[rebel-builders] Vans baffle kit
Have been approached by a couple of friends to get their Rebel in the air
after their final inspection. Are the Vans baffle kits worth the cash and
are they a good tight fit? I have over heating issues with their assembly
and they also have one of the old high speed cowls with the smaller opening
at the bottom. I believe the top openings have been enlargened but the
outlet is quite small. The baffle is toast with alot of leakage and thought
I could save them some money with the kit rather than fabricating one from
scratch. Thanks for the replies
Steve W 637R
Windows Live Hotmail, with safety bar colour coding, helps identify
suspicious mail before it takes your daughter out on a date. Upgrade today
for a better look. www.newhotmail.ca?icid=WLHMENCA152
Steve W 637R
Steve
I have vans 320 baffle kit on my rebel, went on pretty quick, does require
some mods, but sure saved a lot of research time and effort, overall worth
the money I would say
Mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of steve
whitenect
Sent: June 4, 2007 10:06 AM
Subject: RE: [rebel-builders] Vans baffle kit
Steve W 637R
Mike#007
whitenect
Steve W 637R
Hi Steve: In reviewing the Vans accessories, can you tell me which kit you
used, the BAF-4-320 or the BAF-6-320 for your Rebel. Van's sure has a great
selection of parts and seems to be reasonably priced also. Thanks. - Bob J
Rebel192/731
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Monday, June 04, 2007 10:10 AM
Rebel192/731
Steve
Mike#007
steve
whitenect
opening
thought
Steve W 637R
Hi Bob
I have always made my own with the rule of 2 square inches of leakage but
this takes time and now money for my people who want me to finish their
project. It works really good and haven't ever seen a cylinder temp above
320*F yet. Thought the kit would save them some money but I don't have any
experience with their the product.
Other than trimming the top and front, what other mods are there to do with
the kit? Just flattened my left thumb with a hammer and this is taking me
for ever with one hand and the other in ice water!
Steve W 637R
Steve W 637R
_________________________________________________________________From: "Robert Johnson" <bestofbo@cogeco.ca>
Subject: Re: [rebel-builders] Vans baffle kit
Date: Mon, 4 Jun 2007 10:42:11 -0400
Rebel192/731
requireSteve
I have vans 320 baffle kit on my rebel, went on pretty quick, doesworthsome mods, but sure saved a lot of research time and effort, overallairthe money I would say
Mike#007
steve
whitenect
Have been approached by a couple of friends to get their Rebel in theandafter their final inspection. Are the Vans baffle kits worth the cashassemblyare they a good tight fit? I have over heating issues with theirfromand they also have one of the old high speed cowls with the smaller
opening
thought
I could save them some money with the kit rather than fabricating onetodayscratch. Thanks for the replies
Steve W 637R
suspicious mail before it takes your daughter out on a date. Upgradefor a better look. www.newhotmail.ca?icid=WLHMENCA152
Hi Steve !
Several builders have used the Van's baffle kits - they are very
nicely finished, and fit well. Need only a bit of trimming, and well
worth the money.
You are right that the bottom of the cowl should be lowered
to at least 2 or 3"+ below the bottom of the fuse, and extended
rearward at least a couple of inches, to get good extraction. Also
a good idea to add a piece of aluminum wrapped over the bottom
lip of the firewall to round it & smooth airflow....
(metal body filler tape will work if there's no room for sheet)
All Van's round the bottom lip - it gives them about 8 mph
increased cruise .... just helps cooling on the Rebel ...
http://www.prosumers.ca
worth the money.
thought I could save them some money with the kit rather than fabricating
one from scratch. Thanks for the replies
Steve W 637R
Mostly trimming, some stiffeners, some patches for mistakes, the usual stuuf
for home built, then you will want to modify for any ideas you have,
whitenect
Sent: June 4, 2007 12:02 PM
Hi Bob
Steve W 637R
whitenect
Hi Bob
Steve W 637R
Rebel192/731
requireSteve
Mike#007
steve
whitenect
opening
thought
Steve W 637R
Did u have to extent the backs and sides to meet the top cowl?
