[rebel-builders] O-320 Exhaust valve guide wear
Curtis Langholz
Post by Curtis Langholz » Sun Feb 19, 2012 8:06 pm
Wayne,
You are correct about the old cars and needing the lead for lubricant. I had an older Chevy that that the valve seats got pounded so bad the valves were recessed into the heads from not having leaded gas with the non hardened valve seats.
Curtis
Subject: Re: [rebel-builders] O-320 Exhaust valve guide wear
Date: Sat, 16 Oct 2010 16:55:51 -0400
Thanks for the info Tom. Some good stuff there that will all be discussed at
the engine shop on Monday.
As for the lead being a lubricant... if I don't run lead in my old cars
engines the valve seats would be toast in no time. Newer cars that run
unleaded have hardened valve seats and why I consider lead a "lubricant".
Maybe I've got it wrong... but what I've been told for decades.
To: "Murphy Mailing list" <rebel-builders@dcsol.com>
Sent: Saturday, October 16, 2010 11:53 AM
Subject: RE: [rebel-builders] O-320 Exhaust valve guide wear
Hi guys, just thought I'd add my bit.
Lead is NOT used as a lubricant for exhaust valves - It is strictly there
to as an octane booster. Lead suppresses the the tendency for gasoline to
detonate in higher compression engines (i.e. anti-knock). I don't know
where the rumour started that it was added to lubricate valves.
The only time I had problems with exhaust valves sticking was on an older
C-85 after I started burning mogas. Having said that I switched back to
Avgas and it stuck on me again.
Interesting note that 80/87 has 0.5 ppm lead and 100LL has 2ppm.
You may also want to check that the exhaust valve guides were changed to a
Ni-Resist steel and are njot aluminum bronze.
Note the following excerpt from Avweb. it is for the O-470, but I suspect
the same guides are used on smaller engines. Hope this helps...
Older O-470 cylinders were equipped with aluminum-bronze intake and
exhaust valve guides. And while the intake guide performed well and is, in
fact, still used today, the exhaust guide didn't hold up to the heat
created in the exhaust port. When 100LL fuel was used, the exhaust guides
failed even faster due to the prolonged burning process of higher octane
fuels. The exhaust valve guide was then changed to a Ni-Resist steel guide
which is better suited to the higher temperatures encountered. After some
years of success with the Nitralloy guide in the 520 series engines, the
0-470 was given the option of using the same top end parts as the 520. As
a result, the use of the pre-sized Nitralloy guide, pre-sized
aluminum-bronze intake guide (with seal) and improved four-ring pistons
became the standard at engine overhaul.
In recent years, the Nitralloy guide has been replaced with a new version
of the old Ni-Resist guide due to some concerns about accelerated stem
wear and isolated cases of valve sticking due to corrosion in the guides
of inactive engines. TCM's SB #M90-13 talks about the corrosive
environment in which exhaust valves must operate and states that
accelerated stem wear is caused by these elements. More to the point would
be the elevated temperature the working Nitralloy guide creates by virtue
of the nitrided surface on the guide's inside diameter. This higher
temperature tends to flash (carbonize) the lubricating oil - especially at
shutdown - and can cause immediate and permanent valve seizure in the
guide.
Current issues of TCM's SB #M85-8 and #M85-19 define the options for
superseded piston assemblies and valve guide combinations. It's important
to be aware that older, outdated parts can still be purchased but they are
probably not the best option given the expectations put on our engines
today.
Tom Tonner
Date: Fri, 15 Oct 2010 20:27:48 -0700
Thanks Wayne! I do remember that now. I knew I was forgetting something.
Keith
Date: Friday, October 15, 2010, 10:23 PM
Yes lead is a lubricant to protect the valve seats... but it's content is
way too high in 100LL as Ken has pointed out and it becomes a valve
"sticking" and wearing problem.
Sent: Friday, October 15, 2010 11:18 PM
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 8:06 pm
Being an old hot rodder from many years ago....I seem to recall it (lead) acts more like a "cushion" as far as the valve seats are concerned. You guys will have to give me a little lee way here....."ol farts" disease and I am doing my best to pull this info out of what little memory I have. ;)
Keith
Date: Saturday, October 16, 2010, 3:55 PM
[quote]
Hi guys,
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:06 pm
Thanks Keith.. all I know is that lead keeps my '69 Bee and '70 Bird's
magnum/super commando engines alive and well !
Sent: Saturday, October 16, 2010 9:37 PM
Keith
at
in
guide
would
at
guide.
are
today.
Tom Tonner
Keith
is
Keith Leitch
LOL...Well, wayne I have been drooling over those everytime I visited your site. Buddy of mine just got finished restoring a GTX. I thought you had sold one of them. I was more of a Mustang guy, Couple of Mach I's, one being a Cobra Jet.
