well. I rolled the doors with a metal roller and they hold shape pretty
well without any additional support. If you go all the way down to 0.016
it'll be more floppy than mine and you may want to look at some support
pieces like some tubing bent to shape and riveted to the inside of the
doors. I might even add those myself later to provide more protection
against wind damage with the doors open. FYI - for my Super Rebel I ordered
a 4 X 12 roll of 0.025 from Aircraft Spruce and pretty much used it all with
two doors that I wasn't happy with redone. This does include the metal used
to make my air scoop for my radiator which is integral to the lower cowl.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jim
Cole
Sent: Monday, December 18, 2006 10:54 AM
Subject: [rebel-builders] Re: Cowl doors
I have the cowl support and nose bowl all assembled except for the 4
doors. I thought I would use .025 but I think this is too thick and was
wondering what thickness others have used?
I assume it should be .020 or .016 - but I wouldn't mind a couple of
ideas before I try and order a sheet from Peckovers (now Thyssen Krupp).
If you anyone has another supplier please let me know.
Jim 333
