[rebel-builders] Electrical quick connects ?
Radio Shack is your friend!!
Keith R661
--- On Sun, 6/27/10, Kelly M. Ewing <kelly@tru-form.ca> wrote:
Subject: [rebel-builders] Electrical quick connects ?
To: "MAM email list" <rebel-builders@dcsol.com>
Date: Sunday, June 27, 2010, 11:03 AM
Does anyone have a good source for the quick connect and disconnects for wiring ? Usually white in color.
Keith R661
Tried with no luck
Kelly
kelly@tru-form.ca
Enjoy your day !
Sender: <mike.davis@dcsol.com>
Date: Sun, 27 Jun 2010 09:19:16
Subject: Re: [rebel-builders] Electrical quick connects ?
Keith R661
Kelly
kelly@tru-form.ca
Enjoy your day !
Keith R661
Thanks Keith I'll check it now.
Kelly
kelly@tru-form.ca
Enjoy your day !
Date: Sun, 27 Jun 2010 09:29:34
Here you go:http://www.radioshack.com/family/index. ... 286&s=null
Kelly
kelly@tru-form.ca
Enjoy your day !
That's it perfect, just need to find a store close to me.
Thanks again
Kelly
kelly@tru-form.ca
Enjoy your day !
Thanks again
Kelly
kelly@tru-form.ca
Enjoy your day !
Digikey.com has them.
Andrew E Burr XIV
Vertical performance LLc
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and holds ownership of all intellectual property for each component.
Date: Sunday, June 27, 2010, 4:37 PM
Thanks again
Kelly
kelly@tru-form.ca
Enjoy your day !
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Thanks again
Kelly
kelly@tru-form.ca
Enjoy your day !
The Big C airplane company uses AMP brand connectors, same thing from some
of the Accessory makers such as strobe lights, wing tip lights, usually
.093" dia pins.
Other brands are Molex, & Philmore--& others I am sure. These are the white
nylon housings available with 3 pin diameters, .093", .062", and about
.031".
The pins use a special crimp tool available for $10.00 to $20.00. Also the
pins can be extracted with a "pin extractor" for under $5.00. This makes it
possible to run a wire bundle through a small hole, then push the pins into
the housing and you are in business. They can be removed to reverse the
process. Available from many electronic, boat, Ham radio sources. AMP
& Molex housings are not interchangeable, but I think the pins are.
Another option is to use "Sub D connectors" metal housings, My local
avionics shop recommends them. This is rapidly becoming my favorite. About
the same connector as you will find on computer components. Two types,
Solder type pins permanent in the housings, or removable pins that can be
soldered or crimped then inserted. Available in 9, 15, 25, 50 pin sizes.
Mostly the ones I have seen are for # 20, or 22 wires. You can also buy the
clamp on housings to make them up to act as a flat cannon plug with wire
strain relief so as to protect the wires from being broken one at a time, as
I have had happen with the nylon type.
Some guys have ground away the flanges. Then sealed the assy with tape or
RTV, PRC or Shoe Goo to make the assy contamination free, but with just a
little work can be cut apart to separate them and re-use. I picked up a
small hand full of the various sizes at our local Fry's store last week. As
I recall about $5 or $6 to set up one complete 15 pin connector with the
strain relief clamps.
Another thought the Sub-D round pins are the same as those used in some of
the Avionics of the 70's, 80's If you have been looking for a source of
pins.
Dick Wampach SR-108 N331RW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Kelly
M. Ewing
Sent: Sunday, June 27, 2010 9:03 AM
To: MAM email list
I want the ability to disconnect the trim wire at the stab, simply plug and
unplug. So I can take the stab off when transporting.
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
password "builder"
.093" dia pins.
.031".
pins.
M. Ewing
To: MAM email list
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
password "builder"
Thanks guys for the advice on electrical connectors, good variety.
Kelly
kelly@tru-form.ca
Enjoy your day !
Date: Sun, 27 Jun 2010 16:37:37
Subject: RE: [rebel-builders] Electrical quick connects ?
.093" dia pins.
.031".
pins.
M. Ewing
To: MAM email list
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
password "builder"
Kelly
kelly@tru-form.ca
Enjoy your day !
.093" dia pins.
.031".
pins.
M. Ewing
To: MAM email list
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
password "builder"