Still got them both Keith. My father bought the Bee new off the showroom
floor. I picked up the Bird in '89 out of Texas.
http://www.irishfield.on.ca/gallery/bee1.jpg
http://www.irishfield.on.ca/gallery/bird/3-bird.jpg
Sent: Saturday, October 16, 2010 9:53 PM
being a Cobra Jet. My 67 Mustang had a small block Shelby engine it that
was removed from the teams stock car after they changed the cubic inches
to a different class. :) Still have a '59 Vette I have owned for 30+ years
also. Of course the son thinks he should have it. :)
Keith
Date: Saturday, October 16, 2010, 8:45 PM
Keith
at
there
older
suspect
in
guides
guide
some
As
version
would
virtue
at
guide.
important
are
today.
Tom Tonner
allen.hewko
Post by allen.hewko » Sun Feb 19, 2012 8:06 pm
I use Shell Vmax (premium) mogas (Canada), it has no alcohol in it. I have
been mixing it with 100LL at varying rates with no issues so far. I have had
some plug fouling when running straight avgas for longer periods. I am
running one P-mag electronic ignition, with NGK irridium plugs, and I am able
to lean more before running rough. I am very happy with the P-mag ignition.
Allen
R151
On 10/16/2010 4:46 AM, im_planecrazy@yahoo.com wrote to rebel-builders:
-> Ken,
-> I am "lucky" also in that aspect. Here in MN there are several places that
still have premium mo-gas without that dreadful ethanol!!! It is sold mostly
for "colector cars, snowmobiles, etc." and lucky for me it is somewhat easy
to find. $3.00/gal vs.$4.50-5.50 for 100LL within 100 ,ile radius of my place. I
live nearly 30 miles from the airport so it is much easier for me to run up to
the local country store and get fuel than an hour to town and back. Generally
the only time 100LL is used by me is when I am away from home. Been
flying on auto gas for 24 years without any issues.
-> Keith
-> --- On Sat, 10/16/10, Ken <klehman@albedo.net> wrote:
-> From: Ken <klehman@albedo.net>
-> Subject: Re: [rebel-builders] O-320 Exhaust valve guide wear
-> Date: Saturday, October 16, 2010, 7:33 AM
-> If I had to use avgas (in any engine) I would definitely use something
-> like Decalin lead scavenger from aircraft spruce in the fuel.
-> Fortunately so far Ontario still has premium mogas without alcohol.
-> Ken
-> Keith Leitch wrote:
-> > I fly two different planes and the Champ with a Lyc O-235 does not
have the fouling problem. Had this plane for 5 years and never had an issue
with plug fouling running mo-gas with the occasional 100LL put in if on a
cross country. The 172 with the Continental on the other hand is VERY
suseptible to fouling...even with very strict leaning procedures.
-> > A change of plug may help....darn thing has 12 spark plugs though!!! ;)
I just noticed today that Leavens assembled my engine wrong. My rocker arms,
that have the extra oiling dribbling hole, are on the intake valves on every
cylinder.. not the exhaust valves where they are supposed to be!
Sent: Sunday, October 17, 2010 1:47 PM
[quote]I use Shell Vmax (premium) mogas (Canada), it has no alcohol in it. I have
had
able
ignition.
Allen
R151
-> Ken,
that
mostly
easy
place. I
up to
Generally
-> Keith
-> Ken
issue
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 8:06 pm
Wayne: that would give good reason for your early failure. Proper oil
circulation is a big part of cooling an engine.
%*^#%&*#&*^#&*%* %*^#%&*#&*^#&*%* (double darn!)
Sort of on the subject of LEAD; Continental O-200's... When 80/87 no longer
was available and 100/130 and 100LL was to be the only thing to use TCM did
come out with a recommendation that at OH change the exh valves and seats to
a different angle. I believe it was from 30* to 45* (I could have that
backwards). This was their only recommended fix for going to the higher
Octane level. So I ASSUME that was to reduce the harm from a slower longer
burn in the cyl's and more flames across the valve. I don't know if the
amount of lead was a factor.
Dick Wampach SR-108
G. O'Shea
Sent: Sunday, October 17, 2010 10:57 AM
Post by Ken » Sun Feb 19, 2012 8:06 pm
I didn't know that about the 0-200. I'd guess they were after increased
seat contact area.
For the curious, if you google something like "octane rating flame
speed" you will likely convince yourself that flame speed is only
vaguely (if at all) related to octane rating. Higher octane fuel may
well burn faster than lower octane fuel which is neither intuitive or in
line with most simplified explanations. Nor is it always the case. High
octane is high knock resistance which can be thought of as fast complete
combustion leaving little end gas (slow burning molecules) available to
auto ignite or detonate spontaneously before the flame front gets to them.
