[rebel-builders] Pro-Seal
Dynamite
------Original Message------
Sender: mike.davis@dcsol.com
To: rebel builbers list
ReplyTo: rebel-builders@dcsol.com
Subject: [rebel-builders] Pro-Seal
Sent: Dec 15, 2009 19:03
What do you use to clean cured pro-seal with?
Dave Greaton
Moose 189
Sent from my Verizon Wireless BlackBerry
Dave Greaton
Moose 189
A scotchbrite wheel in your drill.
To: "rebel builbers list" <rebel-builders@dcsol.com>
Sent: Tuesday, December 15, 2009 3:03 PM
Dave Greaton
Moose 189
I like Norm's answer better. But I think (Ok, I know) your suggestion works
Mike. You can also use a putty knife to get most of the proseal off before
using the scotchbrite wheel on the rest. Or, better yet, use a phenolic
scraper ( ACS part # 12-01796). You can make your own out of similar
material or get different sizes of phenolic scrapers at The Yard Store or
Aircraft Tool.
Maybe I'll try Norm's method on my next project <grin>.
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
Sent: Tuesday, December 15, 2009 5:18 PM
Subject: Re: [rebel-builders] Pro-Seal
Aircraft Tool.
Ted
Dave Greaton
Moose 189
Dave,
I used product from 3M
http://www.aircraftspruce.com/search/se ... h&search=1
worked for me with little effort.
Jeff
On Tue, Dec 15, 2009 at 4:03 PM, David R. Greaton <dgreaton@maine.rr.com>wrote:
Jeff
Dave Greaton
Moose 189
Those are pretty pricey (e.g. $10+ ea) compared to the scotchbrite pads
(e.g. $0.65 ea in quantity) Jeff. How do they hold up/how long do they last
compared to the roloc scotchbrite pads?
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jeff
Micheal
Sent: Tuesday, December 15, 2009 5:33 PM
Dave,
http://www.aircraftspruce.com/search/se ... chsubmit=S
earch&search=1
Jeff
Ted
Micheal
Dave,
earch&search=1
Jeff
Dave Greaton
Moose 189
Ted, it's like this.......
You ever hear the saying "You get what you pay for", well it's true is this
case. The bristle type pads work great, they're flexible enough to get
around rivet heads (or go over top of them) without getting any snags.
I've been down the road of substituting quality product for less expensive
(cheaper) product with somewhat the same result, but the product doesn't
seem to hold up as well as the 3M stuff. I'm sure there's another
manufacturer that makes something similar and cheaper, but I like what I
know works. Unless someone else has a suggestion of a product of similar
stature.
I used ACS as a link just to show product. If you do a search you will find
other distributors that retail for less.
Jeff
stature.
Jeff
last
Ted
Micheal
Dave,
earch&search=1<http://www.aircraftspruce.com/search/se ... h&search=1>
Jeff
Dave Greaton
Moose 189
If it's not too thick MEK seems to work. Bob
Sent: Tuesday, December 15, 2009 5:05 PM
Dynamite
Dave Greaton
Moose 189
Thanks All,
I'm going to order a couple rolox 3M disks for the heavy work. What grit
did you use Jeff? 50, 80 or 120?
Dave Greaton
SR/Moose 189
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Tuesday, December 15, 2009 7:32 PM
Dave Greaton
SR/Moose 189
Dave,
Jeff
Dave Greaton
Moose 189
Dave,
I've used all three types. If you're removing thick layers of pro-seal use
the 50, but I would say the 80 gets used the most. I find the 120 was good
for "light" removal jobs and finishing.
A job I did a few years back of removing the top tank skin of a flying moose
was very time consuming, trying to get all the sealant off all the ribs and
mating surfaces (scraping the PS off took for ever) & the scotch brite pads
just started to clog (which added more time to the job). The bristle disc
worked the best for me and ensured getting a good clean surface for the new
tank skin. BTW the wing was sealed and no fuel leak.
Jeff
On Wed, Dec 16, 2009 at 12:22 AM, David R. Greaton <dgreaton@maine.rr.com>wrote:
Jeff
Thanks All,
Dave Greaton
SR/Moose 189
http://www.aircraftspruce.com/search/se ... h&search=1Dave,
Jeff
Dave Greaton
Moose 189
The --only-- time I use MEK is with wet/damp recently applied but not yet
dry proseal (works great in this situation). MEK won't touch cured proseal.
Ted
Bjorn
Sent: Tuesday, December 15, 2009 9:47 PM
Ted
Bjorn
Dynamite
Dave Greaton
Moose 189
