Hmmmm, wonder how that prop of yours would work on say......am amphibious
Rebel???? Maybe a Rebel in St.Thomas that is currently
over-propped......Interesting thought.....Angus
To: "Rebel Digest, " <rebel-builders-d@dcsol.com>
Sent: Saturday, July 26, 2008 9:11 AM
Subject: [rebel-builders] Prince Prop
Steve, Hank ...
Here are some numbers with the O-320 / Prince 74x47:
Static RPM (tail tied down) 2,500
Rate of climb at 1,800 pounds gross from climb test report 755 fpm
(Pressure altitude 920 ft)
Cruise speed (two people, weight about 1,550; 2,400 RPM) 103 to 105
mph CAS
Max RPM at cruise >2,700
Max rate climb speed Vy is quite a bit higher than the manual says - 80-85
mph CAS versus 69 at 1,650 pounds
The fact that the engine will over-rev in cruise and the cruise speed is
low, definitely suggests too fine a pitch. You don't need 2,500 rpm on
take off either. I am starting to think that I have a lot of cowling /
cooling drag, although temps are very good.
Mike A / C-FNBO
