[rebel-builders] MAM Brake caliper fittings
Michael Kraus
Post by Michael Kraus » Sun Feb 19, 2012 5:21 pm
You are correct. My RV-4 had the same situation.
Sent from my iPhone
On Mar 25, 2009, at 10:53 AM, "N.Smith" <admin@airnig.co.uk> wrote:
Hi All
On the MAM spring gear brake callipers, mine both came with a NPT
threaded
hole for attaching the supply, and a prefitted brass bleed nipple
that also
looks like it's an NPT threaded assembly.
If the calliper is just a chamber then I should be OK to move the
bleed
nipple to the other hole on one side of the aircraft to allow easier
routing
of the supply line ?
Good idea or am I missing something ?
Ta
Nig
745E
Post by Drew Dalgleish » Sun Feb 19, 2012 5:21 pm
They are interchangable but you need the bleed nipple on top for the air to
get out.
At 02:53 PM 25/03/2009 -0000, you wrote:
Hi All
On the MAM spring gear brake callipers, mine both came with a NPT threaded
hole for attaching the supply, and a prefitted brass bleed nipple that also
If the calliper is just a chamber then I should be OK to move the bleed
nipple to the other hole on one side of the aircraft to allow easier routing
Ta
Nig
745E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:21 pm
Now now Drew.. lol... all depends how you fill them. Bleed screw on bottom
for me...
Sent: Wednesday, March 25, 2009 12:10 PM
Subject: Re: [rebel-builders] MAM Brake caliper fittings
get out.
Hi All
also
routing
Ta
Nig
745E
Michael Kraus
I've personally never seen a bleed screw on the top, but I guess I
have never seen Drews plane either :-)
Sent from my iPhone
On Mar 25, 2009, at 12:51 PM, "Wayne G. O'Shea"
bottom
for me...
the air
get out.
Hi All
threaded
that
also
bleed
routing
Ta
Nig
745E
Well I have my bleeders on the top but I didn't think that through very
well as obviously the air can get out by going up the brake line. I bleed
my brakes from the bottom up then just let some fluid out the bleeder screw
to make sure no air gets trapped.
Sent from my iPhone
bottom
for me...
the air
get out.
At 02:53 PM 25/03/2009 -0000, you wrote: Drew
N.Smith
Post by N.Smith » Sun Feb 19, 2012 5:21 pm
Thanks for all your replies.
I've gone with the pipework going in at the top and the bleed on the bottom.
It looks neater IMHO and hopefully less prone to stone damage.
Nig
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: 26 March 2009 01:11
Sent from my iPhone
bottom
for me...
the air
get out.
Checked by AVG - www.avg.com
Version: 8.5.278 / Virus Database: 270.11.29/2024 - Release Date: 03/26/09
07:12:00