Steve
Windows Live Hotmail. Now with better security, storage and features.
www.newhotmail.ca?icid=WLHMENCA149
Steve
_________________________________________________________________From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Date: Mon, 4 Jun 2007 12:57:03 -0400
stuuf
whitenect
Hi Bob
Steve W 637R
youFrom: "Robert Johnson" <bestofbo@cogeco.ca>
Hi Steve: In reviewing the Vans accessories, can you tell me which kitgreatused, the BAF-4-320 or the BAF-6-320 for your Rebel. Van's sure has aJselection of parts and seems to be reasonably priced also. Thanks. - BobtheRebel192/731
requireSteve
Mike#007
steve
whitenect
Have been approached by a couple of friends to get their Rebel in theandafter their final inspection. Are the Vans baffle kits worth the cashassemblyare they a good tight fit? I have over heating issues with theirand they also have one of the old high speed cowls with the smaller
opening
at the bottom. I believe the top openings have been enlargened but_________________________________________________________________fromoutlet is quite small. The baffle is toast with alot of leakage and
thought
Steve W 637R
The cowl is finished unless I have to open up for better air flow if I get
high temps. I was mainly concerned about the tightness of the fit to the
engine itself and if there was any requirement to extend the back and sides
to meet the top cowl.
Thanks to all that replied
Steve W 637R
Fight Allergies With Live Search
http://search.live.com/results.aspx?q=R ... ORM=SERNEP
Steve W 637R
_________________________________________________________________From: Bob Patterson <beep@sympatico.ca>
Date: Mon, 4 Jun 2007 16:43:42 +0000
Hi Steve !
worth the money.
On Monday 04 June 2007 14:05, steve whitenect wrote:airHave been approached by a couple of friends to get their Rebel in theandafter their final inspection. Are the Vans baffle kits worth the cashassemblyare they a good tight fit? I have over heating issues with theiropeningand they also have one of the old high speed cowls with the smallerfabricatingat the bottom. I believe the top openings have been enlargened but the
thought I could save them some money with the kit rather thantodayone from scratch. Thanks for the replies
Steve W 637R
Hi Steve I used the van's kit when I changed engines and am very pleased
with it. It was more than big enough needing trimming all the way around. I
also had to cut and fit a bit on the rear baffles since I have a conical
mount instead of dynafocal. My temps have been good right from the start.
Steve W 637R
Drew: Maybe you could answer my question of which kit best suits the Rebel
cowling, the BAF-4-320 or the BAF-6-320? Thanks. Bob J Rebel 192/731
Sent: Monday, June 04, 2007 5:16 PM
Thanks to all that replied. I'll suggest to the guys to order one.
Steve W 637R
Windows Live Hotmail. Even hotter than before. Get a better look now.
www.newhotmail.ca?icid=WLHMENCA148
Steve W 637R
Hi Bob I ordered the BAF-6-320 at the online store without talking to
anyone so I don't know what the differences are or if the other one would
fit better. My thought was that an rv6 cowl looks more like a rebel than an
rv4 does.
rv4 does.
DrewDrew: Maybe you could answer my question of which kit best suits the Rebel
Thanks for the reply Drew: (I was beginning to doubt if my request went
through) That is the info I was looking for. At least I now know that one
will work. Previous Rebels, the firewall forward kit was purchased from
Murphy, but I will not be doing that this time. I have sent several requests
to Murphy for information on other items and they where never even courteous
enough to reply. Except when I inquired about purchasing another Rebel kit -
I had a reply in less then 2 hours. The last Rebel I worked on, the owner
has been waiting over a year for all the parts for his firewall forward
kit.I guess a possible new customer is far more important then taking care
of existing. Sorry to sound off guys and if this sounds like Murphy bashing,
then I guess it is. Bob J Rebel 192/731
Sent: Tuesday, June 05, 2007 9:59 PM
an
rv4 does.
At 09:11 PM 6/4/2007 -0400, you wrote:Drew: Maybe you could answer my question of which kit best suits the Rebel
