on line...
Wished I'd had this CD to follow along with when I was building even the
second or third set of floats Jim...and I will follow it myself for the next
set!!
I've just finished clicked thru all 1195 pictures for the second time. Daryl
has set this up in an AMAZING format that has it divided up into 12
sections, with each one letting you just click on the current picture
showing and it will bring up the next one in the order of building. All
pictures are full screen and also have back/forward/return to index etc at
anytime in every frame. I'm of course VERY biased, but I think this CD in a
laptop in the builders work shop will be priceless and worth much more than
we are asking. All pictures include our copyright/logo and encryption that
we are pretty sure will stop anyone from passing a copy onto anyone else.
I'm hoping I've earned enough respect around here that copying shouldn't be
an issue anyhow...but we are making sure. Too much work has gone into this
production to do otherwise.
I will also add that anyone that purchases the Amphib building CD, views the
pictures and decides "what the heck did I get myself into" and then ships us
their kit to build for them will get a full credit on the CD.
We are very close to be able to start burning CD's for those that are
waiting. We just have to find a file I've misplaced to print the CD faces
with and a couple minor changes of some text/picture files and we should be
good to go.
Sent: Sunday, November 12, 2006 12:51 AM
Subject: [rebel-builders] RE: 1800 Amphibious Float - Build CD
THat is awsome Wayne. What a great resource!
On 11/11/2006 8:36 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Well...I've gone thru all the pictures I can think to use...around
1200 of
-> them...and Daryl's busy writing code to upload them into a type of
website
-> format so you DON'T have to click each file #..look at it..hit the X
to get
-> rid of..try and remember where you were for the next picture etc. Once
he
-> has that together I will then go thru them all again to see if I need
to add
-> any explanation text to any pictures. From that we'll see how many
hours
get
-> expended on set up and how long each disc is going to take to burn,
while
-> adding the copy deterrent to each disc, before I can say for sure we
can
-> stick to this price...but for now I am ball parking $175cdn including
CD
-> case/mailing envelope, postage and will include applicable taxes for
-> simplicity.
-> All orders will be via Visa or Mastercard credit cards only and note
that
-> all pictures are covered by copywrite laws and as such their
reproduction,
-> on media file or paper, for anything other than personal use in your
shop is
-> not allowed. No posting in any internet location without my expressed
-> written permission. Anyone ordering agrees to these stipulations or
don't
-> bother ordering a disc please.
-> I'll let you know when we have the final draft. Should be very soon.
Anyone
-> that wants to be contacted directly to order when we are done please
send me
-> an email directly to oifa@irishfield.on.ca
-> If this amphib float build CD is successful. The next one will be a
Rebel
-> Fuselage Build CD. After that with a lot of manual picture scanning we
may
-> be able to do Rebel wings/control surfaces.
-> BTW, this float build CD covers the following:
-> Float build - from kit to ready to mount
-> Main gear axle drill for grease
-> Torque plate mods for easy main wheel install
-> Pump out adapter for beckson pump to fit MAM's tiny cups
-> Spreader bars
-> Mounting struts to Rebel
-> Rigging details shots on various Rebels
-> Flywires
-> Alternate Hydraulic installaton with solid lines
-> Elite installation to CLAMAR 2200's
-> Rudder pedal gust lock
-> Water rudder bar that's required with Clamars to get full deflection
-> water rudders
-> Ventral Fin construction for Rebel/Elite
-> Brake pedal cylinder mounting mod
-> ...and other bits and pieces.
-> Thanks,
-> Wayne O'Shea
-> Irish Field Aviation
-> www.irishfield.on.ca
