I too used the Van's baffle kit for my O320 and it had gaps at
the rear as you noted. I did not seal them until I did the first
annual and I have tried to note whether there is any additional
cooling (lower CHT's) and have seen little to none. So the amount
of cooling air loss is small compared to the amount of total
cooling air flow.
Jenks
Sent: Sunday, November 28, 2010 11:11 AM
To: Builders list
Subject: [rebel-builders] baffle sealing
I'm fitting the Vans baffles and wondering if I need to use something like
RTV in the areas where the baffles meet the cooling fins and engine case to
seal up all the small gaps. For example where the rear baffles sit on the
back of the aft cylinders and around the cylinder attach studs/nuts.
This baffle kit is a great thing by the way...probably saves weeks of work
and despair if you tried to do it from scratch. It must be cool to have a
cnc machine.
Thanks.
I have the Van's baffle installed on the O-540 in my SR-3500, Modified to
fit my installation needs. It sure is a great way to go, The $260.00 was a
wise investment, probably saving 2 or more weeks labor.
Mooney has used the RTV to seal up every pin hole in order to keep their
engines cool enough. I doubt that it will be necessary to use the stuff.
RTV does not accept paint, so if that is a problem to deal with paint first
then apply it. House painting "paintable sealant" could be an acceptable
alternate, but I have not tried it.
Dick Wampach SR-108 N331RW
Gustafson
Sent: Sunday, November 28, 2010 9:10 AM
Subject: RE: [rebel-builders] baffle sealing
the rear as you noted. I did not seal them until I did the first annual and
I have tried to note whether there is any additional cooling (lower CHT's)
and have seen little to none. So the amount of cooling air loss is small
cooling air flow.
Jenks
To: Builders list
back of the aft cylinders and around the cylinder attach studs/nuts. This
baffle kit is a great thing by the way...probably saves weeks of work and
despair if you tried to do it from scratch. It must be cool to have a cnc
machine. Thanks. Jesse
Gustafson
cooling air flow.
Jenks
To: Builders list
Jesse.. you don't want to seal the fins.. you just want enough of a bead
across the baffle edge to keep it from chewing into the cylinder fins.
To: "Builders list" <rebel-builders@dcsol.com>
to seal up all the small gaps. For example where the rear baffles sit on
the back of the aft cylinders and around the cylinder attach studs/nuts.
cnc machine.
Thanks.
Ok, thanks guys.
Another engine question: For some reason I have one threaded stud on the oil filter pad that I need to remove so I can bolt on a 90* filter adapter with a 1 1/2" spacer. Any tricks for removing a 1/4" stud? I tried tightening two nuts on each other, but they still turned on the stud.
Subject: Re: [rebel-builders] baffle sealing
Date: Sun, 28 Nov 2010 21:26:39 -0500
cnc machine.
Thanks.
Vice-grips!
Sent: Monday, November 29, 2010 7:01 AM
Ok, thanks guys.
like
case
on
studs/nuts.
work
cnc machine.
Thanks.
I guess that's what I'll do Craig. I was thinking there might be an elegant way to do it...not that vice grips aren't elegant :)
Date: Mon, 29 Nov 2010 09:05:25 -0900
Vice-grips!
Ok, thanks guys.
You'll probably have no use for the stud anyhow.. but you may wanna try a
bit of heat on it if it doesn't come easy.. maybe it was loctite'd in !
Sent: Monday, November 29, 2010 4:52 PM
Vice-grips!
Ok, thanks guys.
adapter
