?I wrote a Rebel
of hitting a tree and am looking for a replacement I would take it as is and
use the engine from the one that i destroyed. regards Ian Berry
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of J
Portman
Sent: Tuesday, 10 January 2012 10:31 PM
Subject: [rebel-builders] For Sale: N337PB, engine, prop and parts
on
Lycoming.
Lycoming.
carburetor,
Bob Bjorn
Post by Bob Bjorn » Sun Feb 19, 2012 11:36 pm
Hi Guy, I'm interested in your Lycombing package. Where are you in the
US, Bob
J Portman
Post by J Portman » Sun Feb 19, 2012 11:36 pm
Greetings. I am in San Antonio Texas (and the plane as well).
I can be reached at 210 316-2300
JP
a Rebel of hitting a tree and am looking for a replacement I would
take it as is and use the engine from the one that i destroyed.
regards Ian Berry
Of J Portman Sent: Tuesday, 10 January 2012 10:31 PM To:
total on it due to time constraints.I had planned to convert from
the Subaru to Lycoming. The engine was a Crossflow package and runs
carburetor,
J Portman
The plane is in San Antonio Texas.
I will call Monday.
JP
2.2 litre
karl hipp
Lycoming.
Lycoming.
the airplane.
pmag and mount.
Equipment:
* New Battery
* Narco Transponder
* Ameriking ELT
* Ameriking encoder
Specifications:
* Gross Weight 1650
* Empty Weight 1030
* Ceiling 15,000
* Take off
* Ground run                      500 ft
* Landing
* Baggage                                  100 lbs
