[rebel-builders] Re: Fire extinguisher
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 12:04 pm
Hi Jim: That type of extiquisher is O.K., the only thing I found inspection
wants is it to be secured in a metal bracket (not plastic like so many come
with) and accessible from the pilot's seat. Bob J
Sent: Wednesday, April 11, 2007 10:02 AM
Subject: [rebel-builders] Re: Fire extinguisher
I was reading the CARS 549 to try and find out what type of fire
extinguisher was required for the Rebel. The only thing it said was - "One
approved for aircraft use"
I picked up one that was good for gas, oil, and electrical (class B & C)
so
I assume that should do it??? But what is approved for airplane use or
where
do I find the info?
Thanks for your help.
Jim
Rebel 333
JEFF MCMURRER
Post by JEFF MCMURRER » Sun Feb 19, 2012 12:04 pm
Try this site for info. Covers Canadian & US.
http://www.caspaerospace.com/CASP%20htestinfo.htm
Jeff
Date: Wednesday, April 11, 2007 7:02 am
was - "One
B & C) so
use or where
do I find the info?
Jim
Rebel 333
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 12:04 pm
Thanks Bob/Jeff. Of course I just threw out a metal bracket while I was
cleaning up and the one I just bought has plastic - but again that's why I
asked.
Jim
so
where
do I find the info?
Jim
Rebel 333
Rebflyer
Post by Rebflyer » Sun Feb 19, 2012 12:04 pm
Hi Jim,
The BC extinguisher will work ok, but if you can find a Halon type you
wouldn't blind yourself if you had to use it in the cockpit during flight and no
mess. They are still available. 60.95 at Aircraft Spruce.
Curt
N97MR
************************************** See what's free at http://www.aol.com.
Post by Bob Patterson » Sun Feb 19, 2012 12:04 pm
Hi Jim !
I've been lucky enough to find Halon extinguishers - no mess !
Usually mount on the pilots side, in front of the door - easy to
reach, and keeps the weight forward. (The ELT is mounted
on the passenger side, in front of the door .... same reason ;-) )
ELT antenna on the right wing/fuse gap strip, Comm antenna
on left side wing/fuse gap seal strip - easy to access...
Packing furiously for S 'n F - leaving tomorrow morning !
See everybody there ! :-)
http://www.prosumers.ca
asked.
Jim
inspection wants is it to be secured in a metal bracket (not plastic like
so many come with) and accessible from the pilot's seat. Bob J
"One approved for aircraft use"
so
where
do I find the info?
Jim
Rebel 333
Jim Cole
Thanks Bob, I hope everyone has a great time at S 'n F. Talk to you
When you get home.
Jim
On 4/11/2007 4:16 PM, "Bob Patterson" <beep@sympatico.ca> wrote:
Hi Jim !