Similarly the over simplified explanation of calling lead a lubricant
has misled more than it has educated. Indeed most lead is used to raise
octane. A small amount of lead will resist microwelding of soft valve
seats and resultant seat recession. I think it is fair to call that
specific thing lubrication but there are substantial negative effects to
lead that are then overlooked.
Dick Wampach SR-108
G. O'Shea
Curtis Langholz
I think this one runs on unleaded.
Curtis
Date: Sun, 17 Oct 2010 20:31:20 -0400
seat contact area.
Dick Wampach SR-108
G. O'Shea
thtonner
Post by thtonner » Sun Feb 19, 2012 8:06 pm
Interesting - Never new that....
guide.
today.
Tom Tonner
Keith
Eduardo Gutierrez Sosa
Post by Eduardo Gutierrez Sosa » Sun Feb 19, 2012 8:06 pm
Hello Gentlemen (Ladies?): I'm new in this list; I've built a Moose and I've
flown 298 hours till today; It's a great aircraft, tricky to land and the
factory support stinks, like they never cared what happens after they sold
the aircraft kit, no response to e.mails and worse even, phone calls. The
tail wheel's mechanism is weak and I cannot get a decent response from
Chilliwack for a set of parts. I am thinking about adapting a Scott 3400
which I assume will be strong enough for the size of this aircraft. I fly in
South America, mainly Bolivia, Argentina and Brazil. Any comments? Regards,
Eduardo
-----Mensaje original-----
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de
thtonner@mymts.net
Enviado el: martes, 19 de octubre de 2010 10:14 p.m.
Para: Murphy Mailing list
Asunto: RE: [rebel-builders] O-320 Exhaust valve guide wear
at
there
older
suspect
in
guides
guide
some
As
version
would
virtue
at
guide.
important
are
today.
Tom Tonner
something.
Keith
is
4
same.
Just to complete the story... it turned out that #4 had a cracked exhaust
valve head to boot. My engine guy figures I should go buy a lottery ticket
as it was probably no more than a few hours from letting go and costing MUCH
more money! Catastrophic money...
So I had him do all four cylinders... $1072 and I supplied a new exhaust
valve that I had in spares. All cylinders pressure checked for cracks....
valves/seat faces redone and new exhaust guides and install gasket sets. Of
course it took 3x longer to put it all back together than it did to rip it
apart.. but man what a difference. I thought it was my technique or
something that sucked all summer.. but it was just lack of power. Test flew
her this afternoon and grass take off cut in half compared to leaving in
June and climb up from 800 fpm to 1100fpm. Things that make you go.. "why
didn't I look at it a little more seriously".
http://www.irishfield.on.ca/gallery/valve1.jpg
http://www.irishfield.on.ca/gallery/valve2.jpg
http://www.irishfield.on.ca/gallery/valve3.jpg
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Friday, October 15, 2010 8:56 PM
Subject: [rebel-builders] O-320 Exhaust valve guide wear
Not how I like spending my Friday afternoons!
http://www.irishfield.on.ca/gallery/engine1.jpg
http://www.irishfield.on.ca/gallery/engine2.jpg
http://www.irishfield.on.ca/gallery/engine3.jpg
215 hours SMOH... run on nothing but 100LL. #4 was down to 58/80.... all
leakage air blowing (roaring) out the exhaust. Was going to try the rope
trick for a valve seat lap, and I started into that and got the springs
removed..... only to find that the exhaust valve to guide clearnance was
like throwing a wiener down a hallway.
Was told if one was that way..they probably all were, so I put the # 4
back
together to get an indication of how much the valve stem moved with the
spring/keepers installed and sure enough they are all about the same. Off
the engine shop tomorrow for new guides and possibly valves. Thankfully I
have a couple sets of valves... so I know they won't be needed!
mike jones
Post by mike jones » Sun Feb 19, 2012 8:06 pm
You got the luck of the irish on your side
Good to hear all is fixed and done
Mike#007
G. O'Shea
Sent: Wednesday, November 10, 2010 3:40 PM
back
Thanks Mike.. we're sure hoping we have the luck of the Irish on our side
for the next battle in the family as well.... our 25 year old daughter
Jennifer, just diagnosed with Ewing's Sarcoma in her right pelvic bone. One
of the rare bone cancers with only 40 or so diagnosis' a year in Canada vs
the tens of thousands of other cancers..... starts Chemo on Monday. Gonna be
a rough haul for her.. at a current 96lbs.. but she'll beat it !
Sent: Wednesday, November 10, 2010 7:30 PM
Mike#007
G. O'Shea
MUCH
Of
flew
back
