[rebel-builders] tach tests
Post by Bob Patterson » Sun Feb 19, 2012 3:56 pm
Hi Garry !
Wouldn't it be a whole lot easier on everything to just buy an
optical tach - they're about $50. They read RPM directly from
light interrrupted by the propeller blades - 2, 3, or 4 ...
You could then read the RPM in flight - the Rebels natural setting,
OR - with a helper, get a reading just at the start of takeoff.
In Canada, if you have a 'mechanical' tach, I believe you are
supposed to calibrate them every 2 (?) years ....
.... Any CARs experts out there ????
I would worry a lot about damage to the tail & fuselage - I'm
pretty sure designers don't plan for that kind of loading ! I do
know that, when Cessna 150's, retrofitted with 150 hp engines,
were first used to tow gliders, the fuselages were found to be
stretched by over 1" after the first year !!! This resulted in
some major mods !! ;-)
http://www.prosumers.ca
On Sunday 30 September 2007 12:13, Garry Wright wrote:
Has anyone tied a rebel down by the tailwheel and done WOT tach tests on
a rebel with 150 HP? Any concern about over-stressing the back end of
the airplane?
Garry
068R
Robert Andrews
Post by Robert Andrews » Sun Feb 19, 2012 3:56 pm
Hi Garry,
The WOT tach test you mention are known as static RPM tests. Certified
aircraft have static RPM minimum requirements (in the TCDS for the given
aircraft) when at full throttle w/ the aircraft braked or tied down. The
acceptable RPM range is a function of the engine prop combination. I've not
seen any posted values for Murphy aircraft, but suspect the prop folks would
know range values for a given engine/prop combination. Anyway, once the
range values are known for your aircraft, it should be checked and recorded
at minimum during annual (conditional) inspection ... right along w/
compression test values.
Cheers, Bob 612e
Garry Wright
Sent: Sunday, September 30, 2007 5:14 AM
Subject: [rebel-builders] tach tests
the airplane?
Garry
068R
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 3:56 pm
Thanks Bob. Yes. I have that and am in the process of verifying the
tach. Just looking for advice on tying the plane back for the test.
Garry
Robert Andrews wrote:
Hi Garry,
Cheers, Bob 612e
Garry Wright
the airplane?
Garry
068R
Garry Wright
Hi Bob. What brand have you been looking at? The ones I find are dearer
than that by quite a bit. I have a cheapo digital tach but it can't seem
to compete with daylight. Works fine indoors.
I wonder if tying it back from the drag strut attach points as well as
the tailwheel would be acceptable.
Garry
Bob Patterson wrote:
Hi Garry !
Post by Drew Dalgleish » Sun Feb 19, 2012 3:56 pm
Hi Garry I bowwow a tach tester from the local AME. A dozen doughnuts goes
a long way. For verifying tach function there's no need to check it at full
throttle. I check it at about 1000rpm and again at 1900 which is as much as
my brakes can hold. Amazingly my 1956 tri-pacer tach is always perfect ;)
Garry
Hi Garry,
not
would
Cheers, Bob 612e
Garry Wright
the airplane?
Garry
068R
Joe Ronco
Post by Joe Ronco » Sun Feb 19, 2012 3:56 pm
GARRY: Check this link for some inexpensive tachs. I can't verify they
quality but the prices are reasonable for the 1st 2 or 3. Harbor Freight
also has one for $70.
http://www.reliabilitydirect.com/tachom ... hindex.htm
Joe 279R
Garry Wright
Sent: Sunday, September 30, 2007 10:02 AM
Subject: Re: [rebel-builders] tach tests
Garry
Hi Garry !
optical tach - they're about $50. They read RPM directly from light
interrrupted by the propeller blades - 2, 3, or 4 ... You could then
read the RPM in flight - the Rebels natural setting, OR - with a
know that, when Cessna 150's, retrofitted with 150 hp engines, were
List archives located at: https://mail.dcsol.com/login username
Garry Wright
I checked out these and they either have very short detection ranges
(like the one I have) or very high prices. Thanks anyway Joe.
Garry
Joe 279R
Garry Wright
Garry
Hi Garry !
Garry Wright
Thanks Drew. I have been considering that possibility. I would like to
do the full throttle test just so I really know what it will do - more
to do with prop characteristics than anything. There is usually an ad in
the back of Kitplanes for a laser tach for about $45US. I will look in
last months issue.
Garry
Garry
Hi Garry,
not
would
Cheers, Bob 612e
Garry Wright
the airplane?
Garry
068R
Mike Davis
Post by Mike Davis » Sun Feb 19, 2012 3:56 pm
$50 from the airplane parts store... $20 from the model airplane store. ;-)
http://www2.towerhobbies.com/cgi-bin/wt ... XPT31&P=ML
Sent: Sunday, September 30, 2007 6:47 AM
Hi Garry !
the airplane?
Garry
068R
Mike Davis
Should probably mention too that I've used one of these in my 150 in flight
and had no problem reading through the windshield... just pointed it into
the sun to give the most contrast between blade and no blade.
Sent: Sunday, September 30, 2007 12:42 PM
Hi Garry !
the airplane?
Garry
068R
Rick Harper
Post by Rick Harper » Sun Feb 19, 2012 3:56 pm
G'day Everyone ....
Guys ! ( 'n' Gals) .... ANY decent model / hobby / toy aircraft shop carry them !!!
I've used one - through the screen whilst flying even ....
and they are CHEAP & bloody accurate !
Rick Biggus Harper
541R
Sent: Monday, October 01, 2007 2:02 AM
Garry
Hi Garry !
Rick Harper
G'day Gaz ! ..
I put nice big chocks in front of the wheels ... brakes on hard & UP elevator - when I need to any BIG runnups / ground testing .... works fine ... & NO tailfeather stress whatsoever :o)
Biggus
541R
Sent: Sunday, September 30, 2007 10:13 PM
the airplane?
Garry
068R
