Non-magnetic stainless firewall?
schaumr
Post by schaumr » Sun Feb 19, 2012 6:31 pm
Hang on.....an earlier message states that this type of stainless might be non-
magnetic.
I admit the color is slightly different from the surrounding aluminum, and I
would love to believe this is stainless. Maybe it wasn't that easy to file after
all? How the heck do I tell?
Rob
Now I'm not so sure On 8/4/2010 4:28 AM, klehman@albedo.net wrote to
rebel-builders:
-> Curtis
-> Some of us riveted a thin flat sheet of stainless on the forward side of
-> the aluminum. Actually makes for a stronger firewall with a little less
-> risk of damage I'm told.
-> I understand that fibrefrax cloth also meets the requirement. It and the
-> glue is available from Spruce. I did not use it because I figured it had
-> to be covered with something else anyway to keep it from eventually
-> becoming saturated with oil.
-> I don't know why MAM considered aluminum acceptable for early kits.
-> Ken
-> Curtis Langholz wrote:
-> > Rob, Great topic for sure.... I purchased kit # 175r that had been in
-> > storage for a long time. When I purchased it I bought the upgraded
-> > manuals from MAM and got a tour of the factory plus talked to Daryl
-> > about my engine choice. He recomended the 3" shortening of the boot
-> > cowl which I did as well as the fload stiffeners and motor mount
-> > doublers. I was feeling really good now that it was complete.... I
-> > check the MAM bulletins regurlarly as well and there has not been any
-> > mention of the firewall being aluminum or stainless. It is very
-> > frustrating to have all this time putting it together to find out MAM
-> > was so cheap to use an aluminum firewall that is a safety hazard. Can
-> > anyone give me a suggestion of what I should do with it at this
-> > point? Although it is a setback in the building process, it does
-> > need to be addressed. Thanks for bringing up the question about the
-> > firewall material.
-> > Curtis
