[rebel-builders] Rudder Pedal Mounting
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 8:43 pm
Does your delron blocks have an offset? What are your block measurements?
On 2011-04-11 5:21 PM, "Roland Kriening" <kriening@rogers.com> wrote:
I am test fitting my rudder pedals. After installing the 5/8 X 5/8 tube
down
the center of the floor I am finding that the rudder pedal assembly rides
up
on it and I cannot get both of the delrin bearing blocks to sit squarely
on
the floor. If I push one side down the other side rises up almost 1/4
inch.
Even with the doubler under the block I will still have a space. If I
force
it down the rudder assembly will be really tight against the centre square
tube. Doesn't seem right. Is there something I am missing?
Roland
R56
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 8:43 pm
Jeff,
The blocks are 1 11/16 square. The hole is offset by about 1/16 from centre.
Roland
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jeff
Micheal
Sent: Monday, April 11, 2011 8:27 PM
Subject: Re: [rebel-builders] Rudder Pedal Mounting
down
up
on
inch.
force
Roland
R56
Roland Kriening
Also, the length of each of my assemblies seems to be on the short side (16
1/4") based on the pics I see in the archives. Most likely because it is an
early kit. If I put one delrin mount on the outside of the engine mount
bracket, the other end only clears the centre by about 1- 1 1/2 inch. In the
diagram it looks like this should go out about 4-5 inches.
Roland
Micheal
down
up
on
inch.
force
Roland
R56
Jeff Micheal
I'll check some measurements later tonight when I go to the hanger and let
you know my findings. I'm working on a 300 series rebel.
(16
an
Roland
Micheal
down
up
on
inch.
force
square
Roland
R56
snowyrvr
Post by snowyrvr » Sun Feb 19, 2012 8:43 pm
Roland,
Make sure your blocks are oriented to give you the most height. I had to put a .040 shim under one set to clear the 5/8" tube. CW
Date: Mon, 11 Apr 2011 17:27:04 -0700
down
up
on
inch.
force
Roland
R56
Jeff Micheal
Roland,
As I recall, the earlier kits did have a shorter delrin bearing block. The
newer kits have blocks that measure approx. 2" H x 1 3/4" W x 1/2" Thick.
Measurement from bottom of the block to hole center should be about 1
1/4"and bottom of block to bottom of hole should be about 15/16", giving you
about 3/16" clearance between the 5/8 square tube and the rudder pedal
assembly.
If you have one of the older delrin bearing blocks, just make a shim to sit
under the delrin block to give you clearance; 15/16" from bottom of block to
bottom of hole in delrin will give you the clearance your looking for.
Jeff
On Mon, Apr 11, 2011 at 5:47 PM, Roland Kriening <kriening@rogers.com>wrote:
Jeff,
centre.
Roland
Micheal
down
up
on
inch.
force
square
Roland
R56
Roland Kriening
Hey Jeff,
Were you able to measure the length of one of the rudder pedal assemblies..
as mentioned when I set the delrin block next to the engine mount bracket,
the other end of the assembly barely clears the centre square tube. This
leaves my rudder pedals quite far apart.
Roland
Micheal
Sent: Tuesday, April 12, 2011 2:15 AM
Roland,
assembly.
Jeff
Jeff,
centre.
Roland
Micheal
down
rides
up
on
inch.
force
square
Roland
R56
Post by Ken » Sun Feb 19, 2012 8:43 pm
Roland
I don't seem to have a photo (I think I uploaded one a few years ago
though) but you probably want the pedals as far apart as possible. In
addition some of us also added an inch or so extension on the outboard
pedals to fasten the rudder cables to. The idea being to get the cable
attachment as far outboard as possible to minimize the angle that the
cable bends at the cage fairlead point. I think Canadian rules call for
a pulley if more than a 3 degree bend. Also it may be more comfortable
to keep your feet as far apart as possible in flight.
I did not need any shims under the bearing blocks on 119R but I did have
two layers of doublers there since I mounted the bottom of the master
cylinders on floor brackets. That mod requires doing something to keep
the floor from flexing too much. I think the bearing blocks were indeed
close to the center square tube as you have observed.
You can also get creative if you want. At least one builder moved that
square tube to below the floor. Actually I think he replaced it with an
piece of angle material below the floor.
On 4/16/2011 11:22 AM, Roland Kriening wrote:
Hey Jeff,
Roland
Micheal
Roland,
assembly.
Jeff
On Mon, Apr 11, 2011 at 5:47 PM, Roland Kriening<kriening@rogers.com>wrote:
Jeff,
centre.
Roland
Roland Kriening
Thanks Ken,
Sounds like a plan. I will have to rethink the position of the square
tube... that would indeed solve all the problems.
Roland
R56
Sent: Saturday, April 16, 2011 1:31 PM
Roland
Hey Jeff,
assemblies..
Roland
Micheal
Roland,
you
assembly.
sit
Jeff
Jeff,
centre.
Roland
Post by Bob Patterson » Sun Feb 19, 2012 8:43 pm
Hi Roland !
Many builders have added 2 more 5/8" tubes, one on each side,
equidistant from the center, and installed a sheet of .032 or .040
on top of them, extending out to the corner wraps. This double floor
stiffens things up a lot, raises your feet a bit, and eliminates the
conflicts with tubes ...
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
On April 16, 2011 01:53:03 pm Roland Kriening wrote:
Thanks Ken,
Roland
R56
Roland
Jeff Micheal
Hi Roland,
The rudder pedal length is 18", so there was a change from the earlier kits.
What I would do is get rid of the 5/8 sq tube on the inside floor and
replace it with stiffener on the outside bottom skin (witches hat or a
couple angle pieces will work). When you put the stiffener on the bottom
outside skin, install it so the stiffener captures the firewall and the
bottom cabin skin (this way you are tying into 3 pieces and adding
additional strength to the fwd floor).
Jeff
On Sat, Apr 16, 2011 at 8:22 AM, Roland Kriening <kriening@rogers.com>wrote:
Hey Jeff,
Roland
Micheal
Roland,
you
assembly.
Jeff
wrote:
Jeff,
centre.
Roland
Jeff
Micheal
down
rides
up
squarely
on
inch.
force
square
Roland
R56
Roland Kriening
Thanks Jeff,
I will definitely move the stiffener to the outside. I have been trying to
source the same witches hat we used on the firewall, with no success. ACS
only has smaller witches had that is very flimsy. Does anyone know where I
can get more of the larger witches hat?
Roland
R56
Micheal
Sent: Saturday, April 16, 2011 2:36 PM
Hi Roland,
Jeff
Hey Jeff,
assemblies..
Roland
Micheal
Roland,
you
assembly.
sit
Jeff
wrote:
Jeff,
centre.
Roland
Jeff
Micheal
measurements?
tube
down
rides
up
squarely
on
inch.
force
square
Roland
R56
Hi Roland !
You can just email the part number & quantity needed to:
Shipping@murphyair.com
They have been shipping parts orders pretty quickly lately.
bobp@prosumers.ca
bobp@pattersys.com
Thanks Jeff,
Roland
R56
Micheal
Hi Roland,
kits. What I would do is get rid of the 5/8 sq tube on the inside floor
and replace it with stiffener on the outside bottom skin (witches hat or a
Jeff
