I don't know about the beer but use a sharp drill & a good lubricant and two
more important points. Slow down the RPM (about 30-40 Ft/minute) and back up
the SS with 1/2" thick wood or 1/8" scrap aluminum. If you really want clean
hole laminate the SS between the scrap aluminum.
Charlie E. 802R
Sent: Saturday, December 17, 2011 2:41 PM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] Rebel Firewall
A little bit of cutting fluid and good firm pressure is good for
stainless since it tends to work harden. You want the drill bit to bite
and cut not nibble/wear its way through. Even better if you can put it
in a drill press.
No point wasting the beer on stainless, you want to save that to enjoy
when you sit back & admire your fine handiwork ;-P
www.elite583.cjb.net
On 12/17/2011 4:21 PM, Ben Ransom wrote:
FWIW, mine is #496 shipped in 1995 to the US with a formed SS firewall.
Remember too, anyone who hasn't drilled their SS yet, to beer dip your
drill bit each hole, or you'll quickly heat ruin the bits. OK, I guess
any other liquid would be just as good.
I've bought bits from
http://www.aircraft-tool.com and
http://www.browntool.com/
Love those jobber bits.
-Ben
On 12/17/11 8:38 AM, "Wayne G. O'Shea"<
oifa@irishfield.on.ca> wrote:
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Unsubscribe:
List administrator:
