[rebel-builders] Props
Bob Fisher
Post by Bob Fisher » Sun Feb 19, 2012 12:19 pm
hi walter about 7-8 secs off the water one person 3/4 fuel bit of junk
in the plane little breeze 5mph
but i think it was a 82 x 44 cruise was barely 95 at 2450 instead of 105
mph
speaking of top speed i get about 120-122 @2725 i think you may be a
little over proped drew
fish
Sent: Sunday, August 26, 2007 9:07 AM
Subject: RE: [rebel-builders] Props
Were you flying off the water with it and if so how many seconds?
Fisher
Sent: Saturday, August 25, 2007 8:57 PM
Subject: Re: [rebel-builders] Props
hi walter i tried a borer prop about 2 years ago climbed a little
better
not signifigantly! but it was soooooo slow in cruise compared to the
sensenich that i took it off the next day
bob fisher rebel 342
Sent: Tuesday, August 21, 2007 11:48 PM
Sure would like to see someone try a Borer. I had a chance a couple years
ago, when someone offered to lend me one. But with my cowl and need for a
spacer, it wouldn't fit. I realize the cruise speed would be less, but am
really curious to see how fast it can come off the water, and what the
climb
rate would be.
My prediction for 150 hp is less than 10 seconds (in near no wind
conditions) and 1500 fpm. If not, then it is not worth it.
The only way I get less than 10 seconds with mine, is with a good head
wind.
Top climb for me solo, is 1100 fpm. That is with the Sensenich 74 X 54
150 hp.
Angus
McKenzie
Sent: Saturday, August 18, 2007 9:29 AM
Subject: [rebel-builders] Props
Hi everybody, summer greetings!
I've been running a McCauley 74X56 (now re-pitched 54") that was on my
0-320-A2B on the Champion GCBC it came from.
Built the engine up to 160+hp; the prop worked great at 56" on wheels and
then I went on MAM amphibs, after trying a friends' 74X52 I had the 56"
re-pitched to 54". Works quite well.
Off the water in fairly quick times at gross+ and cruises at 80kts IAS at
2400rpm.
Max static rpm is 2400 and max level flight rpm is 2550.
Not getting to the 2700rpm where all the horsepower lives. Possibly a bit
over-propped.
So, to complicate the equation I bought an 80X40 Borer (McCauley) off a
150hp Champion GCBC.
I intend to install this prop as-is and verify performance but I'm
expecting
to need to re-pitch to about 43". Oh', as well, there was a 2" McCauley
spacer came with the prop if anybody needs one let me know.
Has anyone else tried a Borer? Results? Numbers? Advice? I know that
"rule-of-thumb" is: 1" of pitch = 100rpm
As an aside to this I heard today from Carm Titus that his cousin Mike
Titus
(longtime Leavens employee who has helped many of us Rebel types with our
engines) was working on a plane at Brampton in recent weeks and
momentarily
distracted by a bystander got hit in the head by a prop blade. Carm said
Mike is going to lose one eye. You can't be too careful.
Thanks and best regards to everyone, Angus
Post by Walter Klatt » Sun Feb 19, 2012 12:19 pm
7 or 8 seconds is very fast off the water. I can only get under 10 seconds
with a good head wind, and that is solo. Which Sensenich do you have now?
Your top speed is very close to mine at almost the same top rpm. And what
HP?
Fisher
Sent: Sunday, August 26, 2007 4:08 PM
mph
fish
Fisher
better
climb
rate would be.
wind.
150 hp.
Angus
McKenzie
2400rpm.
over-propped.
expecting
Titus
momentarily
Post by Wayne G. O'Shea » Sun Feb 19, 2012 12:20 pm
Bob counts "a thousand and one...a thousand and two" slower than you do
Walter !! ;O)
Sent: Sunday, August 26, 2007 7:15 PM
HP?
Fisher
junk
mph
fish
Fisher
better
years
am
climb
rate would be.
wind.
150 hp.
Angus
McKenzie
at
2400rpm.
bit
over-propped.
expecting
Titus
our
momentarily
Post by Walter Klatt » Sun Feb 19, 2012 12:20 pm
So you finally figured out how to catch those lakers, huh? Sounds like you
are having a great summer out there. Can't say the same out here,
weatherwise, at least not on the weekends. But it is not over yet... Hope
to get some more fishing in later when the water cools enough to get the
trout biting again. Have just been letting them fatten up for now.
G. O'Shea
Sent: Thursday, September 06, 2007 1:01 PM
Walter !! ;O)
HP?
Fisher
junk
mph
fish
Fisher
better
years
am
climb
rate would be.
wind.
150 hp.
Angus
McKenzie
at
2400rpm.
bit
over-propped.
expecting
Titus
our
momentarily
Hans Kuck
[rebel-builders] props
Post by Hans Kuck » Sun Feb 19, 2012 5:37 pm
No Dennis I do not know anyone who has done the above,however could you
please mail me your address in Cloverdale, and if I am there at 16:30 would
that be to early??
cheers
Hans
On Mon, Oct 5, 2009 at 4:21 PM, Dennis Finley <croydonmac@gmail.com> wrote:
Hi All
Has anyone out their ever switch from a sensenich prop to a cato
prop,and if they have was it on floats,what did they think,I'm getting
close to buying my O-375 lycoming 215 HP
and i was thinking of going to the cato 3blade 78 inch that the
people at cato recommended it was 20 lbs lighter. with the hollow
crank,Eci cylinders and prop i can loose 30-35 lbs up front and gain
35 HP.
Dennis Finley
Elite amphib C-FDYF
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Rebflyer
Post by Rebflyer » Sun Feb 19, 2012 5:37 pm
Hi Dennis,
I went from a Warp drive to a Catto. I absolutely love it. The Rpm
numbers they gave me were right on for static and only 25 RPM low for wot. 100
hrs this year and no signs of erosion. I chose to go high static rpm for
quicker take off and sacrifice cruise. Most of my flying is lake hopping in the
evenings.
Whats great about Catto is just tell them you desires and they build the
prop.
I'm putting one on the Long-ez I'm building. I know of 2 cases where
either lost nuts or even exhaust pipes have gone thru the prop and it keeps on
going.
I would let him put on the anti erosion tape on the leading edge. It was
perfect.
Curt Martin
N97MR
Dennis Finley
Post by Dennis Finley » Sun Feb 19, 2012 5:37 pm
Thanks for the info Curt,i have only heard good things about catto.
Dennis Finley
Elite C-FDYF
On Tue, Oct 6, 2009 at 7:29 PM, <Rebflyer@aol.com> wrote:
[quote]Hi Dennis,
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:58 pm
60's not too much for 160HP on wheels Mike. 58 works great on wheels with
150 HP.
If you find it's a little coarse you can take it to Hope or Leavens for
about $250 and get it repitched finer
Sent: Wednesday, January 13, 2010 4:57 PM
Subject: [rebel-builders] props
Hi all
I have a line on a prop for my 160 hp Lycoming, its a sensenich model
74dm6-0-60, may have come off a pa-140 owner says
Does anyone know if this would work on my setup, assume pitch is 60, way
much but perhaps it can be repitched
I don't know much about props so any help would be nice
cheers
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 5:58 pm
It will work. Recommended for wheels cruise is a 58" Sensenich
prop. Many of the members recommend a 56" prop. The reason I
respond is that I am currently flying with 74DM-6-61 Sensenich
prop and seem to have pretty good performance so far. I am
getting 1100 feet vertical speed and go 120 mph IAS at 70%
power for a 1500 pound aircraft. I have a 160HP Lycoming.
Prop came off a Tri-Pacer which has similar specs.
