Sorry, my mistake. Std Murphy "windows" that are probably out of Lexan.
Glass, lexan, plexiglass, saran wrap...all looks the same to me <grin>.
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Bob
Patterson
Sent: Monday, June 18, 2007 9:09 AM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] Sealing side windows
Hi Ted !
The windshield manufacturers recommend Bostick 1100 -
it comes in caulking tubes from lumber supply places, in
several colours. It's very low tack, so easy to remove.
"Plexiglass" ??? Most use Lexan for side windows -
if you are using real plexi, be sure to drill holes oversize,
use large washers on rivets, and perhaps use ordinary
"pop" rivets, as they don't expand like Avex rivets ...
and pull gently ! Better yet, DON'T drill holes - make
up an aluminum frame to let the plexi float, like the
beautifully joggled skylight retainers....
http://www.prosumers.ca
On Monday 18 June 2007 08:25, Ted Waltman wrote:
What compound are folks using to seal the side windows with when riveting
them in place? I thought about putting a small bead of proseal all
around,
but am worried that proseal might have some adverse reaction with
plexiglass.
Thanks for input,
Ted
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