I have so few hours (in the 40 hour fly off period) that I do
not have exact numbers for my aircraft yet, but am working on
them.
However, I fully expect to have to change my prop pitch in the
future. However, I do not know by how much. In the mean time
I am working on putting fairings on the landing gear cross
members (ala Sloan). That should clean it up a bit and allow
me to better determine a better pitch.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of mike
jones
Sent: Wednesday, January 13, 2010 4:58 PM
Hi all
Does anyone know if this would work on my setup, assume pitch is 60, way to
cheers
Post by Walter Klatt » Sun Feb 19, 2012 5:58 pm
I was getting 1100 fpm on amphibs (solo) with my old 150 hp Lyc. That's
because I had the 74 X 54 Sensenich. Finer pitch is much better, and is not
necessarily bad for cruise or fuel consumption, as I have mentioned here on
this list many times.
For the 160 hp, would recommend 56 pitch on wheels and 54 on floats. You
would cruise at slightly higher rpm, but that doesn't hurt your engine one
bit, and you will really appreciate the extra performance.
I was using the Warp (72 dia 3 blade) when I was on wheels, and was getting
1600 fpm with that one.
Gustafson
Sent: Wednesday, January 13, 2010 2:19 PM
Subject: RE: [rebel-builders] props
them.
jones
Hi all
cheers
Post by Drew Dalgleish » Sun Feb 19, 2012 5:58 pm
And since it's a used prop you should robably measure the length to make
sure it hasn't been dressed beyond limits.
At 07:16 PM 13/01/2010 -0500, you wrote:
Mike,
I believe Sensenich will repitch a metal prop a total of 4 inches over its
life. You might want to confirm that with them and review the prop log to
see if any of that 4' has been used up.
Simon Smith
Post by Simon Smith » Sun Feb 19, 2012 5:58 pm
If anyone is interested I have a new Sensenich 74DM6S8-0-56 that includes
spacer and bolts for $2295.00. If interested you can contact me off list
siks@ticon.net or phone 608-289-6936.
Si
Sent: Wednesday, January 13, 2010 3:57 PM
Hi all
cheers
Checked by AVG - www.avg.com
Version: 8.5.432 / Virus Database: 270.14.138/2618 - Release Date: 01/13/10
07:35:00
Mike Davis
Post by Mike Davis » Sun Feb 19, 2012 8:50 pm
There was a guy out of Juneau Alaska with a 81" borer on his Rebel... Murphy
used to have a photo of it on their website titled "one tired Rebel".
Sent: Wednesday, May 18, 2011 11:57 AM
Yes, I got the HTML thing right after I sent the second email from work.
Here's the question: A friend asked me why no one puts a borer prop or a
longer one on the rebel or elite. I didn't know why. I know the 180 hp
cubs and such are using longer ones. CW
Angus McKenzie
Post by Angus McKenzie » Sun Feb 19, 2012 8:50 pm
I use an 80-42 Borer with my amphibs and I'd use it on wheels too unless I was going on a long trip then I'd switch back to the McCauley 74-56.
And, by the way, I've got a Leavens over-hauled, packaged to ship, Hartzell constant speed with the Woodward govenor and prop bolts to sell, if anyone's interested....?
It came off an 0-320 on RV6 that was repowered with an 0-360. I was going to try it on my Rebel but decided to seek out a newer 82-44 Borer instead.
Date: Wed, 18 May 2011 11:59:35 -0800
craig
Post by craig » Sun Feb 19, 2012 8:50 pm
Angus,
I'd like to talk with you regarding the Borer. Not interested in putting
one one my rebel; just like to hear your experience with it. When you have
a free moment, give me a call 907-355-6290 Alaska time Craig
From: "Angus McKenzie" <angus.mckenzie@sympatico.ca>
To: "Mike Davis" <rebel-builders@dcsol.com>
Sent: Wednesday, May 18, 2011 6:41 PM
Murphy
work.
